Bulldog build
#552
CA
Rob, great work on the wings! I don't know how you keep the glue from getting everywhere. Some of the cleanest work I've ever seen. The frame work is straight as an arrow...Awesome!!
Jeff
Jeff
#556
Even though I have not posted I have, kinda, been working on it. Being the springs did not work out I removed them and in the process noticed some weld rust. So for the last couple days I have tinkered with getting them rust free, acid cleaned, and primed with Zinc Phosphate. I also did the same with the cabane while I was at it. I do not want to reinstall until I have one more flight on mine to know how the bungee is going to work out with the added load beyond the kit. Been trying to get one in but weather has not been cooperating, maybe tomorrow. Anyway, here is a shot of the parts in the primer.
#557
CA
Hi Rob, these are the kind of added things you do that set you apart from most builders. Attention to quality is by far the best I've seen and I'm not just saying that because you're working on it for me. Trust me when I say that It will be well cared for, shown off and flown with great joy!! Have a great day Bro!!
Jeff
#558
I started this morning with putting the wings on in hopes of getting them finished up, but it did not work out that way. The top wing halves when pulled together had a nice 1/4" gap in the front. I spent numerous hours trying to figure out why. I started by laying each wing half over it's corresponding plan sheet, nothing there. After many measurements and much aggravation I laid the sheets over each other and held to light so as to see, perfect alignment with each other. So after lots of finding nothing I had the thought of pulling up the full scale drawings, measuring dimensions in different directions. I finally found that the butting edge on the EMHW paper sheets are off. I don't know why and don't care, I just have to fix it. So, I cut some 1/8" light ply for the abutting ends of the wings, I will glue them on and sand them until the wings but tightly. It may be a while for any progress as tomorrow I start prepping for the trip to Texas next week. I will be gone a total of nearly two weeks. But I promise, when we get back I will get back full steam on this build.
#560
CA
Thanks Bud, that was a lot work trying to find the reason for the the gap on the wing halves. You are a persistent devil. Lol
I hope you and the wife have great time in Texas. We'll be looking forward for some pics and a video of course.
Jeff
Jeff
#562
Ace did you have a similar issue while building the red eagle?
Could be just a discrepancy in the wing tube cutouts in the ribs which won't let the wing root ends mate up when joined together.... the wing tube sockets should be 90 degrees to the root rib on each wing panel in order for the two wing halves to join flush.
John M,
John M,
#563
John M,
John M,
#564
You know I didn't realized until you mentioned yours is a one piece wing... I have no doubt you'll sort it out... I'm just surprised with these EMHW kits being cut with a CNC router it wasn't spot on.... the error certainly wouldn't be on their master plans, so its probably on the paper plan set put in the box; or as you say shrinkage in the plans / wood, or something shifted on the CNC bed that wasn't caught in time.
I've seen some strange things happen with printed plans, especially those Bud Nosen plans; back then they were true "blue prints", some times with big shifts in the paper which didn't get caught by QC... not to mention they faded rather quickly in the present of sun light.
John M,
John M,
#565
The plans would not have to move but a 1/2° to create a gap. But I don't blame the plans I blame myself for I know this and know how to rectify it, just didn't. It will be corrected easily though.
#566
Yep, doesn't take much of a discrepancy.
Don't blame yourself, blame Jeff, he should have been paying more attention to the build
All joking aside, as long as the swept back is the same both side, shouldn't be an issue.
John M,
John M,
#569
The wing joint has been corrected by way of light ply glued to the end butts and sanded. It is now a tight fit and snug on the cabane. I will continue on when the alignment tube epoxy has dried, in about two hours.
#572
Good to be back. I have through Wednesday to work on it and hope to have it ready for covering by then. If I make it I will load it all up, take it north, do the covering and paint in the bigger room. Being as we came back home that room did not get converted and will have to wait until done with this bird.
I have the center fitted real well, the struts predrilled, next is to enlarge the strut hole's for the threaded brass inserts.
