Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
*ASM Cessna 182 (10ft) 30-50cc*
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 07-24-2009, 01:52 AM
loukos
Default RE: *ASM Cessna 182 (10ft) 30-50cc*
A fly buddy of mine flew his last weekend, got to you tube and search for "ASM cessna Cyprus"
Flys beautifly
Regards
Loukis
Old 07-24-2009, 09:37 AM
drdoom
My Feedback: (9)
Link: http://www.youtube.com/watch?v=yNz91DdRA9g
Old 07-24-2009, 11:46 AM
G McIntosh
My Feedback: (9)
I too just finished the Cessna 182. Changed a few thing, but not many. Detailed out the instrument panel, and carpeted the floor. Have a Futaba 2.4 7C w/ 645 hitecs on 5 cells, Fuji 50 EFI, XOAR 20x10 and a Tru-turn. Around 28 lbs. Glenn McIntosh.
ID:	1242746   Click image for larger version
ID:	1242747   Click image for larger version
Old 07-24-2009, 02:37 PM
SteveD-RCU
SteveD-RCU's Avatar
Nice job Glenn,how does the nose gear oleo look,do you think it is strong enough?Also what is the width of the cowl near the front?I'm wondering if a Saito 300 twin would fit in there.
Old 07-24-2009, 06:35 PM
drdoom
My Feedback: (9)
I really wish they could have used a different paint scheme...that one has been used every sence TF released the Gold Kit.Way back in the 90's....
Old 08-01-2009, 07:05 AM
  #31
Zippi
My Feedback: (10)
Zippi's Avatar
ORIGINAL: G McIntosh
G McIntosh,
Plane looks good. Do you have any pics of the center join just behind the windows and how that comes apart for transportation.
Old 08-03-2009, 09:42 PM
  #32
muzzgail
muzzgail's Avatar
Hi all, just finished my ASM Cessna. Used Hitec 5645's and 645's servos throughout, a 50cc DL engine with Pitts muffler.
I just had a look at the CG point and found my plane very tail heavy. Has anyone found the same issue. I am having to add over 1.5kg of weight to the nose to fix this problem, and all of my installation so far has been placed forward in the fueselage.
Regards,
Murray
ASM Cessna
TF Mustang
Tiger 60
Old 08-15-2009, 08:36 PM
  #33
roly1129
roly1129's Avatar
My friend just got his today it is big.
ID:	1256823   Click image for larger version
ID:	1256824   Click image for larger version
ID:	1256825   Click image for larger version
ID:	1256826   Click image for larger version
ID:	1256827   Click image for larger version
Old 08-15-2009, 10:11 PM
  #34
muzzgail
muzzgail's Avatar
She looks nice. certainly are big
Old 08-18-2009, 06:30 AM
  #35
Zippi
My Feedback: (10)
Zippi's Avatar
roly1129,
How does the center section come apart for transportation? I assume the elevator and rudder servos are in the rear of the fuse and all that needs to be hooked up is the wiring. What was the shipping charge on this plane?
Old 08-18-2009, 11:11 AM
  #36
muzzgail
muzzgail's Avatar
4 allen style bolts hold both halves together, accessed through the side door. Assumption is correct, I have used extensions to put the connections handy, where the halves join.
Old 08-18-2009, 11:27 AM
  #37
drdoom
My Feedback: (9)
roly1129 You guys have a Lot of nice models... Cessna looks very nice....
Old 08-18-2009, 04:58 PM
  #38
Zippi
My Feedback: (10)
Zippi's Avatar
How about the stab, does it slide on a tube and bolt on? What type of hinges are supplied? This plane is really looking good for a fall project.
Old 08-18-2009, 07:43 PM
  #39
roly1129
roly1129's Avatar
ORIGINAL: drdoom
Thanks that is just the shop you should see the garage and the trailer.
Old 08-18-2009, 09:18 PM
  #40
G McIntosh
My Feedback: (9)
Ok Gents... flew mine last Sunday... One big Baby'... No problems, flew just great. Came out at 26lbs, Fuji 50 EFI , XOAR 20x10. Glenn
ID:	1258955   Click image for larger version
ID:	1258956   Click image for larger version
ID:	1258957   Click image for larger version
ID:	1258958   Click image for larger version
Old 08-18-2009, 09:48 PM
  #41
muzzgail
muzzgail's Avatar
Nice pictures, congratulations on the first flight. Looking to fly mine in the next week for the maiden also.
Old 09-25-2009, 03:10 PM
  #42
HUNTERANDJEFF
Wow, just seen this thread. Very nice looking a/c. I have been wanting a larger cessna to replace my cmp 140 sized one and looks as if this one is it. Do the wings have clear lenses on the tips for lights? Is there a way to cover the seam on the vert. stab? Are the graphics painted on really thick? If I got one, I would want to sand and re-paint if possible. It looks like you probably could. That paint job is been done toooooo much on cessnas and although it still looks great, I would want something more modern.
Jeff
Old 09-25-2009, 05:37 PM
  #43
cjtyped
I am repainting mine. The black striping that you see is actaully some sort of tape that can easily be removed. I am using an epoxy/microballon mixture to cover up the seam, to be followed by some sanding.
Unlike the CMP kit, there is no provision for the clear nav light lenses on the wing.
I am using a color scheme I found on Airliners..net; have the interior kit and am ordering a set of nav/landing and flashing beacon lights. Using an XYZ engine, 30cc/ Very fun and exciting just to even work on it.
Old 09-25-2009, 07:15 PM
  #44
HUNTERANDJEFF
Thanks.
This looks like a very nice project to work on this winter for me. I am probably going to sell my other cessna to help fund this new one even though my cmp cessna flys awesome.
Jeff
Old 09-26-2009, 04:08 AM
  #45
TomCrump
TomCrump's Avatar
ORIGINAL: HUNTERANDJEFF
Thanks.
Jeff
You'll like this model !!!
I watched Glenn McIntosh fly his big Cessna. It was hard to discern it from the full sized version.
Old 09-26-2009, 10:04 AM
  #46
HUNTERANDJEFF
I think I will like this model!
I really like my Cmp 140 sized one and I was a bit sceptical when I purchased it from that company and after it was finished it was very heavy. But when I flew it for the first time, I was very suprised how well it floated around and how forgiving it was. I have some very acrobatic planes and some fast planes in my hanger but I wanted something that I could fly that was forgiving and stress free - something other than a typical J-3 cub. It was designed for a 60 to 90 glow engine and I put a 120 tt pro in it. It will sustain effortless knife edge down the runway and hover for a bit before falling out. Even though that isn't flying scale - like, it is still very fun. Most of the time I fly it slow, low and practice scale, rudder coordinated turns, figure 8s and touch and goes. Really fun! I will not like to sell it but that has to be sold to help fund this big one.
Here is a video of it flying. http://www.youtube.com/watch?v=fR1RV9qL59k
How strong is the font gear on this new plane? Why is it that most of the arfs out there have weak gear? They spend tons of time on the design of these things but none on the gear. I have to change out the stock gear on my CMP cessna to a stronger Fults gear this winter - and all of the arfs that I have purchased in the last two years have had to have the gear replaced on them and or the blocks re-inforced. Not from landing hard, but just because they are weak to begin with!
Jeff
Old 09-26-2009, 05:08 PM
  #47
G McIntosh
My Feedback: (9)
The front nose gear on the ASM Cessna is a Robart style oleo strut, good and strong for this aircraft. Glenn
Old 09-27-2009, 08:33 AM
  #48
drdoom
My Feedback: (9)
cjtyped Be sure to post Pix of your repaint.
Old 09-27-2009, 05:21 PM
  #49
cjtyped
Will do. White with two tone blue will be the colors.
Old 10-04-2009, 08:19 AM
  #50
iflytailies
My Feedback: (82)
subscribed
