It's here and Looks GOOD new Hangar 9 Taylorcraft
#1302
PA
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft
mobyal this isn;t a contest i just stated my preference but feel free to make what ever critical back handed comment you like
#1305
My Feedback: (53)
ORIGINAL: alb1661
John
My DLE 30 is about 1/8'' out from the front of the cowl with the original standoffs. One issue is covering up the original mounting holes. I have two opinions, cover them with a small piece of covering or painting the black mounting bolts white and reinstalling them and use 4/40 bolts with rubber backed washers on the cowl. I am also using a pitts syle muffler from J-Tech.
Couple more comments....My throttle servo is mounted under the pilots floor using a flex rod with a manual choke rod to the front of the cowl. I installed two on/off charge switches next to the door(had to make one cutout larger) for my A123 batteries.
Good Luck
Steve
John
Good Luck
Steve
#1306
Y'all got me chuckling. I don't much like clean up but I don't much like airplanes that don't sound like airplanes either so personally I've chosen not to go electric. I'd never however, suggest to someone that has gone electric, that his choice is inferior. I've life long friends who now fly exclusively electric. Our preferences are personal... there is no right or wrong. It's all good... except those stinky diesels.
#1309
Well completed mine and maidened. Very nice model this is, Thanks to all you posted here very helpful. using a crrc pro gp26r good pull. a little tricky to put in this was thow as the rear carb comes very close to the firewall, Loking forward to fly this again.
#1311
papparossi... very nice looking plane... if it flies as good as it looks... I understand why you are anxious to fly again soon.
#1313
PA
maiden outstanding power is awsom unllimeted vertical roll rate is quick and axiel point rolls clean flat spins are a thing of beuaty flys good inverted but looks odd one thing i don't know with you gas guys engines making noise can you hear the wistel the struts make on a low high speed pass i can[
#1314
Congrats go vertical, on your maiden flight a treat indeed. Maidned mine yesterday here is a vid i took myself on head cam, Also the pilot has some attitude. Enjoy
http://www.youtube.com/watch?v=Htkjv003xEY
#1316
PA
paparozzi love pilots head looks like it flew well even in the wind i really want to get more time on this plane i feel it can become a real head turnner in the air but yours does sound better and mine wistels
#1317
Paparozzi and go vertical good luck and good news on your flights,could'nt agree more with your impressions.Are we lucky to be flying in the golden age of good looking arf's or what?
#1318
PA
can't agree more in the old days what took me 1week to do would have months of teadeus work after 35 years in this hobby i would have a hard time doing as good a job with this plane
#1319
Totally agree, and even faster with the bnf version of this, But lets say that you do need to spend some time building an arf at least its quite exiting,
Some peaple still go for the plane kits thow, For me the only good think about the kit form is that you take for ever to finish so you dont start looking for the next project? well you all know what i mean.
#1321
Can anyone help with this? I have mooved the cg backwards, but i keep ending up with the elevator at 4 clics trim up, The plane flies good and holds level at slow and high speed sg seems right. Anyone came across this here? Tailorcraft 26cc gas. thanks
#1322
PA
because it is a high wing plane there is some control coupeling on knife edge it wants to tuck one of the reasons is the insidencs between the wing and stab are not O this also causes the need for up trim
#1324
I stay away from computer radio mixes in this type of aeroplane.If it's correctly set up including balance (fore and aft as well as lateral) it's a joy to fly a la natural.Next time you are flying it at what you think is a safe height gently roll it over and stay inverted.It should just need the slightest amount of forward stick to maintain height,good luck mate
#1325
ORIGINAL: Old Fart
The stab was on a tube so the forward stab pin was shimmed 3/64 down or reducing the stab incidence by probably less than a half degree doing so in 1/64 increments. At that point, the elevator was neutral for power flight and the landing glide slope ideal with no mixing and the severity of knife edge tucking was cleaned up.
