Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Bob Nelitz 1/3 Scale J-3 Short Kit build
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 12-10-2011, 08:44 AM
  #226
gordon_mcln
Default RE: Bob Nelitz 1/3 Scale J-3 Short Kit build
Misterbill -
Beautiful job on the interior....!
What was the textured paneling you used for the interior? I think the controls on the cabin wall are beyond me, but I'd be interested in how they were done.
Regards,
Gordon
Old 12-10-2011, 12:05 PM
  #227
misterbill
misterbill's Avatar
The full size J3 I'm modelling actually has aluminium 'tread-plate' style sheeting in the interior, replacing the more usual fabric covering.
I've replicated it with appropriately scale sized styrene sheeting found at an architectural model supply store.
The rest of the interior is scratch built, the seat frames, rudder & brake pedals are from 'Evergreen' styrene tube, control cables are actually braided cable, the rear sling seat is a canvas 'lookalike' fabric stitched accordingly. Though not in the pics the whole control column assembly is made & ready to fit, created from styrene tube, litho plate, and miniature hex head lag bolts.
All the inner controls on the cabin wall are litho plate, aluminium sheeting, wire, beads, miniature screws etc.
The fuel on/off unit was vac formed from styrene.
It's really all just junk box stuff. A good scratch scale modeler NEVER throws anything away just in case......you never know.......
Everything is designed to disassemble and be removable for radio/battery/servo access under the rear sling seat.
The radio switches (2) and charge points are under the yet to be installed flip up front seat cushion.
There's still a bit to do & I'll post some more pix when it's done.
Cheers,
Mike
Old 12-12-2011, 08:10 AM
  #228
misterbill
misterbill's Avatar
Ok, so here's the now done panel, on the bench as well as a PEV (Pilot's Eye View) with it in place at last.
Plus a couple of shots of the tricky front screen trial fitting.
Cheers,
Mike
ID:	1698882   Click image for larger version
ID:	1698883   Click image for larger version
ID:	1698884   Click image for larger version
ID:	1698885   Click image for larger version
Old 12-25-2011, 10:22 AM
  #229
4570jackjack
My Feedback: (74)
Old 12-28-2011, 08:03 AM
  #230
warbirdmustang
My Feedback: (21)
Don't want to step on any toes, but there was an ad here very recently for someone selling the laser cut metal parts for the Nelitz cub here on RCU. DOn't know who it was, and the ad is gone. I believe they were asking 40 bucks for the set and had several to sell. Any help would be appreciated. Myself and two buddies want a set, I think we are going to build three of these!
THanks for the help!
Bryan
Old 12-28-2011, 10:05 AM
  #231
Donairplane
HI, I have the laser cut parts,Please send PM also see post 146 Don.
Old 12-30-2011, 01:35 PM
  #232
Donairplane
Bryan, Some of the jigs I used. Just scrap from my shop. Hope this helps. Will post more later. Don.
ID:	1707121   Click image for larger version
ID:	1707122   Click image for larger version
Old 12-30-2011, 02:06 PM
  #233
eddieC
eddieC's Avatar
Don, are those being welded, silver-soldered or? Thanks, I'm preparing for a build in the near future. They look great!
Old 12-30-2011, 03:18 PM
  #234
frank99
My Feedback: (29)
sweet
Old 12-30-2011, 03:23 PM
  #235
Donairplane
Hi, EddieC, I used Harris Safety-Silv. 56% silver brazing alloy. My local welding supply has it.
Hang on to your shirt as it is $$ was $60.00 a troy oz. I paid $48.00 three months ago,
no telling now. I love the way this product flows in the joints, and very strong!
More pics.
ID:	1707159   Click image for larger version
ID:	1707160   Click image for larger version
Old 12-30-2011, 09:00 PM
  #236
eddieC
eddieC's Avatar
Thanx Don. I have SS, not sure the percent but will check. I like your jigs, maybe this is another item you could make available. Is the gear you made detailed per the kit or your own design? Looks very stout, very nice job!
Old 12-30-2011, 10:13 PM
  #237
Donairplane
eddieC, This landing gear is the Bob Nelitz design on the third scale cub plan and is very accurate.
Also have factory drawings of gear,and Bob did a great job. Just about dead on.
Remember silver solder is low temp.Like Stay-Brite a common silver solder is only 430 degrees
Silver brazing is high temp 1200+ degrees.Bob talks about this on page one in the original magazine article.
See page 1 post 42 for magazine article.
more pics. parts bead blasted, ready for metal prep & primer. First pic just brazed.
ID:	1707480   Click image for larger version
ID:	1707481   Click image for larger version
ID:	1707482   Click image for larger version
Old 12-31-2011, 12:41 AM
  #238
eddieC
eddieC's Avatar
Don, that's some amazing workmanship!  I wasn't aware it was brazed, thanks for the explanation.
Old 12-31-2011, 03:56 AM
  #239
Donairplane
eddieC, Thanks guy, I just enjoy sharing ideas and how too. Hope this helps. Don.
Old 01-06-2012, 07:40 PM
  #240
warbirdmustang
My Feedback: (21)
Thanks for the pics, Don, I'm sure they will help. I also just sent you a PM on the parts with an update. Would I be able to just mig this stuff? I don't know how to braze, and I'm sure I could silver solder, but I can dang sure mig weld this. Penny for your thoughts, guys!
Bryan
Old 01-06-2012, 09:08 PM
  #241
Donairplane
Bryan, I never tried to mig parts this small. Bob Nelitz suggest silver braze so thats how I do it.
Brazing is easy to learn, just takes a little practice. Silver solder is not strong enought for this
application.
Don
Old 01-30-2012, 09:40 AM
  #242
gordon_mcln
Mike,
What is the silver corrugation underneath the dashboard.....I don't see that in all Cubs, but I have seen it in some....
Is it pressed metal? Homemade I presume?!?
Let me know.....
Gordon
Old 01-30-2012, 11:37 AM
  #243
misterbill
misterbill's Avatar
It's the firewall - and should be present on certainly most Cubs - however, not that often shiny - the one I'm modelling has had a restoration, and the guys decided to polish the aluminum up. Seen a few others like that too, plus of course a bunch painted black etc. The ribs are strengthening ribs, pressed into the firewall.
Hope that helps!
Mike
Old 01-30-2012, 11:42 AM
  #244
ulpilotrmh
Please correct me if I'm wrong, but aren't the corrugations on the rear face of the fuel tank? The firewall is between the tank and the engine.
Russ
Old 01-30-2012, 11:45 AM
  #245
eddieC
eddieC's Avatar
The only pics with corrugation I see are the fuel tank on p. 9 of this thread. Are those the ones in question? Also, how are you painting , HVLP gun? Thanks, an amazing build.
Old 01-30-2012, 12:04 PM
  #246
gordon_mcln
The piture was in post 217....Hanging under the dash.....
Old 01-30-2012, 12:36 PM
  #247
eddieC
eddieC's Avatar
That would be the fuel tank, last pic in post #217.
Old 01-30-2012, 02:00 PM
  #248
misterbill
misterbill's Avatar
Ok, so there are reinforcing 'corrugations' pressed into the ends of the fuel tank, and there are reinforcing ribs pressed into the firewall - those are the ones I was referring to in my earlier post. I've attached another pic of the Cub interior from another angle, which should help clear it up....
Mike
Old 01-30-2012, 02:06 PM
  #249
misterbill
misterbill's Avatar
Ok, so there are reinforcing 'corrugations' pressed into the ends opf the fuel tank, and there are reinforcing ribs pressed into the firewall - those are the ones I was referring to in my earlier post. I've attached another pic of the Cub interior from another angle, which should clear it up....
Mike
Old 01-30-2012, 02:14 PM
  #250
eddieC
eddieC's Avatar
Thanx, mrbill. Amazingly realistic! How are the firewall and fuel tank done? Look like metal, but I'll bet they're balsa?
