UMS Evolution Radial Care and Operation
#1126
My Feedback: (62)
Steve, Oh no not after each flight!! That would be awful. That would take away from the joy of the one flip start every time for the next flight. Yes the method you mentioned is correct. One time I flew 8 times my 9-90 in a perfect dead calm evening. That was fun. -Tom
#1128
Hi all,
Finally, past Saturday my Evo 7-77 has made his first flight! Great engine. I love it!
And the sound....
http://youtu.be/n4iXbgbv6Lw
And the sound....
#1131
thanks again for the great Idea Rick, brilliant discovery owed to you, yes, the silver color you see is the copper coating just sanded off, I did use the brazing rod type silver solder, with the white flux, worked out great the only thing I did not do was to add a pressure fitting, not sure if I need to, but will try without it first, I did put one on my Corsair only because I have a 2 tank system and wanted to make sure the fuel would flow from one tank to the other, but on the Stearman I only have one tank, 32oz. only because I had it, my clamps are kind of crude but seem to tighten but not sure I can tighten any more with out making the slot wider, will see after the engine runs a time or two, thanks again...............Steve.
#1132
here are 2 short touch and go video`s of the Stearman that my other camera man got, sorry so short.
1. front seat "rookie pilot" http://youtu.be/gGYaECoumzY
2. rear seat experienced pilot ( actually the builder)Ha, Ha, Major Courtney Payne, for real, http://youtu.be/FH4mGyR9-o4
#1133
Hello all
today so va the time to try stearman with 7-35 after repair.
But I been disappointed with the updated carburetor & 18x8 prop-
no nitro and no pressure to tank.
Motor gave 6200 rpm on the ground, but sounded tired in the air
What to do?
Lars
What to do?
Lars
#1135
Yes Tom, I'll do the careful control, it's probably too much into screwed.
But does anyone have experience with other prop than 18x8 to 7-35 -
for better power?
I'll try with 10% nitro & overpressure til the tank.
Now with the new carburetor has a wider diameter = lower air speed
Lars
for better power?
Lars
#1137
Lars, what you describe as "sounding tired" is a lack of thrust at higher speeds. Your 8" pitch at 6200 rpm yields a pitch speed of around 47mph, which is really low. Just try a higher prop pitch, maybe with lower diameter. Your revs are also too high for my liking concerning these engines. These engines produce more torque than rpm. Hope this helps.
#1138
before had up over 7000rpm, going out and try tomorrow.
Have adjusted the idle needle, I mounted tube on the hose for blow, barely no air flow.
I adjusted from 1/8 turn = better airflow
so I write in Saturday
Lars
Lars
#1139
Hello again
I was and test flew today.
It works better now, but not like before.
Can add, it is uneven compression is, the piston rings are leaking.
I'm waiting for a 17x10 to try
Can say that but stearman weighs 7.3 kg
Lars
Lars
#1140
My Feedback: (207)
Here is a pic of my corsair , finally finished the change out from the G-62. weighted 31lbs with the g-62 now it is down to 28lbs with the 777. She is a kit built TF that I did about 8yrs ago. I have the engine turning 4800-4900rpm on the ground with the prop adjusted to about 20x15 3 blade.
#1143
hello guys,
not really wanting to open up this topic again but, wanting to mix my own fuel, got access to all the methanol I want and wanting to use the KLOTS oil with the 80% synthetic and 20% castor blend and I have a possible chance of getting some nitro, I need to get the formula of the percentage right, now at 128 oz. in a gallon how much of this is minus the oil and nitro? in other words do I subtract for example at 5% nitro would be 7 oz. so would I subtract 7 oz. from the 128 oz. and so on with the oil? so it all equals 128oz.? to make it one gal.? just asking for some in put so I have the right mixture. I know I could cut the Wildcat fuel that I am currently using on my other models but trying to since I have the access to all the methanol I want make some home brew thanks fella`s just asking-Steve
#1144
To keep it simple......Yes
Percentage relates to any given amount soooo........
Of the 100% of the given amount (be it one quart, one gallon or one hundred gallons) the breakdown is as such...
5% of it is nitro...
10% of it is oil...
...therefore 85% of the given amount is base fuel IE:methanol.
So your example of 128 ozs.
7 ozs nitro
13 ozs oil
108 ozs methanol
...and bingo, 128ozs of 5% with a 10% oil content.....hmmmm....sounds like radial fuel
10% of it is oil...
7 ozs nitro
13 ozs oil
108 ozs methanol
#1145
I use a regular fuel with known oil and nitro contents. 16% nitro and 18% oil, cut 50/50 with methanol. This gives me 8% nitro and 9% oil, simples...oh and my 7-77 loves it
It is simple to mix and very little maths too!
Xoar 20x10
Xoar 20x10
#1146
Very true!!! You also get the advantages of any of those nice additives they may have put in.
#1147
thanks for the info guys, I am having no luck yet with the availability of the nitro, still looking, is it possible to run these engines on just methanol and oil blend reliably? if so I will forgo the nitro, maybe give it a try? so if you just go with the oil content, it still would be 10% only of the 120 oz? another words 10 oz. of oil plus 118 oz of methanol? right?
#1148
I was running 0 nitro and the engine ran just fine. But I found its simpler just to cut a jug of 15% with methanol. Heres a screen shot of the math. You can plug in your own numbers. Belated thanks to Ross. It works great.
#1149
0% nitro wont hurt but I cant comment on it....never done that.
Your math is way off. 10% of 120 is 12.......12 off of 120 is 108......so 10 % oil will be 12 ozs of oil in 108 ozs of methanol.
The numbers you put up would be 8.4%
