UMS Evolution Radial Care and Operation
#1527
CA
Hey Maxam (Tom) good to hear from you. Yes, the engine is in excellent condition. I am also considering puting it into a plane that does not require retracts such as a Yak, Stinson or other similar aircraft. I have had good luck with my three cylinder Saitos and my HK five cylinder on the GP Stearman but not so much luck with the BH Corsair because of the weak retracts and retract mounts.
Best wishes and good safe flying.
Heli-NuBee (AKA Roger the radial rabbit)
#1528
CA
OK, I have decided to keep my UMS Evo- 7-77 engine. I just ordered a new plane that was on sale and cost less than replacement retracts for the Corsair.
#1532
PA
Although I have the ring, I had trouble at first trying to get the engine to rev much about 3000 rpms - it would act like it's starving for fuel. Someone (on this forum I think) suggested enriching the low speed needle valve a little and that worked! I only turned it maybe 1/4 turn counter-clockwise. Give it a try!
#1534
CA
It has been awhile since I have posted anything so I thought it may be time for an update. I purchased a Howard DGA-12 from Kangke and have been slowly assembling the plane for my UMS Evolution 7-77 radial engine. The real Howard was powered by a seven cylinder radial so this build will be close to real scale. As always, there have been some challenges in assembling this plane but it is coming along. One of the issues I still face is if I can somehow get the cowl to fit. Kangke indicated the cowl diameter was 12" but when the plane arrived the cowl only measured 10". I am not sure that I can get to cowl to fit at all but I may be able to split the cowl and make that work. I will post pictures in the near future.
#1536
CA
Hey Maxam (Tom) it is great to hear from you. Yes, I sent an e-mail before purchasing the Howard asking the cowl diameter and the response was 12". However, the actual diameter is only 10" which is very tight. The cowl mounts with a ring glued to the inside that makes it impossible to get over the engine unless the cowl is split or some other method is used. I may just forget about the cowl though, because that seven cylinder radial sure looks great on the front of the Howard.
#1537
Hey Rodger, I built the Kangke DG- 12 myself and was surprised at the quality of the airplane for an import arf. I put the evo 77 on it and was able to get the cowl on with some retrofitting but it was such a pain to pull the lower plugs for after run draining of the cylinders I chose to leave it off. Besides, it looked really good with the engine exposed. Couldn't use those beautiful wheel pants either because I had to go to much larger wheels and tires to fly off my rough ranch strip. I also had to beef up the landing gear with some home made struts because the weight of that engine was too much for the stock gear. After several attempts to get off my high elevation airstrip I decided I needed more power so I put the evo 99 on it. The good news is it was plenty of power to get off the ground. The bad news is my 68 year old reflexes were not fast enough to counter the torque to the left after lift off and it cartwheeled into the ground completely destroying the airplane. In 40 years of flying rc and full size aircraft it was the most spectacular crash I have ever had. Fortunately, I was able to walk away and the engine was spared to fly in another airplane some day.
Tom N
Tom N
#1538
CA
Hey Tom N, thanks for the input. I will keep my fingers crossed that I will have a bit better luck with my Howard. We fly off of a 650' asphalt runway so I hope the 7-77 will have enough power for good take-offs. I may have to beef up the landing gear though because the engine is heavy.
#1539
Hey Rodger I think you will be fine on the asphalt runway and at a lower elevation where I think you are. I live on my horse ranch up in the Sierra mountains for 6 months of the year and the elevation is 5700' so the performance of my airplanes is greatly reduced plus my runway is just a grass pasture so I don't have real smooth surface to take off on.
I had to put a lot of weight in the tail of the Howard to get the cg right so I put my ignition and receiver batteries back there and I still had to add some lead since those evo radials are so heavy. It weighed 25 pounds with the 99.
Tom N
Tom N
#1540
CA
Hey Tom N, sorry to hear that you lost your Howard. We are near sea level here in the California central valley so the 7-77 should do the job. I had the engine in a BH Corsair but landing gear issues caused me to give it up and go to a fixed gear type airplane. I will also have to add weight to the tail even though I have placed as much as possible weight to the rear. I even moved the rudder servo to the back rather than using pull pull on the rudder.
#1541
Hi Guys, Have a quick question regarding glow fuel for the radials . I have the corsair almost finished and am ready to break in the engine. I can purchase methanol , no problem and can buy Klotz techniplate oil. However in the interest of keeping things simpler, would it be possible to just use a gallon of Cool Power 10% (which according to Morgan fuels website has 17% synthetic oil) and mix it with one gallon of straight methanol ? The Omega I typically run has 20% oil content and is a blend of synthetic and caster oil . Also what do you guys recommend as a good prop for the initial running in ? Thanks in advance.
Dave
Dave
#1542
PA
Dave
Dave
#1544
Thanks Guys, That was what I figured but wanted to vet it with you guys first. I am not used to an engine that uses such a low oil content . Buying the Cool power and mixing it down with the methanol is an easy way to go . Keeps things simple . I have the Mcdaniels system for the engine but I am hoping it won't need it after break in . It would be nice not to have to carry 2 large battery packs . Tom says his run good without using on board glow but we'll see .
Dave
Dave
#1545
IMO the closer to 7% oil the better. Less worry about fouling plugs, and less soggy idle/transition etc. all the way up to full throttle. I was running 9% oil for a while, and found 7% much more reliable - if you're looking to run without and glow support, I'd then especially drop the oil content in my opinion
#1546
Thanks for the input. I can work the math and blend the fuel down a little bit more to get closer to the optimum 7% . I figure a touch more oil in the mix won't hurt for the initial break in on the test stand but I want to have it running as good as possible for the maiden flight. Nothing like having an unknown plane plus an unknown engine ! I test fly planes for people all the time but this one is going to make me nervous . Funny how that works when it's your plane . :-/
Dave
Dave
#1547
CA
It is time to post a few teaser pictures of my UMS Evo 7-77 radial engine powered Howard DG-12 airplane. The build is nearing completion and I hope to have the maiden flights on this plane next Wednesday.
Heli=NuBee (AKA Roger the radial rabbit)
#1549
CA
OK, the maiden flights of my Kangke Howard DGA-12 went very well. The plane flies great and the UMS Evolution 7-77 radial engine ran great. I am quite pleased with this combination. Here are a few pictures of the maiden flights.
