Moki 2.10 settings
TX
I have an Aeroworks Extra profile with a Moki 2.10. I am having trouble setting the needles. I get the low end set, then when I throttle up, it peaks at about 7200 then drops back to 6500. Im running 5% nitro and a Zinger Pro 20/8. I am going to put a Cline REg on it, but it should still start up and run without it. Any suggestions?
BTW I am using the standard tubing inside the tank and larger tubing to the engine.
My Feedback: (42)
TX
As posted ealier, make sure you have large (1/8" ID) fuel tubing from clunk to carb.
The symptom you are describing sounds like the motor is starving for fuel.
Don't fly it this way!
If the tank is close to the engine, respectfully suggest you leave the Cline off to start.
Get the engine running good without the regulator, then put it on.
Let us know how it works out for you.
3Deep
There are many good suggestions already posted.
Rule #1 Always err rich
Rule #2 Refer to rule #1
Always try and set the top end slightly rich first and then go to the bottom end adjustment. The disc on the bottom end of the Moki is very sensitive so only move it a little at a time. Get the motor to hold its maximum revs with the nose up for at least a minute. The main needle is not as sensitive as the bottom end needle
Cooling could also be a problem if the air has nowhere to escape - 1 in 3 out
Definitely need big bore fuel tubing and big clunk.
Moki's also take a long time to run in. Be patient and the Moki will serve you well.
You also need a fairly open exhaust to prevent overheating.
The prop you are running is fine
Regards
Zane
Regards
Zane
