Welcome to Club SAITO !
#6877
TN
RE: Welcome to Club SAITO !
It is what was on the engine when I bought it. Do you think I should put a muffler on it?
Did you see my post on what happened when I restricted the pipe?
#6878
My Feedback: (102)
J, is that a stock Saito pipe, all the stock Saito straight pipes I have here have the ends crimped a little, since it will draw fuel well at part throttle but not at full throttle more or less says it is lack of tank pressure. My guess is that if you open the throttle slowly it doesn't quit.
#6879
TN
It is better when I slowly open the throttle but will still die within seconds. It will run the tank out at half throttle or idle. As I said a few post up, restricting keeps it running at full throttle. It just seems like somrthing is wrong if I have to restrict the pipe. I am just not sure about the stock pipe part as this is what was on it when I bought it.
Thanks forr all of the help!
Kevin
Kevin
#6881
TN
Yes it is loud! Sounds really good though. I think I may be close. I have it now where it runs really good from top to bottom. Turning 9960 RPM's w/15x4W. Should do pretty good on the harrier 90. If the weather holds I may get to fly it this afternoon and really give it the true test.
#6882
ORIGINAL: brewerjk
I have run the needle in and out and no effect. I am running the engine inverted and the fuel tank is set right. I have a straight pipe on it and was wondering if I need more pressure from the pipe at full throttle.
#6884
I’m running a SAITO .82 inverted in a World Manufacturer 1/5 scale clipped-wing Cub. The high-speed needle valve is difficult to reach for adjustment because it is covered by the cowling. I would like to extend the needle valve out the side of the cowling. Is there an extension available for this needle valve?
Rick
Rick
#6887
MB, CANADA
Squeeze the pipe with heavy pliers a bit at a time till you get what you want. I have had 4 srokes that required muffler pressure because without that the rich HS setting due to no pressure would make the low end too rich. With muffler pressure (which reduces at low throttle) things were OK.
#6888
MB, CANADA
I noticed in the saito manual that saito recommends a 14X6 prop for the 65, 72, 80, 82, 91 and 100. I don't think I would use this size on a 100 or 65. Anyone care to comment on this?
#6891
The APC pull even harder... I think im turning 10,200 wide open, tied down, with my 65 and the 12x6. I have it on a 46 size Decathlon. (flying pig) My 72 is on a 40 size Super Stearman with a 13x6, and it's just right ! I only use Master Airscrew props.
Give me a 40 size biplane, over power the heck out of it, and im happy... lol
#6894
TN
ORIGINAL: scratchonly
