Need help with OS 1.08 two stroke
Old 01-22-2002 | 04:13 AM
Default Need help with OS 1.08 two stroke
I just reinstalled an OS 1.08 2 stroke in my Spitfire (inverted engine) and it starts, runs fine with the glow igniter, and for about 30 seconds after removing the igniter. It then just dies right down without "loading up." Yes, I did try a new glow plug. I can't tell if the engine is getting too much fuel and drowning plug or is not getting enough. When I restart, all I have to do is tweak the nose cone backward and it fires right up and runs normally (until I take the heat off.)
This engine has an oddball low-end adjustor screw that operates a cam lever. It seems to accelerate normally without stumbling or cutting off. One more thing, the high speed needle is only open less than one turn (about 3/4) and it seems like it should be more than that. I did get it to make one pass around the field, but it cut off in a Cuban 8 and glided back dead stick. Any help or hints with this would be greatly appreciated! Feel free to email me.
Fred Lomax [email protected]
Old 01-22-2002 | 06:29 AM
Get that Hi speed out 2 turns at least ,peak, richen 300 rpm, then start with the low speed needle.
Old 01-22-2002 | 06:37 AM
My Feedback: (31)
You did not mention if you had attempted to move the low speed/mid range transition adjusting cam lever around, try leaning it out a little. If nothing else try a hotter plug...
What are you using for a plug?
Old 01-22-2002 | 10:27 AM
The OS 7D carb on the 108 has an extremely narrow low end range of adjustment so only move it a hair at a time if necessary. Also try an OS #8 plug or better yet an Enya #3 which is a bit hotter. Also this engine eems to prefer 15% Nitro or lower. I wonder if richening up your high and low end might offer a solution.
Old 01-22-2002 | 02:03 PM
SDM
My Feedback: (9)
Default A couple things to try
The engine slowing down when glo heat is removed
is usually an indication of either too rich a
mixture or not enough nitro or possibly too
cold a glo plug. Also have you tried starting
the engine with the plane inverted so the engine
is upright? If the behavior of the engine changes
then it could indicate a tank height issue...
Just something else to try.
Good luck Sam
Old 01-27-2002 | 03:38 PM
Default Problem with 1.08 solved!
THANKS! (TO ALL WHO RESPONDED). Problem was solved by leaning out low end. Now sits there idling with no attempt to cut off. The glow plug was drowning.
Fred picture of plane is attached.
