Saito adjustment help needed
Old 12-10-2006, 11:20 PM
kinnaird
Default Saito adjustment help needed
I was changing the angle of the throttle arm on my saito 56 and thought the Idle adjustment screw was the set screw, so I backed it out quite a ways before I realized what I had done. Does anybody know what the factory settings on that idle screw is. The factory setting was working great and If I just knew what it was things would be a lot easier.
TIA
John
Old 12-10-2006, 11:22 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: Saito adjustment help needed
With the steel throttle arm the head of the screw is even
With the plastic arm recessed about 1/2mm
But the final adjustment is how it runs. That's why it is adjustable
Old 12-11-2006, 11:16 AM
wcmorrison
ORIGINAL: w8ye
Those are starting out positions and are generally rich. So from there the needle is usually turned in. Start there and work your way in until you get a good idle and transition. So this in small steps like an 1/8 of a turn.
Have patience and good luck.
Cheers,
Chip
Old 12-11-2006, 09:31 PM
kinnaird
Thanks for the response guys.
I was actually hoping that the factory had a certain number of turns that they normally used. The motor was running great with the factory specs and I was hoping to just dial that in and keep flying with minimal tinkering.
John
Old 12-11-2006, 10:42 PM
rc-sport
My Feedback: (12)
rc-sport's Avatar
You'll find that Saitos from the factory are set very rich on the low speed needle. Get it set right and you will be amazed at the idle will now get.
