help
OR
I think you forgot to add what it is you are using this motor on. People are throwing opinions, but what if you want max speed, or you want 3D? a16x10 3 blade works awesome for 3D with that motor in an edge 540 I had, then I had the same motor in a p-51 and it really loved the Mez. 16x11. Unfortunately, if you don't try several, and go by opinion, you may end up with one that is only satisfactory and never know the difference. Just my .$.02 worth.
Hope nobody minds a slight highjack of the thread here......
What about a 3 bladed prop to replace the MA 15x6 for a Saito 170R3? This will be on a Sukhoi kit that has a very big round cowl. There won't be a lot of prop diameter past the cowl. Good performance will be an issue as this engine is about the minimum for the model.
MI
Richard,
I owned this engine and owned this prop: Graupner 16x8 3-blade. It will swing it at around 9000 rpm -> perfect match. This is the same load as Pro Zinger 18x6. You can get this prop from www.hobby-lobby.com or www.prop-shop.com
Master airscrew 16x8 3-blade will work too.
I also have the MA 14x7 3-blade, 15x7 3-blade, Graupner 14x7 3-blade & 15x8 3-blade. They are all for smaller engines.
The rule of thumb is to drop 1" diameter and 1" pitch to get very similar results. Start off with a 17x5. Remember, what you add to the diameter must be subtracted from the pitch or vice-versa. It really depends on what you want. Speed, go with a 16x6 or 15x7. Aerobatic would ask for an 18x4. Just pick your application.
I had one on a Saito 180, what a horse.
