ASP/MAGNUM FS400AR Rebuild/Overhaul
#2601
Ah - nope.
Just the link posted - the vid didn't embed at all.
Will see if I can figure it out...
http://vimeo.com/74850163 BJ
Ahhh.... if you "Go Advanced"... then click the "Insert Video" icon and paste the video link that way, it seems to work.
#2609
I'm interested in the matter since I'm a happy owner of a new Laser 300v. So time to star testing some props, such as Menz 20x8 (which is Jon's favourite with the 300v) and APC 20x8. Apc is faster but i don't know which of these two pulls better. I guess I just need to acquire them both and test it..
But ok this is going to be off topic so let's get back to the ASP 400 theme..Thank you Rev
#2611
Anyone ever tried to make their own crankshaft?
A bit off-topic re the ASP 400 - but I scored a half-decent ME 109 and would like to put a multi-cylinder (4 or 6) inline in it.
Kolm's just cost to much... so I have this idea in my head to use ASP 'spares' (top end - cylinder/sleeve/head + valves etc) and maybe turn up a crank and Mill an Ali engine block blah blah blah.
Too hard maybe?
BJ
Too hard maybe?
BJ
#2614
BJ - it all depends what material you hope to use for the crank and what machines/services you have available. We have had people use Laser parts to make flat twins, V4's and V6's. Also a few radials have been done with our parts.
In any event I wouldn't fancy running a crank that wasn't hardened, then you need to do some grinding as well to get the bearing fits all nice. It can be done for sure, but plan it carefully before spending any cash
#2615
First flights
Hello,
as proposed and requested I post some pics and a vid from the first flights of my Gee Bee R3. The engine has around 2.5 l through and runs quite fine so far. No problems with hydraulic lock of the bottom cylinder of the rotated engine, but has some difficulties running on all five pots. Starts easily and I am happy so far. Here are the pics:
As you can see I designed a new, fully damped landing gear, which already proved to be worthwhile. No jumps on touchdown. And here is the video. I am no expert in video editing, so please forgive if it looks awful:
http://youtu.be/knCJUCpMyiI Have a nice day!
#2617
#2618
Is that a stock ASP 400 you've got in that?
What a magnificent deep, rich sound
Mine sounds rather pissy on the test stand with just the standard staight exhaust headers.
Must be the ring muffler? Keleo I'm guessing?
That thing sounds (and looks) absolutely killer, mate
BJ
#2619
Ho-lee crap!
BJ
BJ
PS: Maybe also the quite low RPM helps too. With the 22x8 and around 6500 it doesn't create that much high frequencies.
#2621
Thanks Tom. The glow driver is home-brewed. I originally did it for my Evo 999 and downsized it to five cyls. It uses a 3S LiPo and cuts down the voltage using PWM from the Arduino Nano. Because I prefer to have full access to my equipment I also wrote the software for it. One can connect the throttle channel in parallel and set a throttle point by a potentiometer from where the glow driver kicks out and additionally switch it on/off via the TX. If I have new ideas I can add them as I like. The board is also selfmade. The glow driver is able to fire the five plugs around 70 minutes uninterupted with a small 2500 mAh battery. It is comparatively large, but I did not want to go and use SMTs. If anyone is interested I can provide the schematic, board layout and program.
Cheers,
Olaf
Cheers,
Olaf
#2624
Good job Olaf ! I would be interested in your schematic + board & layout
I suppose the parts are readily available in a electronic supply store ? Do you have an idea of the total cost ?
Thanks, Vasek
Thanks, Vasek
#2625
You can put me down for the details of how to make the glow-driver too, Olaf.
From what I've been reading, some of the commercial ones can be a bit flimsy and hit-an-miss at times - so something genuinely reliable would be a bonus
Danke.
BJ
Danke.
BJ
