MDS 48 PRO
My Feedback: (79)
I guess I took the comments a little to seriously. I was just venting and am sorry for the bad comments, and I still think you are a nice guy. I just did not like the crack you took at us.
I personaly never messed with them, or FOX!!![X(] MDS was doomed from the get go, and there reputation for dead sticks got out very quickly.
] Even if it was partially do to operator eror, there are too many good engines out there to take a chance on one of those. I know were a couple MDS'S are still sitting in the showcase, and nobody will buy them.
As far as Fox goes, I have never seen one run decent. I have been around flyers who take this hobby very seriously (Pattern flying) my whole life. The only Fox's I have ever seen were by older stubburn gentleman, who refused to buy a foreign engine, and guess what, they sat there all day trying to tune it, and keep it running while we fly.
My Feedback: (264)
ORIGINAL: MOTORMAN37
MDS has allways stood for "Many Dead Sticks" in my book.
Sell it and buy a decent engine. A Magnum, ASP, or any other engine in that matter.
I know this is not what you want to hear.[X(]
Sell it and buy a decent engine. A Magnum, ASP, or any other engine in that matter.I know this is not what you want to hear.[X(]
BTW, I have 5 fox engines and about 7 or 8 MDS in various sizes. I'm not afraid to tinker with my engines until they submit, they all run well for me.
Mike
My Feedback: (102)
As I mentioned above I avoid making comments about engines I have not owned, I've seen guys fumble with some of the best engines you can buy, most engines are only as good as their owners tuning abilities. I still have one of each size of MDS engines from the .48 up to and including a 2.18 and about a dozen Fox's most have been flown except a couple of rare .15s and a new .46 that I just put on a H9 Cessna 62. I tried everything to get a fourstroke on it but they're just too long, Enya .53, OS .52 and Saito .56 and .62, all no go.
ORIGINAL: SABREPD
Hi all,
First of all I did`nt think this was going to such a big topic, but it`s great to hear all of the advice i`m getting from some of you and I certainly won`t give up on the motor. I will try alot less nitro and give that a try and try some different plugs especially that fox one if I can find one, never seen or heard of one. But good news I won a new SC 46 ABC on ebay, so any advice on this whether it`s good, bad, or anything else, please let me know.
Many thanks again for all the advice, hope to hear from you all again.
Nige.
Hi all,
Nige.
If I were you I would use that SC46. Put an OS #8 plug in it and run it on something like Duraglo 5 , or Irvine sport 5 and enjoy many hours of happy , reliable flying. By all means have a go with the MDS but I doubt you'll find a Fox plug very easily in this country.
ORIGINAL: Hobbsy
Barry, I was obviously not referring to the original poster since I too have a MDS .48 and like it. If he listens to the sound advice given by the helpful posters he will like his too.
#34
My Feedback: (14)
ORIGINAL: w8ye
There have been many threads about the MDS engines. One guy's engine runs perfectly and the next guy cannot get his to run.
A lot of the problems come from air leaks around the base of the carb.
MDS engines also tend to unload more in the air than a OS or Irvine for example. Therefore they need to be set a little richer on the ground to allow for the unloading in the air.
Engines "unloading" in the air need less fuel, not more.
However, an engine with weak fuel draw needs a richer initial setting than one with adequate fuel draw. Couple this (weak fuel draw) with an engine being fed too much nitro for its compression ratio and you have a deadstick just waiting to happen.
The problem with MDS engines was the same problem that Indy R/C faced with ASP engines. They were built for no more than 5% nitromethane in the fuel. Run 15% nitro with a slightly larger than the minimum recommended prop and you were into preignition right off the bat. The engine overheats, sags and then quits. One very unhappy customer is the result.
Ed Cregger
#37
FL
regardless of the brand, if its hard to tune, the carb is the problem. spend a few bucks and buy a 'perry' carb and your problems are over. i've been doing that for years.
'th' dumb ole florida cracker'
#38
FL
mike, i'm like you, i still fly mccoy .35s. i'm too hardheaded to give in. they'll fly or die. sore bleeding fingers are a badge of honor to an old man.
#39
ORIGINAL: Ed Cregger
Ed Cregger
Ed Cregger
#42
My Feedback: (147)
GA
Nige,
I picked up an MDS .48 at a swap meet from a fellow who gave up on it. The price was right and I took it on as a challenge. Read all the posts for advice and did the following:
1. Mixed my own fuel 21% castor oil, 79% methanol.
2. Sealed the carb with RTV, expecially around the funky two piece carb hold down bolt.
3. Installed a Fox shielded glow plug.
4. Installed the engine on a trainer, gas tank cushioned, with middle of tank 1/4" below carb needle.
5. Used 11/7 prop.
6. Took off rich and watched it lean out in flight.
7. Slowed engine down when it sounded like it was getting hot.
8. After about four hours of flight time, the engine in now fully broken in and operates reliably. No flameouts with excelletn transition from low to high.
9. Compression is excellent and starts at one or two flips of the prop after prime when cold or hot.
10.The MDS .48 is the most challenging of the MDS line, definitely not recommended for the beginning pilot or anyone who expects to mount a new engine in his plane and fly after running one or two tankfuls on the ground. It requires patience and an experienced ear for tuning.
11.Since the first one, I have acquired three additional MDS .48's, one MDS .40, two MDS .68's and three MDS 1.48's all slightly used, from modelers who couldn't wait to get rid of them at swap meets. The other sizes have been less challenging to break in and get to run right. The 1.48's have the C-2 carbs. The others have the original carbs which are tunable.
5. Used 11/7 prop.
