Go Back  RCU Forums > RC Airplanes > Golden Age, Vintage & Antique RC
Reload this Page >
Gilmore Red Lion Build
Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Old 05-09-2015, 08:18 AM
  #326
acerc
acerc's Avatar
If that first one is that heavy, send it to me and I'll make you them out of .060 PTEG. Small parts, in height, I can do easily and very repeatable.
Old 05-09-2015, 10:23 AM
  #327
Melchizedek
Melchizedek's Avatar
Thanks a million for your kind offer Robert. However, I am invested in the rout I have begun and will press on.
Iteration 3 is in the bag. Making sure both 6 oz plys were down (as I was negligent in iter 2) and then manipulation of bag and breather cloth ( thumb deeply planted in big end, pinky implanted in small end) then pump on. I believe I have solid press up.
I added another parting plane at the opening of the cowl mold because I want a flange there.
I then waxed on, waxed off Danielson, X 3 then pva. Then applied Jell Coat.
Off to layup last part of cowl mold. WooHoo !!!
Kevin
Name:	m_Jell Coat cowl mold main body 36 001.jpg
ID:	2094893   Click image for larger version
Name:	m_Jell Coat cowl mold main body 36 002.jpg
ID:	2094894   Click image for larger version
Name:	m_Jell Coat cowl mold main body 36 003.jpg
Old 05-09-2015, 11:10 AM
  #328
acerc
acerc's Avatar
Sounds like you have it well I in hand. And I know exactly how you feel about press on, my canopy currently is worth around $300 and still more to come. Maybe we want what we want to much....
Old 05-09-2015, 06:13 PM
  #329
Melchizedek
Ok, cowl mold complete. It took a lot longer than I thought.
After Jell Coat. I mixed up some chopped CF and epoxy to make a fillet in the two corners.
Then 6 oz 6 inch wide overlapping strips front to back up and on flange.
Then 6 oz around twice. Then two layers of 6 oz on both flanges up lapping the side about an inch with second layer overlapping joints of first.
Then honeycomb on matting flange, then 2 more layers 6 oz over honeycomb in same fashion as first two.
Then flipped over and two layers of 6 oz on cowl opening flange overlapping side like matting flange.
Then for good measure I wanted to make sure the conical wall stayed straight. I cut a heavy cardboard tube in half to make uprights for sides.
I then epoxied them inside and out. Then glassed them to the sides of the cone.
It sure aint pretty but I think it will be durable.
Can you tell I didn't have anything heavier than 6 oz ?
Tomorrow I get to find out if I did everything right. Boy I sure hope so (understatement ).
Oh yea, Do you remember the blister ? How could you forget ?
I am happy to report. Recipe found.
Good layup and light weight. The battery on my scale is dead so full report will have to wait.
2 layers of 6 oz it will be. It is plenty stout. Cant stand on it, but you can't have everything.
OnWard
Kevin
Name:	m_finished cowl lauup 37 001.jpg
ID:	2094991   Click image for larger version
Name:	m_finished cowl lauup 37 002.jpg
ID:	2094992   Click image for larger version
Name:	m_finished cowl lauup 37 003.jpg
ID:	2094993   Click image for larger version
Name:	m_finished cowl lauup 37 004.jpg
ID:	2094994   Click image for larger version
Name:	m_finished cowl lauup 37 005.jpg
ID:	2094995   Click image for larger version
Name:	m_finished cowl lauup 37 006.jpg
ID:	2094996   Click image for larger version
Name:	m_finished cowl lauup 37 007.jpg
Old 05-10-2015, 07:30 AM
  #330
Melchizedek
Plug has been pulled from mold.
Plug was destroyed though. Can't say I would have saved it but it was a little heartbreaking .
Turns out I had sanded a slight undercut at the opening of the cowl ring.
It took a blast of air in the centering hole to break the ring mold free with the top of the plug still in it.
The top of the plug would spin in the mold but had to break it free.
I am kicking myself for forgetting to mold in the alignment buttons. 2 of the 3 I glued on broke free of the ring mold.
Small mistake in the whole scheme of things.
After thoughts.
1. the Jell coat should of been applied thicker. Although black Jell Coat on a black grey plug is hard to tell how thick a coat is.
You can see though the jell coat in the light. The surface is slick and smooth though.
2. The number and weight of the cloth on the sides probably would have not been enough had I not added the insurance of the half round tubes.
The tubes turned out the be a saving grace (state farm double check). The wall between the tube is self supporting but flexible. I will reinforce
the wall before molding the cowl. The top ring is very stout. I attribute this to the shape. A tight compound curve of any structure is stronger than a
simple curve of same material.
3. DO NOT start mold making unless there is no other agenda that day. Yesterday I began molding at about 1 with a 5 oclock dinner engagement
looming. At about 3:30 I began to feel rushed. At 4:20 I heard " honey it's 4:20" Boy I wished I had begun this earlier. I was rushed to the end and
was 1/2 hour late for dinner. Not a desirable situation and could have paid a steep price. But I got away with it. Captain lucky rides again
Results
Kevin
Name:	m_Plug pull from mold 38 001.jpg
ID:	2095083   Click image for larger version
Name:	m_Plug pull from mold 38 002.jpg
ID:	2095084   Click image for larger version
Name:	m_Plug pull from mold 38 003.jpg
ID:	2095085   Click image for larger version
Name:	m_Plug pull from mold 38 004.jpg
ID:	2095086   Click image for larger version
Name:	m_Plug pull from mold 38 007.jpg
ID:	2095087   Click image for larger version
Name:	m_Plug pull from mold 38 008.jpg
ID:	2095088   Click image for larger version
Name:	m_Plug pull from mold 38 010.jpg
Old 05-11-2015, 02:47 AM
  #331
stevegauth30
stevegauth30's Avatar
nice work captain lucky.
Old 05-11-2015, 03:51 PM
  #332
Melchizedek
Thank you Steve,
Just so you know. Capt Lucky is not me. Capt Lucky is like Capt America. He rides in to save the day.
One of these days he won't be there, he will be busy saving someone else's day.
Coming forecast ? Along with the coming cowl layup and the 18 little minions .
The wheel pants will be shaped and then set in a jig to get the geometry of the landing gear correct.
Looking forward to this part. Been pondering it for awhile.
Kevin
Old 05-12-2015, 05:49 AM
  #333
FlyerInOKC
FlyerInOKC's Avatar
Nice cowl!
Old 05-12-2015, 06:01 PM
  #334
Melchizedek
Thanks, Mike
As you all know the cowl plug was made mostly of foam. Hold with one hand sand with other.
Since the wheel pants are MDF. Shaping them will take quit a bit more effort.
So they needed to be held steady whilst I commit acts of violence to them.
The pants sit tail slightly up with the datum line. I thought it best to mount them for shaping in that attitude.
So I built a jig to slot the bottom at 90 degs to the datum line. The jig holds them level and also has a built in template on top for routing the slot. The slot is 2 inches deepl
I then cut some poplar to fit snugly into the slots. When the boards are mounted plumb the pants are at the correct posture. The pants can be removed easily from the mount boards when necessary yet hold them firm when hogging material off them.
Next a sturdy base to secure the boards then shaping can take place.
Kevin
Name:	m_wheel pants mount 40 015.jpg
ID:	2095620   Click image for larger version
Name:	m_wheel pants mount 40 016.jpg
ID:	2095621   Click image for larger version
Name:	m_wheel pants mount 40 021.jpg
ID:	2095622   Click image for larger version
Name:	m_wheel pants mount 40 022.jpg
ID:	2095623   Click image for larger version
Name:	m_wheel pants mount 40 023.jpg
Old 05-13-2015, 09:25 AM
  #335
FlyerInOKC
FlyerInOKC's Avatar
That is going to take some time to shape MDF but it will be worth it. Stupid question, couldn't you make one plug and then make the strut cover a separate piece with left and right versions as need? The pants themselves look identical to me. Also will the strut cover be a one piece or are you using an oleo style strut and require a two piece arrangement?
Old 05-13-2015, 01:03 PM
  #336
Melchizedek
Mike,
Two reasons to make two. The outside of each spat has a hub cap like disc. I intend to mold that into the spat. I could just add it after the fact but I would rather mold it in for strength. Also the lower part of the strut cover will be molded into the spat. This will make right left inside halves. The upper strut cover is not affixed to the fuse. It will attach to the lower strut cover that is molded in to the spat. The upper strut cover has to flex quite a bit to get over the gear wire bend. If it had the lower fillet molded into it, it might not flex that much.
Look at the gear detail as per plan.
I made the mounts to support the blanks so they can be shaped.
This should aid in making them symmetrical and holding them firm.
Kevin
ID:	2095702   Click image for larger version
Name:	m_Wheel pants 41 001.jpg
ID:	2095703   Click image for larger version
Name:	m_Wheel pants 41 002.jpg
ID:	2095704   Click image for larger version
Name:	m_Wheel pants 41 003.jpg
ID:	2095705   Click image for larger version
Name:	m_Wheel pants 41 004.jpg
ID:	2095706   Click image for larger version
Name:	m_Wheel pants 41 005.jpg
Old 05-13-2015, 06:13 PM
  #337
acerc
acerc's Avatar
I haven't said it lately so here goes, "You are awesome"!
Old 05-13-2015, 07:12 PM
  #338
Melchizedek
Aw Shucks,
Kevin
Old 05-14-2015, 01:03 AM
  #339
stevegauth30
Well if that aint the pot calling the kettle black. Lol.
Old 05-14-2015, 05:12 AM
  #340
FlyerInOKC
FlyerInOKC's Avatar
I agree with Robert and Steve!
Old 05-16-2015, 06:04 AM
  #341
Melchizedek
I had been waiting all week (with trepidation) to lay up the cowl.
Time frame on Sat/Sun was going to be iffy. This was not something I wanted to be rushed or interrupted.
So I thought nobody ever needs me In the late PM early AM. So I went to work on it right after dinner. Finished up a t 3:15 AM.
When I got everything set up and started laying the glass. I was having difficulty getting the glass to lay in that tight crevice at the nose.
My first thought was, "this was going to be one giant mulligan !" (that's the rated "G" suitable for all audiences version). All positive vibes left the room and Capt Lucky was in the Bahamas on vacation.
This is when you have to think like Winston Churchill. "Never give up,Never surrender," So I pressed on.
Once I got the second layer of cloth down things felt a lot better and the negative vibes faded. Hope began to spring .
I started with the nose with quarter donut shaped cloth. Laying one quadrant at a time over lapping the edges. This ran about 2 inches up the side also. Then wrapped the wall with one continuous layer of cloth this overlapping the donuts at the nose. This completed the first layer.
I then laid 8 inch bands at 45 degrees from the opening all the way down covering every thing, all edges overlapping. Then did another layer of 1/4 donuts in the nose ring, then another complete wrap of the cowl wall.
Everything got 3 layers of 6 oz with extra where it overlapped.
This was the major blemish. Considering the trouble I had getting the cloth lay down here, I AM ELATED
A Little bondo will make this go away in short order. The rest of that edge is solid.
This cowl is huge !!!. The circumference is 48 inches.
The shoe is on top to give perspective. That is a size 10 shoe.
The front wring is stout as all get out. The rear opening is a little more flexible than I would like. I will probably run a band of CF around to opening to stiffen it up.
I am very happy with the result.
Kevin
Name:	m_We have Cowl 41 001.jpg
ID:	2096326   Click image for larger version
Name:	m_We have Cowl 41 002.jpg
ID:	2096327   Click image for larger version
Name:	m_We have Cowl 41 003.jpg
ID:	2096328   Click image for larger version
Name:	m_We have Cowl 41 004.jpg
ID:	2096329   Click image for larger version
Name:	m_We have Cowl 41 005.jpg
ID:	2096330   Click image for larger version
Name:	m_We have Cowl 41 006.jpg
ID:	2096331   Click image for larger version
Name:	m_We have Cowl 41 007.jpg
ID:	2096332   Click image for larger version
Name:	m_We have Cowl 41 008.jpg
Name:	m_We have Cowl 41 009.jpg
ID:	2096334   Click image for larger version
Name:	m_We have Cowl 41 010.jpg
ID:	2096335   Click image for larger version
Name:	m_We have Cowl 41 011.jpg
ID:	2096336   Click image for larger version
Name:	m_We have Cowl 41 013.jpg
Old 05-16-2015, 06:46 AM
  #342
acerc
acerc's Avatar
Looks fantastic Kevin. That little spot is easily filled.
Next time try putting a thick coat of resin in those hard corner/curves let it get tacky add another coat then start laying up the glass. I use a thickener on the first and second gel coat just for that reason.
Old 05-16-2015, 07:02 AM
  #343
stevegauth30
You make it look soooo easy. Well done. And on thr first try at that.
Old 05-16-2015, 07:15 AM
  #344
Melchizedek
Thank you Robert and Steve.
Steve, I struggled all the way through with outcome in doubt. Very thankful with the result.
Robert,
Yes, next time will deal with the crevices differently. I am learning a lot along the way.
I only used 1 gel coat. Didn't think to add another. Will put that in my tool box for next time.
Kevin
Old 05-16-2015, 07:15 PM
  #345
Rocketman612
My Feedback: (85)
Rocketman612's Avatar
Kevin,
Well done!!
I know what you mean when Capt Lucky goes for a smoke just when you need him. But, he came back and said Hey I knew you had this
Pete
Old 05-17-2015, 12:36 PM
  #346
Melchizedek
Thank You Pete,
As I said in my last post I thought the back of the cowl was a little to flexy.
So last night I put the cowl back in the mold and wrapped the inside opening with two layers of 2 inch wide CF.
In the 2nd pic the full weight of the cowl is being held by the rim. Almost no deflection.
I the CF cause it sets up stiffer than glass.
Kevin
Name:	m_Wheel pants 43 008.jpg
ID:	2096565   Click image for larger version
Name:	m_Wheel pants 43 009.jpg
Old 05-17-2015, 01:03 PM
  #347
Melchizedek
Went to work shaping the wheel pants today.
A big hat tip to Pete / Rocketman. The plans only have a front view and side view of the wheel pants.
He took the time to take some pics of his pants (top and bot view) and send them to me. Thank You Pete.
I made a front view profile template off the drawings. I then used a belt sander with 60 grit and a surform to rough shape them.
Using the template to check often to make sure to shape evenly and not over sand. I roughed them down until I had about a 1/4 inch left to remove then stopped. I then made a sanding block from template and sanded the top shape to profile.
Then used a sanding jig to sand the top profile to shape.
The bottom profile was shaped with a 1 inch round over with only 13/16 of the round over cutting. This gave the arched bottom shape.
I stopped the RO shy of the front and back and then tapered those parts in by sanding.
At this point I was beat. been sanding for about 6 hours. I was also overjoyed with how they looked.
Took a shower then sat down and took another look at the photos Pete sent. Oh Poo .
The noses are to blunt. The front profile and side profile are right but the noses should be more slender left to right.
More work needs to be done. Have about 10 hrs total so far in the pants.
Oh well, the heavy lifting is done. Should be short work to true them in. But not today.
Kevin
Name:	m_Wheel pants 43 002.jpg
ID:	2096569   Click image for larger version
Name:	m_Wheel pants 43 006.jpg
ID:	2096570   Click image for larger version
Name:	m_Wheel pants 43 007.jpg
ID:	2096571   Click image for larger version
Name:	m_Wheel pants 43 010.jpg
ID:	2096572   Click image for larger version
Name:	m_Wheel pants 43 026.jpg
ID:	2096573   Click image for larger version
Name:	m_Wheel pants 43 028.jpg
ID:	2096574   Click image for larger version
Name:	m_Wheel pants 43 034.jpg
ID:	2096575   Click image for larger version
Name:	m_Wheel pants 43 029.jpg
Name:	m_Wheel pants 43 030.jpg
ID:	2096577   Click image for larger version
Name:	m_Wheel pants 43 031.jpg
ID:	2096578   Click image for larger version
Name:	m_Wheel pants 43 032.jpg
ID:	2096579   Click image for larger version
Name:	m_Wheel pants 43 033.jpg
Old 05-17-2015, 02:19 PM
  #348
acerc
acerc's Avatar
Ohhh the joys of being a perfectionist, I love it!
Old 05-18-2015, 03:40 PM
  #349
Melchizedek
Yep, you nailed it Robert
Just could not leave it that way. You might agree when you see the pics.
Here is a top view of Pete's pants and a side view of the replica in the museum.
Now Wendell's cross section I think is a little wider proportionately than Pete's pant. I am going to stick with Wendell's cross section witch will preclude getting Pete's shape on the money. But the shape I had was far to blunt. Also if you look at the replica, that hub cap has a distinct turn in toward the front. My pant flattened out far to soon. The first pic below is the pant before alteration. It looks a little torpedic. The one next to it is after adjusting the plan view.
The difference is settle but distinct. As I am looking at it I might also tapper the tail sooner. Will ponder it
It is far easier to cut the plan view when all the edges are square. So after pondering it for a while I came up with a plan.
I cut a new profile out of 1/4 inch mdf. Then centered each spat over it and shimmed the spat so the datum line was level.
Then used the disc sander and a bright light to sand spat to new profile. Once the spat got ground down close to the template size I penciled the edge of the template and sanded the spat until the pencil was brushed off.
With the template it was easy to get them both symmetrical.
Once all the edge get feathered into each other It will look much better.
But not tonight.
Please opine if the shape looks amiss. Every time I look at it I get different conclusion.
Kevin
ID:	2097010   Click image for larger version
ID:	2097011   Click image for larger version
Name:	m_Wheel pants 43 027.jpg
ID:	2097012   Click image for larger version
Name:	m_Spat rework 44 002.jpg
ID:	2097013   Click image for larger version
Name:	m_Spat rework 44 001.jpg
ID:	2097014   Click image for larger version
Name:	m_Spat rework 44 003.jpg
ID:	2097015   Click image for larger version
Name:	m_Spat rework 44 004.jpg
ID:	2097016   Click image for larger version
Name:	m_Spat rework 44 005.jpg
Name:	m_Spat rework 44 008.jpg
ID:	2097019   Click image for larger version
Name:	m_Spat rework 44 009.jpg
Old 05-18-2015, 05:05 PM
  #350
acerc
acerc's Avatar
Shazaam!!!!
