WACO YMF
#5152
RE: WACO YMF
great thread...I just skimmed a good bit of it.
I am completing a Cox Pica 1.5 Waco YMF ARF this week, converting it to electric.
Am fixing a few of the scale sins to make it look a little better.
Can somone point me to the best available 1/5 vac formed 7 cylinder radial motor for detailing the cowl?
#5153
RE: WACO YMF
ORIGINAL: Thomas B
Bill, AMA 4720
WACO Brotherhood #1
#5154
RE: WACO YMF
Bill,
Tell Tom B how you built your faux Radial Engine, what vacumm molded cylinders, what diameter spray can for the crankcase, etc. to place inside the cowl. I know that Ken (khodges) used one of the resin molded dummy engines, but forgot which and where from.
#5155
RE: WACO YMF
ORIGINAL: Thomas B
Bill, AMA 4720
WACO Brotherhood #1
#5156
ON, CANADA
RE: WACO YMF
Thomas.................I posted the name of a company that makes dummy radials. Company name is WINGS MANUFACTURING
check them out.
Charles.
check them out.
Charles.
#5158
RE: WACO YMF
ORIGINAL: Mainer_Jim
What is the cowl diameter?
Jim
Jim
Bill, AMA 4720
WACO Brotherhood #1
#5159
RE: WACO YMF
ORIGINAL: Garthwood
check them out.
Charles.
check them out.
Charles.
Do you have a link to them?
Bill, AMA 4720
WACO Brotherhood #1
#5160
My Feedback: (19)
RE: WACO YMF
I was marveling at your imagineering, Bill, from the first time you showed me the photo of your plane cowl. I have an 11" dummy radial from one of my GeeBees made of resin, it's pretty heavy but it's very detailed, and it is for static display only. Yours is functional and light, and that's no small thing, especially considering that yours looks so great. When I build my scale Waco (of whatever size) I will likely not buy a radial engine for it, instead I'll use a good dummy facade, so I've watched yours with increasing interest. Beautiful job.
Here's where I got mine:
http://franktiano.com/scaleproductFrameset.htm
Garthwood, I'll check out wings mfg.
Jim
Jim
#5162
RE: WACO YMF
Bill, Jim and others,
Wing Manufacturing - http://www.wingmfg.com/index.html , I think the dummy engines listed are too small.
AeroTech Models - http://www.aerotechmodels.com/index.htm , has cast, 7 cylinder engines in 8†diameter. Expensive.
Williams Brothers - http://www.williamsbrothersmodelproducts.com/ , Has the best detailed engines, but no Jacobs or Continentals. Site also has some tips on making a crankcase and other detailing tips.
If you are building a Waco CTO, as the record setting, climb to altitude, NC 280W, “Question Markâ€, then you could be close with a Wm Bros Wright J-5 or Wasp engine as “Question Mark†had a Wright 975 E&F-2&3 engine
#5163
My Feedback: (19)
RE: WACO YMF
Here is the link to those tips from the Willaims Brothers website on building a crankcase, the guy did a great job. Wrong brand of radial, too bad, but a really nice job anyway, and he talks about mis-steps and solutions he found. Worth a look to get the creative juices flowing. I wonder if any of those scale detail cylinders they have there will match the WACO's engine cylinders. I put the link to their cylinder photos second, followed by the link to the list and prices.
http://www.williamsbrothersmodelprod...crankcase.html
Cylinder photos:
http://www.williamsbrothersmodelproducts.com/j5.jpg
List:
http://www.williamsbrothersmodelproducts.com/rc.html
Jim
Cylinder photos:
List:
Jim
#5165
RE: WACO YMF
Jim,
I have looked at adopting one of the Wm Bros Cylinder and coverting it to a Jacobs or Continental, but it would be more trouble than it worth at this point. I have written to Wm Bros and both engines are on the "To Do" list but making the molds is a long and difficult process. They are also trying to bring back many of the original parts from the original Wm Bros.
There any many differences between the Wright or P & W engines when compared to the Jacobs or Continental. The head fins and Rocker arm cover are just 2 of the major differences.
P1 – The P & W Cylinder by Wms. Bros. (front view)
P2 – Close up of an actual Jacobs engine #1 Cylinder, front view
P3 - The P & W Cylinder by Wms. Bros. (side view)
P4 - Close up of an actual Jacobs engine #1 Cylinder, top side view
#5166
RE: WACO YMF
ORIGINAL: skylarkmk1
Bill, AMA 4720
WACO Brotherhood #1
#5167
RE: WACO YMF
Jim
Jim
The cowl (white one with red blisters) is not one from Stan's. It is from an old Pica kit, and is ABS plastic. The blisters were cut out of the sheet of parts, and glued to the cowl, and the radius was done using polyester body putty. It is labor intensive, but still makes for a nice looking cowl. The latches were made from aluminum scrap, fitted to the holes that I drilled in the cowl. The parting line was done by shooting a couple of extra coats of primer over the exposed upper half of the cowl, with the bottom half being masked.
Bill, AMA 4720
WACO Brotherhood #1
#5168
RE: WACO YMF
Bill.
I am wondering about cooling for the engine and effect the heat from the engine will have on the plastic parts of the dummy engine.
What experience have you had with dummy engines installed. Will this be for static display only?
I don't remember reading if you are going to fly with it on.
Angel
B 58
Angel
B 58
#5169
RE: WACO YMF
You make a disk from light ply and it glues to the back of the dummy engine. Then you remove the wood from between the cylinders that you need airflow through, and access through. The baffle/dummy engine remain in place when flying. You want to control the air to the engine, and not just have a big old hole out front.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#5171
ON, CANADA
RE: WACO YMF
I think I only paid about $10, so I bought two of them. Fits just right in the Pica ABS cowl 1:6th. Good enough to cover all that open space. You'll need to have to trim out the ABS from the form. It comes with dowels, but I opted for the K&S 1/8 Tubing. The cut out cylinders were epoxed to the cowl. Before I expoxied them in I painted the dummy radials and fuel proofed the paint. I need to fuel proof it again as it is starting to run off when I used fuel with higher nitrometh. content. in the Saito .91s
Charles
WAC Brotherhood #87
Charles
WAC Brotherhood #87
#5172
RE: WACO YMF
I wish that Williams Brothers would come out with a scale Jacobs 7 cylinder dummy engine. That would fill the bill nicely.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#5173
RE: WACO YMF
Hi Guys,
Just a thought here, has anyone thought about blowing up the plans 150% ?? I would think that would put it at the perfect size for a 50-80cc engine. It should make it fairly easy to scale up the wood sizes accordingly. The only issue I see would be forming a new cowl and wheel pants. Does anyone have any thoughts or ideas about doing this??
Later!!
Anthony
Later!!
Anthony
#5174
RE: WACO YMF
Anthony,
I am working on blowing one up to quarter scale. It is a little more involved than just increasing the parts. There are additional stress loads, the wing loading changes (a bunch) and the power requirements change by a higher percentage than you would imagine. Looks as if this one would need something in the 50-60 cc range. Some of the structure will need to change by quite a bit, and some can actually stay the same dimension (ribs etc). I'll get it all worked out.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
#5175
ON, CANADA
RE: WACO YMF
Unless they have enough requests to make it worthwhile they won't do it. Best is to work around the problem.
Charles.
WACO Brotherhood #87
Charles.
