Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 07-12-2013, 09:11 AM
  #16601
FMBB
Default RE: WACO YMF
Hi Tmac,
quite interesting, the wing panels normally are close to one Kg each so your model is round about 21Kg with a 2 cyl. engine. That's ok taking into account what you have installed. If you add the difference to a 5 cyl Moki you will come out in between 23 to 24 kg which is in the average range.
Peter
Old 07-12-2013, 03:18 PM
  #16602
WacoNut
WacoNut's Avatar
tmac,
She will fly really good at that weight. Mine is well over 24kg all up weight. With that 150 up front she will pull thru some big loops without any issues.
Later!!
Anthony
Old 07-12-2013, 04:51 PM
  #16603
hopkimf
My Feedback: (56)
Tmac,
Added a couple sketches of what I put in words the other day .Still a little concerned over stiff legged version. First picture shows an assumed wheel load in black, a wire load in red, and a gear leg in green. Magnitude and direction of wheel load known. Direction of wire load known. Extend both to an intersection. Then draw green line for axle leg load from pivot point through intersection of other loads (line of action for axle load must go through intersection of other two, or there would be moments and it would not be stable). It''s now defined. Above right side is a graphical solution. Put vectors in tip to tail and scale off results. Simple and quick.
Second photo shows wire force lines of action plus spring line of action. Combine them per upper right for results.
One could argue putting in pinned ends yields the wrong result. Agree, but this is a close approximation. It's true the real axle leg resists bending somewhat, and the spring pin is in a hole and could bear against the side changing results. But this is a pretty simple ballpark check.
Regards,
Mike Hopkins
Waco Brotherhood # 132.
ID:	1899879   Click image for larger version
Old 07-12-2013, 06:57 PM
  #16604
tmac48
tmac48's Avatar
Nut, It would be good at that weight, but I'm not too concerned over the weight issue, it is what it is, however I do think once it is all together with the wings painted it will be closer to 25 kgs but there is plenty of wing area to handle it.
hopkimf it is all double dutch to me will be very interesting to see how your model handles the landings compared to mine, looking forward to that day.
Peter would you be able to set your model at the correct attitude ( top wing at minus 2 deg ) and then measure the center section at the center to give a reading at that point? Peter one point about the Alloy that you can consider is that it does take a lot less weight in paint than all that dope undercoat and paint it takes to obtain the same finish on the fabric.
Another shot with the fuel lines and front screen almost finished.
tmac
ID:	1899897   Click image for larger version
ID:	1899898   Click image for larger version
ID:	1899899   Click image for larger version
Old 07-12-2013, 07:49 PM
  #16605
WacoDream
WacoDream's Avatar
Beautiful build TMac!  It all has come out so nice. Really great work.  Your Waco shines
Old 07-12-2013, 08:31 PM
  #16606
DinoR
Peter...WACO has landed !
Arrived here on Wednesday but I was interstate until last night ( Friday) so started unpacking as soon as I got home..all safe and sound.
But man..you must read a lot of Newspapers mate
ID:	1899919   Click image for larger version
ID:	1899920   Click image for larger version
ID:	1899921   Click image for larger version
ID:	1899922   Click image for larger version
Old 07-12-2013, 08:51 PM
  #16607
tmac48
tmac48's Avatar
ORIGINAL: DinoR
and now let the fun begin.
tmac
Old 07-12-2013, 10:32 PM
  #16608
DinoR
Hi Terry
Yeah..just remember ..its all your fault
Build won't start till the New Year as the whole rear of the house that you can see in the photos is getting demolished. Somehow in the plans a new 'man cave' has made an appearance in the planning stage as well...designed around a certain plane
Peter, compliments on the build quality, I have a friend who just visited, he has built literally dozens of fibreglass bodied Kingfisher seaplanes in his modelling business...his comments on your fibreglass parts was ' these have the mark of someone that cares about what he builds and sells '..he pointed out a number of your techniques and attention to detail...I think the word obsessed was mentioned a few times but in a very positive way. If anyone is interested I can post some more pictures of Peters part packs and componentry...honestly the more you look the more impressed you become.
Dino
Old 07-12-2013, 11:08 PM
  #16609
Errol Levin
Errol Levin's Avatar
Tmac
With all those wires going up to the top wing, are you putting navigation lights in the top wing?
If you go to the site below, they make scale lights exactly like the full scale.
Got some for myself.
http://shop.rc-electronic.com/e-vend...&c=2033&p=2033
Regards
Errol #204
Old 07-12-2013, 11:35 PM
  #16610
tmac48
tmac48's Avatar
Errol, it is a little late in the build for me to do the lighting in the top wings, sure wish I had known about that site before now. It looks as if I should sell this model and start on another one ( only kidding ) Have you some pics of your build?
Photo of my landing lights.
Regards tmac.
Old 07-12-2013, 11:51 PM
  #16611
Errol Levin
tmac
What are all the wires going to your top wing for?
Also you don't have to electrify the lights if you install them. I am deliberating weather to electrify them or just have them as dummies because to electrify them involves a lot of intricate work dealing with tiny 3mm LED's, relays etc.
Also to get the power to my top wing presents a bit of a problem with regards to the diameter of the fuel tubes. My plane is quarter scale so the tube diameter will be very small. The only way will be to have the positive wire up one tube and the negative wire up the other with the electronics in one of the wings. Been driving myself mad trying to work out how to do this. Even thought about separate battery receiver etc. in one of the top wings.
Suggestions would be welcome from all the brothers.
My landing lights will be working lights.
Errol. #204
Old 07-13-2013, 01:08 AM
  #16612
tmac48
tmac48's Avatar
Errol, the only tubes that I have going to the top centre section is the fuel lines (3/16 th ) with the servo wires in them for the servos that operate the ailerons on the top wings. You could definitely run your lighting wires through 1/8 tubing (2 wires per side ) and use an ignition safety cut off swich to do the on/off, they just plug straight into your receiver. you do not have to use LEDs and relays KIS and use the lowest voltage old fashioned torch globes and disposable batteries that you can find. Don't forget PHOTOS PHOTOS PHOTOS.
Regards tmac
Old 07-13-2013, 01:27 AM
  #16613
FMBB
Hi Mike,
I do no understand your concern. If you add pivot points to the upper "corners" of the landing gear and at the lower attachment points of the center struts no moments will be counteracted respectively the loads counteracted by the "bending" solution will have to be counteracted by the main legs and the center struts thus transferring the loads to the center spring. This spring has now to transfer all the loads to the structure. In the bending version without any pivoting points you have moments (at both "pivoting" points) which help to reduce the load to the center spring. In case you may install the capability for pivoting the center spring has to be reinforced significantly.
Does this be of any help?
Peter
Old 07-13-2013, 01:43 AM
  #16614
FMBB
Hi Tmac,
wing panels are less than 1kg normally lower wings with servos and landing lights should be 0,95kg and upper wings round about 0,8kg. I will measure the AoA on my Waco at the center wing current design. My current Waco has Anti collision lights and a beacon. Voltage supply is by the rigging wires which works fine. It was a big issue to have all that wires installed. I have two pumps one for smoke and the second for fuel supply of the radial, two electronic switches one for the landing light on for the fuel pump. Five batteries one for the ignition system, one for the ACLs, beacon and smoke pump, one for the fuel pump and two for the two receiver. The biggest challenge is to get all these servo and beacon, ACL wires as far as possible away from each other and away from the antennas. Lots of work but now I am close to finish the wiring only elevator servos below the stab have to be connected to the system and than testing can be started. Hope every thing works fine.
Peter
Old 07-13-2013, 01:49 AM
  #16615
FMBB
Hi Dino,
thanks for the compliments, enjoy building. Good to hear that all arrived in good shape - long journey form Europe to Australia. The news paper we are using to pad the kits is our daily newspaper. You cannot read all you have to have a brief overview and to prioritize, but it still takes time to read the articles I am interested in.
Peter
Waco Brother #170
Old 07-13-2013, 02:58 AM
  #16616
hopkimf
My Feedback: (56)
ORIGINAL: FMBB
Hi Mike,
I do no understand your concern. If you add pivot points to the upper ''corners'' of the landing gear and at the lower attachment points of the center struts no moments will be counteracted respectively the loads counteracted by the ''bending'' solution will have to be counteracted by the main legs and the center struts thus transferring the loads to the center spring. This spring has now to transfer all the loads to the structure. In the bending version without any pivoting points you have moments (at both ''pivoting'' points) which help to reduce the load to the center spring. In case you may install the capability for pivoting the center spring has to be reinforced significantly.
Peter
Peter,
No concern for design as is. When I referred to 'stiff legged' design, I was meaning one with no spring in center. Put pins in corners to get a simple graphical picture of forces and directions. Academic exercise only.
Regards,
Mike Hopkins
Old 07-13-2013, 03:15 AM
  #16617
FMBB
Hi Mike,
ok understood, would work with pins in corners as said but spring in the center would have to be reinforced significantly may be also counter act structure in the fuselage.
Peter
Old 07-13-2013, 04:09 AM
  #16618
mogman
mogman's Avatar
ORIGINAL: DinoR
Hi Terry
Peter, compliments on the build quality, I have a friend who just visited, he has built literally dozens of fibreglass bodied Kingfisher seaplanes .......
Dino
That wouldn't be Tim Nolan would it? If so, I met him years ago at the float fly at Shuswap Lake, here in B.C. I had the yellow 1/2 scale Spacewalker on floats.
Cheers,
Dave.
Old 07-13-2013, 04:52 AM
  #16619
DinoR
Hi Mogman
Yep sure is Tim...he is actually heading back to the Shuswap float fly in a few weeks time ! ..I was thinking about it but decided to buy a certain plane instead
Old 07-13-2013, 05:47 AM
  #16620
FMBB
Hi Tmac,
the AoA difference of the outer wing panels to the inner is round about 1 degrees. So if the upper outer panels are set on minus 2 the center section should be minus 1 degrees.
Peter
Old 07-13-2013, 07:56 AM
  #16621
Errol Levin
Hi Peter
Can you explain the "voltage supply is by the rigging wires". Do you mean that the rigging wires are actually carrying current.
Regards
Errol. #204
Old 07-13-2013, 08:15 AM
  #16622
Errol Levin
Tmac
I think 1/8 tubing would be too thick for 1/4 scale. Do you know what the diameter of the full size fuel lines is?
Regards
Errol. # 204
Old 07-13-2013, 02:28 PM
  #16623
FMBB
Hi Errol,
yes Sir, rigging wires are carrying current.
Peter
Old 07-13-2013, 03:44 PM
  #16624
tmac48
tmac48's Avatar
ORIGINAL: Errol Levin
Tmac
Regards
Errol. # 204
NO, I have no idea ,infact I have asked that question myself but no luck. I can say that 3/16 looks ok on 1/3 model and I needed that size to run the wires anyway, so I would think 1/8 would not look out of place on 1/4 model, at the end of the day it is your call and sometimes we just have to compromise on things.
tmac.
Old 07-14-2013, 03:00 AM
  #16625
DinoR
Like some others I have been inspired by TMACs use of Aluminium for his panels and will be trying to follow suit eventually. I was reading the EAAs Experimenter magazine and came across this small point below re marking aluminium...most of you may already know this but it was news to me...
Use a Sharpie Marker on Aluminum Planes
Don’t use a pencil!
By Gary Baker
If you have worked on an aluminum airplane, you have probably heard that you should not use a pencil to mark the aluminum parts. That’s because the carbon graphite will get into the crevices inherent in the aluminum surface.The combination of carbon and aluminum in contact
with one another will set up galvanic corrosion that will not become evident for some time, but it will become evident. The corrosion can only be stopped by removing a few thousandths of aluminum.Van’s Aircraft and other kit manufacturers recommend that a Sharpie be used on aluminum parts instead of a pencil. The Sharpie can be removed with lacquer thinner or enamel cleaner prior to priming or painting, and it will not damage
the material. Lines on aluminum marked by a Sharpie can also be left on the material before priming, if they are needed for reference and the material will not be painted later. If the material will be painted, the Sharpie lines need to be removed first. The lines will show through the primer and paint!
Here is an illustration of Sharpie bleed-through. The lines were drawn on the forward side of the vertical stabilizer spar of my RV-6 after priming. This area of the spar lies against the fuselage bulkhead and will not be seen, so I did not bother to clean off the lines. The lines are bleeding
through fi ve coats of primer and white paint. So, make sure to clean off those Sharpie pen marks, if you don’t want them to be seen!
