Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 07-17-2013, 09:26 AM
  #16651
FMBB
Default RE: WACO YMF
Hi Mike,
that's looking much better now.
Peter Waco brotherhood #170
Old 07-21-2013, 06:21 PM
  #16652
airplanegeek
airplanegeek's Avatar
Had the waco out today, and had a little misshap. I have Robart wheels and they are just way to soft. I landed in long grass and she ended up on her back. Minor wing damage to repair. Stickbuilders spar mod would have prevented the damage I took. Any wheel suggestions out there for the best wheels to use. I was thinking of just going with dave brown foam wheels. What do you guys use?
Old 07-22-2013, 12:55 AM
  #16653
Stickbuilder
Stickbuilder's Avatar
I use Sullivan with aluminum wheels.
Bill, Waco Brother #1
Old 07-25-2013, 06:14 PM
  #16654
hopkimf
My Feedback: (56)
Waco YMF Barth 1/3
I got lots of good input on servos, etc from members. Then I took the cheap and dirty approach. Hitec HS-805BB for elevator and rudder. Located them in turtle deck. Elevator servo mounted upright and connected to an arrow shaft with 4-40 rod and on the back end of arrow shaft to elevator halves with 4-40 rods to each. Glued 4-40 rods to arrow shaft with JB Weld. For rudder and tail wheel, I mounted the servo upside down on same rails used for elevator servo. Will run pull-pull cables. No walking beam used. I understand the benefit but think I can get away without it. Photos included. Undecided on gluing in servo rails or making them bolt on. Baggage hatch will allow access from top. From underside access possible behind pilot. Not as clean as I would like.
Working stringers. Decided to make a drawing of former notches using velum right over the plan and cutting it out and putting it on former. Easier for me than trying to measure and better than guessing. So far pretty straight but not perfect.
For power, I went cheap. Just ordered a new Evolution 152GX, a 152cc twin on EBAY. I believe it is from a Czech manufacturer and know little about it except that it was offered from Horizon and withdrawn. Now looking for mufflers.
Mike Hopkins
Waco Brotherhood # 132
ID:	1903965   Click image for larger version
ID:	1903966   Click image for larger version
ID:	1903967   Click image for larger version
Old 07-25-2013, 11:03 PM
  #16655
Errol Levin
Errol Levin's Avatar
Mike
Putting a servo upside down is going to be very difficult to access through the cockpit.
Have a look at my setup for my elevator servos. They will be very easy to access through the luggage compartment door.
The servo tray is also completely removable.
Just a suggestion.
ERROL #204
ID:	1903997   Click image for larger version
ID:	1903998   Click image for larger version
Old 07-25-2013, 11:52 PM
  #16656
Errol Levin
tmac48
You requested some pictures.
Here are a couple. I haven't done much lately. I have painted the fuse with 2K paint with 10% plasticiser added to avoid the paint crazing on the fabric.
I am busy getting ready to cover and paint the wings. I am deliberating the navigation light issue prior to covering them.
Not much done lately I am afraid, but as they say slowly, slowly, catch a monkey.
Regards
ERROL #204
Old 07-26-2013, 12:09 AM
  #16657
Errol Levin
ORIGINAL: Errol Levin
tmac48
Regards
ERROL #204
Hi tmac
Sorry, for some reason the pictures weren't uploaded, and it won't allow me to edit the post.
I will try again.
ERROL
ID:	1904000   Click image for larger version
ID:	1904001   Click image for larger version
ID:	1904002   Click image for larger version
ID:	1904003   Click image for larger version
ID:	1904004   Click image for larger version
ID:	1904005   Click image for larger version
Old 07-26-2013, 01:32 AM
  #16658
tmac48
tmac48's Avatar
Errol, she is looking just great, building skills are showing up real nice. Did you find it took a lot of work and subsequently weight to fill the weave in the Koverall?
tmac.
Old 07-26-2013, 02:59 AM
  #16659
Errol Levin
Hi Terry
I am using Solartex It's a wonderful product to use. Works like a charm.
The weave is still very visible. I will give it a light sand then another light undercoat and then sand again and then two top coats. There shouldn't be a weight issue.
I am using a Saito 5 cylinder radial which should haul it around pretty comfortably.
Regards
ERROL #204
Old 07-26-2013, 03:02 AM
  #16660
hopkimf
My Feedback: (56)
Mike
Just a suggestion.
ERROL #204
Errol,
Thanks. Agree. My thoughts when I roughed it in were to have minimum number of pieces and a straight shot back from servos to elevator and rudder. But it does make the rudder servo horn and cable adjustments inaccessible once servo package is dropped in place. There is a way to allow the servo package to be bolted in place from open baggage door (which I have not come up with yet- just a bunch of stringers in the way now). Rudder adjustments would need to be made from back connections. Need to think more about it.
Mike Hopkins
Waco # 132
Old 07-31-2013, 09:13 AM
  #16661
rccrasher65
My Feedback: (35)
Errol, sweet looking bird, Great job.
Old 07-31-2013, 04:05 PM
  #16662
chuck l
My Feedback: (17)
The third scale Barth Waco is a BIG bird. I'm getting anxious to get working on it this fall when we get back to Florida. This summer, once we get done with all the work associated with moving into a town home, I will cover/paint the rudder, elevators, and cowl since I was able to squeeze them in the car this spring.
Chuck
Old 08-06-2013, 07:27 PM
  #16663
rccrasher65
My Feedback: (35)
Has anyone been on here since the upgrade. Looks ok, a little different, we'll see I guess. I tried an email link and it didn't work. No new posts as of yet, to try lets see what happens.
Old 08-07-2013, 03:51 AM
  #16664
mrdhud
My Feedback: (48)
mrdhud's Avatar
Hey George,
I’ve been trying for days with no luck. Just figured how to get back on. All my favorites are no longer working and I don’t see any of the pictures any more. On page 1 the index is no longer working. I can’t help to think about the saying (if it ant broke don’t fix it)
Old 08-07-2013, 09:13 AM
  #16665
rccrasher65
My Feedback: (35)
Originally Posted by mrdhud
Hey George,
Dan, I just use the basic of things here on RCU. I just received your post via email, so thats working. I had to go on from page one, Bills first post of this thread, because the old email link from last week did not work. Now I have your post and I clicked it, and it took me right here. I guess all is well. I don't know much about the pictures. I only placed pic of my items I sold, but will be starting my build soon, so I have alot to learn. I do hope that all is not lost that does not work so far. I guess we'll all have to re-learn. I do agree with you though, if not broke don't fix, but alot of folks think RCU is a big mess anyway so what ever they decide to do can only improve over time, we must all exercise some patience here, and give these tech's a chance. I think they do a pretty good job, after all they have a huge task to preserve all the info, and pics, threads on here. most would have just changed, and started a new system without all the old info. Best of luck, George
Old 08-07-2013, 04:52 PM
  #16666
jymster
My Feedback: (9)
jymster's Avatar
Hi guys, my first comment about the new site would be that where are the thumbnail pics now?!! We need to see the thumbnails of the pics on the post, and not have to click on each individual photo, which then opens a popup window for each image. i don't like this new feature, as it is a step backwards.
Old 08-08-2013, 03:35 PM
  #16667
WacoNut
WacoNut's Avatar
I am seeing the thumbnails. It seems some are having compatibility issues with the new server.
It may take them a few to get all the bugs worked out. So far I find it a bit laborious just trying to navigate around. Also I cannot stay logged in. If I am off for more than a few minutes I have to login again.
Later!!
Anthony
Old 08-08-2013, 03:48 PM
  #16668
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
There was a glitch when the indexing for all the pictures was done during the migration. The programmers have fixed the glitch and then yesterday they restarted the indexing of all the attachments to RCU posts, which include uploaded pictures. With over 20 million attached images this is going to take some time to accomplish. It was started late yesterday and they tell me it could take 24-48 hours (hopefully) to finish. Once the re-index is complete the thumbnails for all the images should be back in place.
Ken
Old 08-08-2013, 03:56 PM
  #16669
jymster
My Feedback: (9)
jymster's Avatar
Thanks Ken, I'm also now seeing thumbnails. However, when I log in it takes me to my account page, rather than to the page I was just looking at. Also does not stay logged in, as before.
James.
Old 08-08-2013, 05:06 PM
  #16670
RCKen
My Feedback: (9)
RCKen's Avatar
James.
They are still working on the login issues. Hopefully they'll get it all worked out before too long!!!!
Ken
Old 08-08-2013, 07:20 PM
  #16671
chuck l
My Feedback: (17)
Where is the best place to buy stencils for painting the fuselage side stripes and cowl bumps for a third scale Waco?
Chuck
Old 08-09-2013, 12:45 PM
  #16672
WacoNut
WacoNut's Avatar
Chuck,
I have used Getstencil.com in the past when Gary Siebert owned the business. He sold that portion of the business a few years ago. The mask were very easy to work with and did a great job. I believe they are still using the same materials that Gary used.
Later!!
Anthony
Old 08-10-2013, 07:20 PM
  #16673
Stickbuilder
I don't know about anyone else, but I hate what they have done to this site. All my preferences are gone and I can't begin to understand how to reconfigure my preferences.
Old 08-11-2013, 09:28 AM
  #16674
WacoNut
WacoNut's Avatar
I agree, this site is a TPITA now. It used to be the most user friendly forum out there.
Just going thru the Login is a PITA and you can't stay logged in. Hopefully they correct these issues pretty quick. I will have a new build going soon and if they do not fix the issues I will post elsewhere.
Later!!
Anthony
Old 08-11-2013, 10:45 AM
  #16675
acerc
acerc's Avatar
Are you guys referring to your subscribed threads. If so, at the top of the page in the column that has your avatar click on settings, scroll down just a little on the left is a my subscriptions box, in it is subscriptions-click it. That should be your subscribed threads, but it can post one of two ways first is the subscriptions that have had post. For all of your threads irregardless of post just click subscriptions again
