Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
 Using different transmitters >
Helimax This is for all your Helimax questions and comments.
Old 03-27-2007 | 07:27 PM
Default Using different transmitters
I'm sure this has been gone over a million times so please excuse my ignorance. I have tried to use my Futaba radio for my axe and have no luck. Any luck useing non-stock transmitters with the axe reciever? Or am I an idiot for even trying?? Thanks again Storm
Old 03-27-2007 | 08:34 PM
Default RE: Using different transmitters
Yes .. i also have a Futaba radio and have no problems .. its 6 channel
Old 03-27-2007 | 08:49 PM
I'm using my 9C and so far no problems. Are you trying to use a non-Helimax Crystal in the receiver? I'm using the synth module in my 9C so I just tuned it to the same channel.
Old 03-27-2007 | 09:04 PM
I swapped RX Crystal on the heli with the Futaba RX Crystal and set the radio .. I used these setting from QUICKSTER47 ( THX again )
http://www.rcuniverse.com/forum/m_54...tm.htm#5451413
Old 03-28-2007 | 11:11 AM
I had the same problem with my blade cp. I used the xtal from the reciever that came with the radio and swapped it for the xtal in the 4in1 and it didn't work.
called the lhs and the xtal in the reciever that comes with the radio is considered a "long" xtal. I picked up the short style xtal on the same channel and all was well.
futaba 7chp
This could be the problem you are seeing.
Old 03-28-2007 | 02:25 PM
Thanks for the responses, I am trying to use a 8UAP. At least I think thats the name, its not in front of me. I just grabbed a crystal I had laying around and tried it in the axe board. No luck with that. I will check some others I have. I have never heard of long and short crystals. Will see what I can find. Thanks Again.
Old 03-28-2007 | 02:39 PM
Well it took about 2 minutes on Tower site to discover there are indeed long and short crystals. I happen to have a short at home that I had just ordered for another project, so I will give it a try. Thanks Storm
Old 03-28-2007 | 06:24 PM
Well the short crystal worked, now I am going to try to use the set up posted by QUICKSTER47 and see if I can get this bad boy settled down a bit. Thanks to all who took time to respond! Storm
Old 03-28-2007 | 08:01 PM
Be careful with the Throttle
