Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Intermitant blue module light when servos are use
Old 11-18-2010 | 07:19 PM
Default Intermitant blue module light when servos are use
The blue light on my Hitec 2.4 module lights on and off and beeps when I apply the aileron servos All other servos are ok and no light.The aileron servos are digital. I have a fully charged battery pack ( ni cads) 5 cell 1800 ma. The batteries test ok on my load tester. Any suggestions?
Old 11-18-2010 | 07:44 PM
coriolan's Avatar
Default RE: Intermitant blue module light when servos are use
Sound familiar!
http://www.rcuniverse.com/forum/m_9932022/tm.htm
Old 11-18-2010 | 07:52 PM
ORIGINAL: jwgn The blue light on my Hitec 2.4 module lights on and off and beeps when I apply the aileron servos All other servos are ok and no light.The aileron servos are digital. I have a fully charged battery pack ( ni cads) 5 cell 1800 ma. The batteries test ok on my load tester. Any suggestions?
What voltagelevel is theSpectra Module set at?
<span style="font-size: x-small"><font color="#22229c">Low Battery Warnings - Minimum Settings</font></span><span style="font-size: x-small"> Recommended for both the Aurora TX &amp; Spectra 2.4GHz module - which are set separately.
</span>if at the recommended 4.5V, this indicates that:
. RX battery cannot handle the current requirements of yourtotal servos, many load testers cannot test NiMH or A123.
<span style="font-size: x-small">Faulty leads or connections.
AFHSS - Warning Beeps Aurora &amp; Spectra Pro. - meanings
LED Status Card - <font size="1">What the colours/combinations are indicating.
</font><span style="font-size: x-small">
Aurora A9, Spectra Pro &amp; Optima - FAQ &amp; Undocumented Features </span><span style="font-size: smaller">- Mixes, Setups, Tips.
<span style="font-size: x-small">Regards
Alan T.
Alan's Hobby, Model &amp; RC FAQ Web Links
</span></span></span>
Old 11-18-2010 | 08:53 PM
I have an Eclipse transmitter. How do I reprogram the module? Do I need a ubs cable? I will be upgrading batteries for my receiver just to be safe.
Old 11-18-2010 | 10:56 PM
ORIGINAL: jwgn I have an Eclipse transmitter. How do I reprogram the module? Do I need a ubs cable? I will be upgrading batteries for my receiver just to be safe.
Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to install &amp; Use Instructions <font size="1">(with screenshots)</font>.
However, the module supplied separately should have had the factory auto detect 4/5cell saved at 4.5v.
What chemistry are the batteries?
Optima Transceiver (RX) - A123 2S Cell - Low Battery Warning <font size="1">not adjustable V1.04&lt;06. Setting Voltage Alerts V1.07. <font color="#ff0000">Warning regarding use of Eneloop &amp; A123 2S as RX batteries.</font></font>
Optima Transceiver (RX) - Battery set up for Nitro/Gas models #1 <font size="1">caution re NiMH.</font>
Optima Transceiver (RX) - Battery set up for Nitro/Gas models #2 <font size="1">caution re NiMH.</font>
Alan T.
