Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Flaps Function
Old 08-24-2005 | 07:30 AM
Default Flaps Function
OK Guys;
I have been reading my manual (I dangerous thing to do!) on the features of the Hitec Eclipse 7.
I am attempting to have a single switch activate the flaperons. So far I have found the “Land” function that drops the flaperons and adjusts the elevator (channel 6) and I have found the flap operation from the VR1 knob (I hate the idea of twisting a knob during landing).
However; what I was looking for was a single function switch that would just drop the flaperons . . . Am I going to have to use the ‘LAND’ function with the elevator change set to zero? Or is there something that I have missed?
Old 08-25-2005 | 09:38 AM
My Feedback: (31)
Default RE: Flaps Function
I don't recall if Flaps can be had with a toggle switch, maybe a free mix can be assigned to this function. I'll have to check the manual. In any event the LANDING function is fine to deploy flaps; typically some elevator is used to compensate for pitch when flaps are dropped. But you can zero the elevator function without worry if you prefer.
Old 12-08-2005 | 10:55 PM
i will monitor this forum.... I have the same question.... before I was using a Futaba with a 3 position switch that worked.... I hope this new Eclip 7 will do the same....
