Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
optic 6 elevator set up question
Old 10-03-2005 | 05:35 PM
Default optic 6 elevator set up question
Hello Can some one help me set up my extra 300s elevator I’m Required to use 2 servos (one each halves) and this would be my first. Model that require that. (What function should I use) I’m using an optic 6 from Hitec.
Old 10-03-2005 | 06:27 PM
My Feedback: (31)
Default RE: optic 6 elevator set up question
Activate AILV.
Connect the servos to channels 2 & 5.
Use the cursor <> to move the screen to the % +100. Note at the top arrows above and below channel indicator 1, 2 & 5 as you scroll with the cursor.
When the arrow is above 1 and below 2, zero the percentage with the - data button. Use the cursor and move to above 1 and below 5 again zero out the percentage. This prevents the aileron stick form interacting with elevator function.
You'll need to go the EPA screen ad set each percentage for channel 2 & 5 equally. Be sure and move the elevator stick up and down while changing percentages for changing the throw in both directions.
Old 10-03-2005 | 07:31 PM
thank you I will try it right now..
Old 10-03-2005 | 07:43 PM
mglavin I realy thank you for this.. you made my nite compleate....
Old 10-03-2005 | 07:45 PM
My Feedback: (31)
Old 10-04-2005 | 12:24 AM
mglavin..... Do you know how to set up using 2 reciver battery Pack on my plane . Im curently using 4 hitec digital servo and 1 sandard. I bought 2 (6volt 1100mah Nimh) I just want to make sure I have Plenty of battery power. I'm using Hitec Supreme 8-Channel FM Receiver
Old 10-04-2005 | 12:42 AM
My Feedback: (31)
Both batteries each with their own switch plugged directly into the RX with any available channel ports. All the channel ports share the power buss, so its all good.
If your short channel ports it’s permissible to use a wye with one end to a servo and the latter to the switch power pigtail.
Old 10-04-2005 | 12:49 AM
Thank you .
