Hitec Eclipse Programing
I am in the process of setting up an EZ Glider elec. RR, and would like to have ,
1: Spoilerons
2: Throttle proportional on the stick ( Is this possible )
Manual says motor controlled with gear switch on channel 3 ( On/Off )
Using an Electron 6 rx, Eclipse 7 tx
Aloha, Les
1: Spoilerons
Aloha, Les
ORIGINAL: Leslie Ward I am in the process of setting up an EZ Glider elec. RR, and would like to have , 1: Spoilerons 2: Throttle proportional on the stick ( Is this possible )
Manual says motor controlled with gear switch on channel 3 ( On/Off ) Using an Electron 6 rx, Eclipse 7 tx Aloha, Les
Plug ESC into Ch3 = normal throttle function and ailerons/spoilerons as "Flapperons" as per page 26 of your manual - use the "UP" = spoilerons.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
