PICS OF YOUR SAVAGES !!
#3552
RE: PICS OF YOUR SAVAGES !!
i finaly did it! my savage is now bigger! i used an LST/MGT sized body for the extended chassis. this is my first atempt at stripeing, there are a few bad spots but nothing noticeable let know which set of wheels you guys like best, the first is the 40series moabs then the claw dawgs and then dirt bonz.
#3553
ORIGINAL: ravenlunatic
#3555
Thanks Sportsfans, if you got the LST size it'll fit great! post pics when you get it painted!
#3558
ORIGINAL: donoisten
Here is my 1st. rc truck. Have been into airplanes for years. but this truck is a blast for my winter of not flying.
I'm green with envy!
#3561
TX
MTBoy: the 73 bronco shell from HPI has taken a considerable beating....even after it's broken it's still standing up to a lot of abuse.....the only thing I'm going to do on my next one is put a bit more reinforcement on the rear before I start bashing with it....
#3562
MT
Thanks dhyde,
I'll have to try it. How do you reinforce it? Both of mine broke in the back. Bad landings[&o]
Hoping the lhs has a new tank so I can go to the skate park.
#3563
TX
I reinforced the top of the "cab" with a piece of alumimum that I glued in with clear silicone (goes right ontop of my roll cage, keeps the truck from destroying the body on a hard hit) I'm gonna do the same in the back, make a bracket that goes at the mounting spot for the posts and possibly fill the "roll bars" and such in the body with silicone and after it sets up mold it over with a bit of custom fiberglass work.....to date I've destroyed 3 bodies, and at $35 a piece plus paint, it's getting expensive to have to do it each and every time, so I'm gonna see what I can do for reinforcing the next one before I run it......
#3564
MT
I like your idea to reinforce. I'm working on buying my second one. My stock body seems to be the strongest so far. I thought when I landed I only cracked the tank but after further look.. My body is trashed in the back and I broke the back mount for the tank.[:@] Sucks becouse I just got back from the lhs and went to put on the tank to see the mount broke...
#3565
TX
ORIGINAL: Rudeboy
Well, I didn't know that there was an actual Jeep Rubicon... But Whipnets jeep looks like a spitting image of the limited edition Jeep Rubicon "Tomb Raider"
ORIGINAL: dhyde79
uh....I thought the inspiration came from the actual jeep rubicon? it's the decked out heavier duty offroad capable version of the wrangler.....(won awards for the new transfer case design and whatnot)
I was not aware of the Rubicon in Tomb Raider, but after looking it up, I can certainly see where those comments came from. Colorwise, it's right on.
Thanks again guys!
#3566
TX
by the way, an easy way to reinforce the inside of the bodies is duct tape or gorilla tape, either one will work, I opted for gorilla cause it's thicker and the adhesive's considerably stronger. I'll get a pic of my grean meanie and post it as soon as I can.
#3567
just got new shocks for me svage they are th lst ones with innovatoin rc conversion kit shock oil is a bit rubbish going to change as soon as possible
#3568
TX
okay guys its been a while but now its getting cold over here in texas... soo i think i want to get my savage back into working order... i believe my stock engine is TOAST... but im not quite sure which one to go with to replace it... what are some of ya'lls recomendations for that??? i'm not sure if i should go with o.s. or something else... plz help!!! lol what are ya'lls favorite engines... and why?? lol
#3572
Here they are with some truggies to spice it up a bit
Savage X 4.6 and the Hyper (just broken in) are mine ]
friends Savage X 4.1 and his red/black Thunder Tiger ST1
other friends white/purple Thunder Tiger ST1
#3573
MT
Sweet pics Rican. Looks like you have the best of both bashing and racing. Have fun and thank for sharring.... Now lets see some action pics
#3575
ok, if this works here it is.
Savage X
-Axial .28
-Robinson racing spur
-16T vented clutch
-dual stainless disc breaks
-high torque servo
-hump pack
-Pro-line Big Joes
-Axial beadlocks
-custom back half roll cage
Savage X
-Axial .28
-16T vented clutch
-high torque servo
-hump pack
-Pro-line Big Joes
-Axial beadlocks
