Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Controller Setup for 3d Helicopter
Old 04-08-2006 | 04:48 PM
Default Controller Setup for 3d Helicopter
Hi can someone explain the detailed procedure for setting up the controller for inverted Heli flight?
Thx
Old 04-09-2006 | 02:22 PM
Default RE: Controller Setup for 3d Helicopter
Ye, real simple
set it up the same as for a plane, and add the autorotation switch to the mix.
You dont need to have the tx on heli, or any mixes
Regards
Martin
Old 04-10-2006 | 07:18 AM
Thx Martin.
Not sure I understand your instruction. How do you add the autorotation mix to the controller adjstments properties?
thx
Old 04-10-2006 | 12:26 PM
Hi
Have you managed to get the controler working? working on a plane?
Once you have calibrated, go to controls, double click on the one you are using, and look for auto-rotation, if you have a tx with more than 4 channels, move the button on and off that you want autorotation on, and put the dot in line with the red bar that moves when you do that and also in line with autorotation.
if you have a 4 channel tx, you will have to use a number on the key board in stead of a switch
there you go
regards
Martn
