Graphics
UT
How do you guys put on your vinal graphics...?? I hate when i go to put them on and just touches the surface and you go to pick it back up and it rips! blah.. Do you use the "windex" method or what?
MD
If you ordered them from Kirbys Kustom Graphics they send some instructions on how to put them correctly!! I recently ordered some, but never read them! [&o][&o] I think I still have them somewhere!
Let me know, I can make a copy and send them to you!
Keep flying,
Alex
Let me know, I can make a copy and send them to you! Keep flying,
Alex
Chris,
The "windex" method works just fine. I picked up a small "squeegee" from Sign-O-Rama but you can use any straight edge that isn't sharp to squeeze out the windex once the graphic is down.
Dave
Dave
Msot of the good quality vinyl graphics come in a 3 layer sheet.
The actual graphic is in the middle.
Take the 3 layered graphic and set it into position. Make a Hinge out of masking by taping the top edge of the graphic to the plane.
Fold the graphic up by the hinge, remove the back part exposing the sticky side of the graphic and then just roll the graphic into place. It will be right where you want since you taped it in place with the hinge. Also, by rolling it into position you should have no air bubbles.
UT
Thanks guys, will try that... and no these are not from Kirby's ...\
Ill try that then... o and this is for the Radio Craft Extra .... its almost done, im hopping to test it this weekend.
My Feedback: (28)
TX
If you are still looking for an answer, try soap and water. Add a drop of dish detergent in a spray bottle of water. Spray both surfaces, place your graphic on the aircraft, move it around to where you want it . Take a squeeze and remove as much water as you can, allow it to dry in the sunlight if possible, wait about 10 - 24 hours before moving the graphics. Once completely dry it will not move.
The soap and water trick is also use to put tint on car windows. It works great.
Good luck.............
My Feedback: (12)
MD
While all the methods will work I have found the commercially available application fluids to be superior. If you need to reposition it is no problem. Window cleaner, soap, etc, will work however there are times it will stick and you will have the problem mentioned (ripping). This can be really an advantage when working on a 12' sign or a 40% aircraft. I try to assist the installation for the first try as it's new techniques. Most things aren't difficult once we learn the process.
Hope to see you at some NE IMAC meets soon. I loved the 40% photos and hope to have mine in the air soon.
EXCAP232
EXCAP232
UT
Hey All, thanks much for all the great info !! We went with Wayne's tape method and all has worked out fine - it looks real sweet / awesome / YOW ...... Want to give a super HUGE THANKS to Mr. Rich Fletcher who was so very kind to lend us his vinyl graphic machine with all the vinyl, etc... Rich - YOU ARE DA MAN !!!!!!!!! THANKS AGAIN !!!!!!! Now we have another Q for all of ya. Is it needed or recomended to apply wax or ???? over the graphics to protect and help then stay attached. Hey EXCAP , can you make the Milford meet ? If not we will see you at the CAPI then ! Keep havin FUN !! Rod & Chris [8D]
PS, we will post some more pics soon - after we get the pants on it !
My Feedback: (38)
I used a touch of liquid soap with water in a spray bottle when I put on my sukhoi wing graphics, I put the graphic on the wet wing, squegee'd it really good, and left it for a while, coming back to it speezing out a bit more water, once it dried enough I could pull the transfer paper off. Came out perfect no bubbles, but typically I do it without the soapy water.
