Reload this Page >
Platt Zero Build Thread
Old 09-30-2012, 05:13 PM
  #51
[email protected]
Default RE: Platt Zero Build Thread
Wow... maybe I need these instead?  http://www.sierragiant.com/prod05.html
Old 09-30-2012, 07:40 PM
  #52
Nergall
I've the tape and primer for panel lines mentioned before. How does that work?
Old 09-30-2012, 08:19 PM
  #53
rlemaster
rlemaster's Avatar
Hi Nergall,
Where-ever you have panel lines (flush panel lines, overlapping is a bit different), you apply the chart-pak tape along those lines. It's a little tricky to work with at first, but just take your time and make sure you have a very sharp blade (I use a scalpel). As you get to each corner, just go a little past it and trim it with the knife. Note that you don't want to cross the tape. Where tape meets (like in a + for example), cut to each side of one of the lines so that the tape is level and flush. I didn't do this my first time and it caused problems when I later went to sand and remove the tape. It can also cause the primer to get up under the tape and cause it to react with the adhesive and bubble up a bit.
Once the tape is applied, just shoot the primer over it and overlap a couple of inches or so. Note that the overlap will pretty much happen on it's own if you are using rattle can primer since it goes on with a fairly large spray pattern. If you are using an airbrush just make sure you don't cause a sharp "bump" around your tape or you will notice it when you sand and paint. You'll need to spray at-least a few cotes (or more depending on what type of primer you are using). Keep in mind that the primer will build up on the tap as well as the surface around it, so don't try to keep spraying until you can't see the tape or you'll wind up with 1/2" of primer on it.
Once done, you'll need to sand down to where you can see the top of the tape. I use wet sanding for this but that's up to you. I use 220 (gently) then 320 grit. Once you have sanded to the point where your tape is showing, then clean everything up real good and start pulling the tape out. It's a bit tricky at first, just make sure you have something with a really small tip. I use a dental tool or the scalpel, but to each their own. Keep in mind that sometimes the tape will pull apart and you won't get it all. Look at the tape after you pull each strand and if you see where it looks thinner or you only see a clear section, that means you have left some in the indention. Just grab the end and gently pull out.
That's pretty much it. This is one of those things that can be a little tricky at first, but once you get the hang of it.. it really isn't hard at all. However, I would try it on something other than your plane first just to get a feel for it.
I'm sure others have some other good techniques here as well, so I'm looking forward to seeing what I could be doing better.
Later,
Russ
Old 09-30-2012, 08:57 PM
  #54
Nergall
Thanks for the info!
I'm working on a warbird now, and it will be my first attempt at glassing a plane. Not sure I want to go this far or not, I'll be happy if the thing doesn't come out too heavy.
Old 10-13-2012, 05:40 PM
  #55
[email protected]
Received my cockpit kit from Ed at BuyAero.com and have been painting and making knobs from pins all week!
I'm pretty pleased with the results so far.
ID:	1810932   Click image for larger version
ID:	1810933   Click image for larger version
ID:	1810934   Click image for larger version
ID:	1810935   Click image for larger version
ID:	1810936   Click image for larger version
ID:	1810937   Click image for larger version
ID:	1810938   Click image for larger version
ID:	1810940   Click image for larger version
Old 10-21-2012, 06:22 PM
  #56
[email protected]
I finished glassing and priming this week.
Now I have a few last tasks before color coat:
1. draw the panel lines
2. lay down the chart tape
3. more primer
4. wet sand
5. pull the chart tape
6. hours of rivet marking
6. paint it aluminum rustoleum
I also have a few final body scaleing items. Not sure if i'll use the amunition hatch molded plastic bits and various hatches. I will make some of these shapes with flight metal before final priming.
Here's some photos with the cockpit kit taped in to check fit and see how cool it's gonna look. I am really pleased!
-Regards
-Skip
ID:	1813700   Click image for larger version
ID:	1813701   Click image for larger version
ID:	1813702   Click image for larger version
ID:	1813703   Click image for larger version
ID:	1813704   Click image for larger version
ID:	1813705   Click image for larger version
Old 10-21-2012, 06:27 PM
  #57
[email protected]
Oh yea... I also have to paint my pilot! That is going to be loads of fun!
Old 10-21-2012, 06:31 PM
  #58
sebo
Are you going to weather the cockpit or are you going to leave it pretty....I like it the way it is but if you are going to weather the aircraft, you may want to show some wear on the cockpit too.
Just my thoughts....I've done it both ways..
Old 10-21-2012, 06:40 PM
  #59
[email protected]
I will probably but, I haven't decided yet...
Were you happy with the results when you did it?
Old 10-21-2012, 06:59 PM
  #60
sebo
Yes, quite pleased....but I was going for the weathered look all over........Dave Platt's spitfire....beautiful plane.
Old 10-30-2012, 06:40 PM
  #61
[email protected]
With the hurricane and all, I had a couple bonus hours to work on the Zero! Yay! Here's some shots. I'm still amazed at the size of this thing!
ID:	1816367   Click image for larger version
ID:	1816368   Click image for larger version
ID:	1816369   Click image for larger version
ID:	1816370   Click image for larger version
ID:	1816371   Click image for larger version
ID:	1816372   Click image for larger version
ID:	1816373   Click image for larger version
ID:	1816375   Click image for larger version
Old 12-11-2012, 05:13 PM
  #62
[email protected]
Making progress, between work and other projects!
ID:	1828980   Click image for larger version
ID:	1828981   Click image for larger version
ID:	1828982   Click image for larger version
ID:	1828983   Click image for larger version
ID:	1828984   Click image for larger version
ID:	1828985   Click image for larger version
ID:	1828986   Click image for larger version
ID:	1828988   Click image for larger version
ID:	1828989   Click image for larger version
ID:	1828990   Click image for larger version
Old 12-11-2012, 05:26 PM
  #63
[email protected]
Base coat of Rustoleum Alluminum is on... next is color coat, and I'm torn between Imperial Navy sky grey and Imperial Army green...
ID:	1828995   Click image for larger version
ID:	1828996   Click image for larger version
ID:	1828997   Click image for larger version
ID:	1828998   Click image for larger version
ID:	1828999   Click image for larger version
ID:	1829000   Click image for larger version
ID:	1829001   Click image for larger version
Old 12-11-2012, 08:17 PM
  #64
Ram-bro
My Feedback: (101)
Just so you know and me may not want to do this to simulate some weathering. When I use the A,. Rustoleum on my warbirds and then paint over it with another color, I will wipe it down with a dry cloth to remove the sheen to help with adhesion. I have done this with my TFGS P47 and Byron p51. I have the smae kit framed up and ready for detail so I am watching
Old 12-12-2012, 01:37 AM
  #65
sebo
Do you paint the inside of your canopy or the outside, or both?
How do youmask it before painting?
Old 12-13-2012, 03:09 AM
  #66
Ram-bro
My Feedback: (101)
http://www.youtube.com/watch?v=TkOOYuJzcdw
Old 12-13-2012, 08:57 AM
  #67
jaka
Hi!
Make a bigger muffler for it and it will be perfect!
Old 01-19-2013, 02:15 PM
  #68
[email protected]
I was in Pensacola last week and got a chance to take some pix of the zero in the Navy Air museum...
A curator there, who is a retired Navy pilot, said he would try to get me some photos of the inside of the cockpit. I hope he can!
ID:	1842202   Click image for larger version
ID:	1842203   Click image for larger version
ID:	1842204   Click image for larger version
ID:	1842205   Click image for larger version
ID:	1842206   Click image for larger version
ID:	1842207   Click image for larger version
ID:	1842208   Click image for larger version
ID:	1842210   Click image for larger version
ID:	1842211   Click image for larger version
ID:	1842212   Click image for larger version
Old 01-20-2013, 07:14 AM
  #69
sebo
I'm partial to the green, but the grey makes the plane look larger.
Old 01-20-2013, 09:07 AM
  #70
OldScaleGuy
OldScaleGuy's Avatar
Who made the landing gear? I have a hunch they are Dave Platt, that is exactly what mine did. Great flight.
Nice field except for that killer fence.....
Old 01-20-2013, 10:26 AM
  #71
metaldriver
Looks like your pictures are of an A6m2 with the late war Navy green scheme. Yes the navy used both grey and green,as the Army didnt fly Zeros. They flew Oscars. If you can get your hands on one of the aerodetail books it has several good pictures of the cockpit.
Old 01-21-2013, 01:10 PM
  #72
Luft-Gangster
ORIGINAL: OldScaleGuy
Back at post 38. Shown are the best version of Dave Platt retracts with 1/2" robo struts. Reason I say best is Platt had a cheaper version made of a nylon material.
Old 05-27-2013, 07:43 AM
  #73
[email protected]
Well, It's jsut ab out ready to fly. I'm having trouble uploading images right now, but will attempt to do so again later today. Thanks for watching!
Old 05-31-2013, 07:11 PM
  #74
johnboy151a
My Feedback: (68)
johnboy151a's Avatar
Well?
Old 08-23-2013, 05:20 PM
  #75
kenair
My Feedback: (10)
kenair's Avatar
any updates?
