 Platt Zero Build Thread >
Old 04-18-2022 | 04:34 AM
  #101
Originally Posted by yoska
I have a question about the stab and elevator gap on the plan. There seems to be a taper at the hinge line and i am trying to understand why.
It is not the wing tip but the stab. looking at this build I did not notice the same in photos.
Old 04-21-2022 | 01:47 PM
  #102
Thanks Guys.. Never mind have it figured out. It was an illusion caused by a poor reproduction of the plan that did not show woof grain in the elevator's front.
Old 09-13-2022 | 02:13 AM
  #103
GlennO's Avatar
Do you have right thrust built into that engine box?
Old 09-13-2022 | 12:32 PM
  #104
My Feedback: (60)
Not sure I fully understand the question. The leading edge of the elevator has to be a tapering radius to match the taper of the stab. The dotted line represents the hinge line, IE, the center of the tapering radius. It is also probably a good indication of where the top skin of the elevator should stop in order to form the gap seal for a gap-less hinge line. Take a look at any good 3-view of a Zero and you will see that the visible separation between the stab and elevators is a straight line from tip to tip. The hinge line (your dotted line) also has to be a straight line from tip to tip. Thus, due to the tapering shape, the leading edge of the elevators is swept back as shown on the drawing. Hopefully this all makes sense and I apologize if I misunderstood the question.
Old 07-09-2023 | 11:57 AM
  #105
Default Right Thrust
About how much would you say I need, Glenn?
Old 12-16-2023 | 09:52 PM
  #106
Default Excellent build thread
I'm starting one that will be powered by a 40cc twin. It just barely fits in the cowl. Have you flown yours yet?
