***CUB BROTHERHOOD***
#2801
But unlike the HA's when we try to call a gathering of brother's everyone is too busy or can't afford the travel. I for one still think's that (a gathering) would be way cool.
#2803
Are you guys referring to the Aeroworks Carbon Cub?.... be careful about over powering it... there's a thread posted in one of the forums here, where someone over power theirs and induced wing flutter and the wing struts pull out of the wings.
White and yellow one would look nice!
John M,
John M,
#2804
Ace, it would be great to all get together to fly, but airfare isn't cheap, especially when you haul your plane and flight gear around... by car, it all depends where the lo cal is, 3 days by car is a stinker for me... plus it takes away from what I can sink into the hobby, I've already over spent on my budget with 2 engines, so I'm on a leash for a while... I've been bad, lol.
Super08, as long as you are aware of it, is all that matters... the red is nice... its a shame they don't offer any other colors, I fancy yellow for some reason.
John M,
John M,
#2806
Hi to all CUB brothers, this is my Piper J3 Cub 1/4 (25%) scale, made from my drawings and built of course, by me.
I think that it is one of rare Cub-s that have fuselage lines real thing (wide in the middle).
http://s1336.photobucket.com/user/mi...ml?sort=3&o=56
https://www.youtube.com/watch?v=g2p4EikelOs&list=UUriZtahXmmijX49maYGZYhQ
#2809
John M,
#2810
mnem
I bleed Cub Yellow.
#2813
Thank you all for your kind words. It means a lot when it comes from Cub people.
I am considering to make Short kit of this plane (2psc are already sold), or to sell only plans.
First I want to make sure that everything is working ok, and that there is no error in construction.
I have order to make 1/4 Super Cub plans, so that version will be finished soon.
#2815
That looks awesome!!
#2817
I draw my plans in dimensions that fit H9 landing gear. H9 landing gear has 2 springs (hidden under black protective bags) on both sides, and they absorb any harder landing very well.
#2818
Also it was very hard form me to find material for struts in my country, so H9 struts fits too.
And, I must say, that both are good quality for money. I could not make them for money they cost.
#2819
Misha,
They are very good until you make a several bounce landing. I did that on my H9 cub and as expected the springs extend beyond their range. Thats when u need to replace them. This is the link to the replacement springs which are available. http://www.horizonhobby.com/landing-...-3-cub-han4573
By the way, a set consists of 4 springs.
Best and heres to a no bounce landings.
Rafeek
Rafeek
#2820
Misha,
Rafeek
Rafeek
#2821
Misha, I put a set of H9 j3 struts on my cub as well... they worked out nicely... but I took the male threaded ends out and redid the strut ends with female threads on the strut ends... don't ask why, because it ended up being a lot of work, I just didn't like the thread fit of those aluminum clevis ends.
rafeeki / spaceworm... switching to actual 1/8" bungee cord works very well... its just a bit of a fiddle to get the initial length and tension set right for the weight of the aircraft, but once you get it right, they work a treat.
Also you guys have seen my comments regarding the differences between the landing gear width of the arms on the hangar 9 verses the robart 1/4 scale landing gear... I borrowed one of Misha's images (hope he doesn't mind) so I could better illustrate what I was referring too... the Hangar 9 dimension is within scale, based on measurements I took off a real cub at our local GA airport.
John M,
John M,
#2822
John M,
John M,
#2823
To John, Misha and all Cub officianados,
Does anyone use a differential aileron setting? Are your ailerons set to difflect the same amount both up & down? What if I set them more up and less down or less up then down, what would happen?
How can I make it make flat/flatter turns? Sometimes the steep banking scares me.
#2825
To get flatter turns you mix rudder and aileron to make coordinated turns; so when you make a right bank; you add a little right aileron, and a little right rudder... left banks, a little left aileron, and a little left rudder... it will also keeps the tail from dropping in tight / steep turns... just practice the amount of aileron / rudder mix to get the turn style you want... after you're comfortable with the concept, you can mix it in your transmitter so you don't have to think about it; but I like to fly the sticks, so the only mixing I may do is when it comes to using flaps and keeping the nose at the right attitude on approach for landing.
John M,
