 Painters ????? >
Painters ?????
Painters ?????
Old 02-16-2012 | 03:42 PM
My Feedback: (15)
Default Painters ?????
So how do ya'll pros hold control surfaces for painting. I paint alot (motorcycles), but had trouble holding my control surfaces on my try at a plane. I stuck sticks in the hinge holes, but the rotate, and blow around from the air presure. What is your magic solution ? Also I will be painting my F18 military colors, so whats the hot setup for flat, or semi gloss. One thing I'm REALLY trying to avoid is the chalky look soooooo many military planes have. With weight being an issue, would you go base, clear or single stage. It will be more than one color.
Old 02-16-2012 | 04:34 PM
Zor
Banned
Default RE: Painters ?????
An excellent question.
I am anxious to read the responses.
Zor
Old 02-17-2012 | 02:56 AM
I have always installed the conrol surfaces before painting, but you could use a smaller music wire to create a "handle " by putting the wire in the outer most holes in the control surface to make a loop to hold on to and hang once it is painted
Old 02-17-2012 | 03:55 AM
TomCrump's Avatar
I install the control surfaces, too. I build fixtures to hold the wings. I mount the fuselage on an engine stand, allowing it to be rotated as I paint.
For paint, take a look at Warbird Colors. They have accurate color matching, and a realistic gloss. http://www.warbirdcolors.com/welcome.asp
ID:	1728047   Click image for larger version
Old 02-17-2012 | 06:29 AM
My Feedback: (15)
Very cool idea on the engine stand ! Do yoe have to worry aboyt paing getting into the hinges, or coating them ?
Old 02-17-2012 | 06:50 AM
TomCrump's Avatar
ORIGINAL: edgeflyer
The stand was $70.00 from the corner auto parts store.
I install my hinges with epoxy. This requires that I put Vaseline on the pivot points. This also protects the hinges from being penetrated by the paint.
Old 02-17-2012 | 07:03 AM
waterloged's Avatar
Hi Tom, I'm Jim Scofield from bullwinkels flying aces in greenville mi. I bought your PC 300 airflair several years ago at the swap in wyoming mi. it still flys and havent trashed it yet. just thought you would like to hear its still flying. Have a nice season...
Old 02-17-2012 | 07:10 AM
Banned
"One thing I'm REALLY trying to avoid is the chalky look soooooo many military planes have"
I'm not sure about the more "modern" paints, but when I was doing a lot of painting, the only way you got any kind of "dull" was with a powdered additive. Therefore, if applied a little dry; chalky.
"and blow around from the air presure"
Again, from my experience that was usually the result of too much air, not enough paint, from trying to spray too thick a mix.k
Les
Old 02-17-2012 | 07:26 AM
My Feedback: (43)
Two suggestions....either "jamb" the plane like you would a car or make holding jigs using more than one of the hingle holes. If you jamb the plane, you can paint all of the leading and trailing edges, canopy edges, gear doors, etc etc, then assemble the plane, and paint the rest.
I use dowels in two hinge holes, then stick those dowels in a piece of foam, then paint. I assemble after the base color, then put all of my stripes and such on after the plane is hinged.
Old 02-17-2012 | 09:12 PM
Rudolph Hart's Avatar
Re weight i'd go basecoat,finish the design and then clearcoat.T pins don't make big holes around control surface edges and fine tie wire between two upright poles will hold it all still for you.
Old 02-18-2012 | 04:33 AM
TomCrump's Avatar
ORIGINAL: waterloged
Thanks for the update, Jim. I really liked that model, and hated to part with it.
Old 02-18-2012 | 06:26 AM
OldScaleGuy's Avatar
For Robart type hinges i spot glue dowels in place leaving a gap large enough to get good coverage to leading and trailing edges. Whit pinn type hinges, i sacrifice some hinges by glueing the hinge joint to make it virtually unusable. These are saved for future projects, i have used thin plywood and sheet brass for the same job but it is much faster to sacrifice a few hinges for an instant "paint fixture".
Old 02-18-2012 | 08:25 AM
frequent flyer's Avatar
I have a number of pine 1 x 4 blocks the are a foot long, from these blocks I made two vertical pieces of 1/16" piano wire that I sharpened the ends. I glued these into the blocks with the points sticking up. When I paint a control surface I just press it on the two wires guiding them into a couple if the hinge holes. It works great and I put tape on the hinges that I usually epoxy into one have before painting.
Old 02-18-2012 | 09:45 AM
ORIGINAL: frequent flyer
I have a number of pine 1 x 4 blocks the are a foot long, from these blocks I made two vertical pieces of 1/16'' piano wire that I sharpened the ends. I glued these into the blocks with the points sticking up. When I paint a control surface I just press it on the two wires guiding them into a couple if the hinge holes. It works great and I put tape on the hinges that I usually epoxy into one have before painting.
I used to do something very similar but due to my lack of being a great painter i always ended up with an off color due to more paint on let's same an elevator than the horizontal stabilizer. Attaching them in close proximity of each solved that problem and now the surfaces are much more consistent with each other.
Old 02-18-2012 | 07:36 PM
My Feedback: (15)
A great builder friend of mine told me to do the dowels in the hinge hole method, but I think my dowels needed to be tighter, just like to know what other genious methods are out there. Thanks
Old 02-18-2012 | 09:09 PM
countilaw's Avatar
ORIGINAL: LesUyeda
Les
Les,
If you have a automotive paint supplier near you, and they carry PPG brand of paint, they will have a clear called " Flex Clear". This is a clear coat that dries flat. You have all the protection of a clear coat with the uv protectorant it contains, plus the ability to clean it with soap and water. It is also nitro proof.
You will need to get the clear activator with it and mix it 4 parts clear to 1 part activator. Add some reducer to it to get it thin enough to atomize through your spray gun.
You will like the results.
Frank
Old 02-18-2012 | 09:11 PM
countilaw's Avatar
ORIGINAL: LesUyeda
Les
Les,
Frank
Old 02-18-2012 | 10:35 PM
My Feedback: (13)
ORIGINAL: edgeflyer
couple of ways if you use pin hinges I just use the stick method but use 2 sticks taped to the edge of a box at each end so it holds the item steady,then you can shoot both sides, trying to paint with only one stick just leads to frustration, for CA type hinge slots a "T" pin through the cardboard at the hinge locations,it will hold the elevator or whatever your painting in position vertically so you can do both sides.
I usually build warbirds so there is usually a 2 tone scheme, a lighter under side and darker upper, so after doing the underside, I usually just tape the area to be masked and tack the surface down to a box with some small pieces of tape so it won't slide around,my latest project was to paint my ESM FW190 in a more scale scheme while still using the existing logos
ID:	1728897   Click image for larger version
ID:	1728898   Click image for larger version
Old 02-19-2012 | 07:19 AM
Banned
countilaw
Thanks. You may have missed my "when" I was; I haven't been doing that for quite some time now, and don't see it in future.
Les
Old 02-19-2012 | 08:21 AM
SunDevilPilot's Avatar
I use a coat hangar inserted into the hinge holes. The hangar is bent in a way I need to pull it wider to get it to enter the holes. With some tension built into the wire the surface will stay on the wire while painting. The wire makes for a nice handle to hold while painting. It is then used to hang the part while it dries. When done you just pull it out.
SunDevilPilot
Old 02-19-2012 | 09:02 PM
My Feedback: (13)
that looks killer I am going to use the coat hangar
Old 02-22-2012 | 08:08 AM
raptureboy's Avatar
Well I just lay them flat on some cardboard or paper and spray with my airbrush. not enough pressure to move them around and when the top dries I flip over. I use latex paint so it dries in about 30 min. I'm not sure what you mean by chalky finish warbirds have. If your modeling a warbird that's been in combat the finish will be anything but nice and shiney or pretty looking. Navy planes had the worst chalky looking finish from salt air and sun. Remember these were tools of war and should be all dented dirty and faded.
Old 02-22-2012 | 09:58 AM
Zor
Banned
ORIGINAL: raptureboy
When I walk around the grounds at an airport I do not see shiny, waxed, polished airplanes like we often see cars in an automobile showroom.
I like my models to look like they have been flown and they have.
A full size J3 or Citabria does not look like it has been finished with Monokote or similar material .
My models are not built full of fine details. They are not for competition.
I build them to be solid (as crash resistant as I can) and to fly them.
I am still planning for my next build to be a Twin Comanche (my avatar) which I flew for the company for nearly two years. I am designing the structure myself and the drawings are 50% done.
I have just bought a Ryobi disk and belt sander to facilitate my work. It certainly will not be a kit .
I will not only <u>build</u> the parts but will <u>assemble</u> them __Hee! Hee! .
Have a great day everyone.
Zor
