BUSA 1/3 Scale Ercoupe Build
You can get parts for your Stafford model here http://leisurercmodels.com/jack-staf...dels-kits.html
Nice pic of my Coupe on the site
Glad to see they are still available. Unfortunately mine met it's expiration date last year. Later!!
Anthony
My Feedback: (17)
I just ran across this thread. The BUSA Ercoupe is one of those planes that I've always wanted to build when I could afford it. The time may this coming year. I'm wondering what engine everyong is using? My wife has given me free reign on this plane and I was thinking I would like to use an OS 3.20 Pegasus if it will fit in the cowl. I don't think I could bring myself to put a 2 stroke in this plane, Anyone know where I can download a copy of the kit manual?
MN
I'm installing the wing center section on mine now, what's the wing incidence supposed to be?
How about stab incidence?
Don't find any reference to it anywhere.,
How about right thrust, it says 1 1/2Degres down thrust, but no right thrust reference on the plans, but I found in the manual 1 degree down and 1 right?
I'll call BUSA on Mon.
I'm using the Saito FG57 twin engine, going to be a challenge getting it in.
The carb is on the rear and will be inside the mounting box.
Hard to hook up throttle linkage, fuel lines etc, also the tank is supposed to be inside the box.
It's too big and there's no room with carb in there.
