Reload this Page >
~~Sig Kadet Brotherhood~~.
Old 02-23-2015, 09:39 PM
  #2501
soarrich
My Feedback: (98)
soarrich's Avatar
Default Got the motor mounted.
I have the fuse about 75% done. I've built and joined the sides, then mounted the motor. I was going with a radial look, but I think I've switched to a Ranger 6 cylinder look. I thinned the firewall width one inch. I have two options for mounting the motor, my first choice is like it's mounted now, but in one of the pictures you can see the other optional mounting with the motor on front of the mount, I don't like that but if it's needed for balance I can do it.
ID:	2075836   Click image for larger version
ID:	2075837   Click image for larger version
ID:	2075838   Click image for larger version
ID:	2075839   Click image for larger version
ID:	2075840   Click image for larger version
Old 02-24-2015, 02:44 AM
  #2502
TomCrump
TomCrump's Avatar
Nice progress, Rich.
Old 02-24-2015, 10:02 AM
  #2503
FlyerInOKC
FlyerInOKC's Avatar
Looks real good Rich, where did you get the motor and mount?
Mike
Old 02-24-2015, 05:13 PM
  #2504
ETpilot
ETpilot's Avatar
As far as I know, SIG has come out with 10 versions of the Kadet and you can see what I gathered here: http://www.wanderings-ds.com/whs/kadet-versions.html
Of course, several thousand guys have done their own thing with the Kadet too, which probably makes it one of the most "modified/bashed" designs ever, if not #1.
Skylark-flier thanks for that brotherhood number and also the link with the info on the different versions of the Kadet. Very interesting. Tomorrow is a weather day here. So I am going to start on the Kadet tomorrow.
Old 02-26-2015, 06:36 PM
  #2505
Flight Risk
Flight Risk's Avatar
Thanks for that list ET. That's a useful list. I thought it odd that the MkII came out before the MkI. Maybe because the MKI is similar to the original version. I always wanted the EP-42 after seeing one assembled in a hobby shop. Now they are big money on flee bay.
Old 02-26-2015, 06:55 PM
  #2506
Steve Westphal
We use our big Kadet to pull up a glider......but my brother found a Kadet "Jr." still in the box. We use a .60 glow engine in the big one and it pulls fine. Any suggestions as to set up for elec on the small one?
Old 02-26-2015, 07:02 PM
  #2507
ETpilot
ETpilot's Avatar
Originally Posted by Flight Risk
Thanks for that list ET. That's a useful list. I thought it odd that the MkII came out before the MkI. Maybe because it is similar to the original version. I always wanted the EP-42 after seeing one assembled in a hobby shop. Now they are big money on flee bay.
skylark-flier posted that list for me. See post 2500. I didn't know how to quote just that portion of his post without also including the brotherhood list. So I copied n paste. I should have been a bit more clear to give him credit. That list is very informative.
I've just started scratch building the Kadet LT-40. I'm about finished drawing out my building plans. Next I need to order some balsa to add to what I have on hand. Local hobby shops are not stocked for the scratch builder. It should be an interesting n fun build.
Old 02-26-2015, 09:09 PM
  #2508
skylark-flier
skylark-flier's Avatar
As I remember it, SIG came out with the Mk-II and - at that time - figured INCORRECTLY that the original Kadet was history. Mk-II came out Spring 1980 and by Fall they had so much feedback they finally re-issued the original under the guise of Mk-I very early in 1981. The original 1972 Kadet and the Mk-I Kadet are virtually identical - same plane.
Old 02-26-2015, 09:39 PM
  #2509
soarrich
My Feedback: (98)
soarrich's Avatar
Mike
The motor and ESC are HobbyKing items:
http://hobbyking.com/hobbyking/store...00KV_815W.html
http://hobbyking.com/hobbyking/store...ontroller.html
The motormount is http://www.aircraft-world.com/en/p1071850-hp-z30-frtmnt
Old 02-27-2015, 06:10 AM
  #2510
FlyerInOKC
FlyerInOKC's Avatar
Than ks Rich!
Old 02-27-2015, 02:10 PM
  #2511
acdii
SIG Rocks! Ordered the Koverall and Dope Wednesday night, got it today!
Old 02-27-2015, 02:55 PM
  #2512
TomCrump
TomCrump's Avatar
It's hard to beat the service that Sig provides. Other, larger suppliers, should take notice.
Old 02-27-2015, 04:53 PM
  #2513
acdii
Yep, the only times I experienced delays from SIG were over holidays, which can be expected.
Old 03-02-2015, 12:09 PM
  #2514
soarrich
My Feedback: (98)
soarrich's Avatar
My build is going slow this is what I've got done lately.
First picture is making the leading edge cuff's bottom.
The next two show the cuff after the epoxy dried.
Then the wing bolt block and diagonal pieces on top back.
I show the ply plate I put on the bottom, stringers and diagonal pieces.
The last two pictures show the front loading battery, and the original too low location of the motor.
Name:	battery opening.jpg
ID:	2078128   Click image for larger version
ID:	2078129   Click image for larger version
ID:	2078130   Click image for larger version
ID:	2078131   Click image for larger version
ID:	2078132   Click image for larger version
Name:	wing bolts.jpg
ID:	2078133   Click image for larger version
Old 03-02-2015, 12:19 PM
  #2515
TomCrump
TomCrump's Avatar
It's not a race, Rich. It'll get done when it gets done.
I like the fuselage stringers.
Old 03-02-2015, 01:15 PM
  #2516
EJWash1
EJWash1's Avatar
I'm curious. I see that you used wax paper to protect the wing from the epoxy saddle. I've used West System epoxy/filler mix for several projects. I use kitchen plastic wrap, and it literally falls off of the epoxy. Is it the same with wax paper?
You do NOT build slow, *I* build slow!
Your build is looking good, too!
Old 03-02-2015, 03:52 PM
  #2517
soarrich
My Feedback: (98)
soarrich's Avatar
I've used both, I think it comes off the waxed paper better. The plastic wrap can get little wrinkles in it which for small snags, you don't get that with the waxed paper. I hold the waxed paper on the wing with a light dusting of 3M 77. Super MonoKote works also, has it's own sticky, but is more expensive.
Old 03-02-2015, 05:11 PM
  #2518
acdii
For some reason the wax paper I used bleeds through epoxy and other glues.
Old 03-02-2015, 06:05 PM
  #2519
N1EDM
I've heard some people comment that the waxed paper that is out today is not the same as we used to build with years ago. I, too, have had waxed paper stick to my balsa when used with CA an. Parchment paper works a little bit better, bit it also isn't foolproof. Instead, I use the backing from rolls of Monokote.
Just my $.02
Bob
Old 03-02-2015, 06:41 PM
  #2520
acdii
I found the backing from the old SIG covering even better than monojoke backing. Its heavier and lasts longer, and glue does not stick to it.
Old 03-02-2015, 07:57 PM
  #2521
Flight Risk
Originally Posted by TomCrump
It's not a race, .
Maybe some of you could have a race. It would be interesting to see just how fast a Kadet can go together by an expert.
There was a fellow in our club who built almost 50 Seniors. I had one numbered 45. He also built a 4 engine Kadet, and was a big inspiration why I love these Sigs.
Old 03-02-2015, 08:56 PM
  #2522
flyingagin
flyingagin's Avatar
I have also had wax paper stick. Now I put some cooking oil (usually olive oil) on a paper towel and wipe the wax paper with it. Just a very small amount and no sticks. Some car paste wax would work great.
Ken
Old 03-03-2015, 04:10 AM
  #2523
N1EDM
Nice thought on the paste wax, Ken. Thanks for the idea!!
Bob
Old 03-03-2015, 06:21 AM
  #2524
acdii
I could probably build another LT-40 in under a week. It goes together a lot faster than the Cub. I have about 3 weeks in my Biper, and part of that was in designing the lower wing mounts and mods. If I just built it as a clipped wing plain Cub it would be ready for radio by now.
Old 03-03-2015, 01:38 PM
  #2525
soarrich
My Feedback: (98)
soarrich's Avatar
I just made the top part of my leading edge wing cuff and the waxed paper stuck to the epoxy. Normally I use slow epoxy, but I wanted to take the plane to my club's meeting tonight so I used 6 minute, it got quite hot,it must have melted the wax. I guess if you don't use 24 hour epoxy, don't use waxed paper.
