Reload this Page >
~~Sig Kadet Brotherhood~~.
Old 03-03-2015, 02:06 PM
  #2526
FlyerInOKC
FlyerInOKC's Avatar
It could have seep thru and stuck that way. Modern waxed paper is porous so you can microwave with it.
Old 03-03-2015, 03:28 PM
  #2527
ETpilot
ETpilot's Avatar
Just getting back into RC n building. Weather here in Texas is lousy so I am taking the time to start my build; Kadet LT-40. Not sure how this build will go but at least I have started. Thought I'd post a picture of where I am so far. Starting with the fuselage. Here I have both fuselage sides, one atop the other, glue drying. More work to follow. If I am careful it may look like an LT-40.
ID:	2078499   Click image for larger version
Old 03-03-2015, 07:05 PM
  #2528
Pork Chop
Pork Chop's Avatar
FlyerInOKC,
I'm repairing an old Sig Riser right now, first time building in years and noticed my new CA'd tail assembly completely stuck to the wax paper. I was totally surprised. The car wax idea sounds like it would be a great idea!
Old 03-04-2015, 07:10 AM
  #2529
acdii
I found parchment paper works better, but is hard to see through. Just make sure it is shiny side up.
Old 03-04-2015, 07:20 AM
  #2530
skylark-flier
skylark-flier's Avatar
It'll go just fine - it's a SIG plane and, as far as I've ever known, you simply can't screw one up. I may be testing that thought though, with my Stratus build. You're looking good though, so far.
Old 03-04-2015, 08:19 AM
  #2531
FlyerInOKC
FlyerInOKC's Avatar
I use GP plans protector or the heat shrink plastic for covering windows and doors in winter.
Old 03-04-2015, 08:55 AM
  #2532
flyingagin
flyingagin's Avatar
I just epoxied up a part yesterday. I wiped some Carnuba car paste wax on the wax paper liberally and then wiped it off. Worked like champ. Even where I direct wax paper to epoxy contact.
Ken
Old 03-05-2015, 05:00 PM
  #2533
N1EDM
Hmmmm, I wonder what a shot of some cheap silicone spray would do, as long as you kept it off the pieces you're gluing up....
Just my $.02
Bob
Old 03-05-2015, 05:33 PM
  #2534
acdii
Its a good idea to keep silicone as far away from your project as possible. Even the thought of silicone anywhere near it can cause painting issues down the line. The best protection I found to date is the clear backing that was on the old SIG covering that I got with my 4*. Its thick, durable, and clings well to the plans, paint and all glues come right off it too. Can't say the same for the plan protector roll of stuff, it is thin, and ca sticks right to it. It tears easy and ca wicks right past the pins into the plans.
Old 03-07-2015, 04:26 AM
  #2535
N1EDM
Acdii, yeah, I think you're right. Strike my last, um, suggestion if you're going to be painting. Perhaps it is a bad idea all over, in afterthought.
Bob
Old 03-09-2015, 11:21 AM
  #2536
soarrich
My Feedback: (98)
soarrich's Avatar
Default Making slow progress.
I've decided to paint the windows in. I fly with Dick Sarapolus, he's done maybe a 100 designs in magazines, he avoids plastic windows and canopies whenever he can because they are the first things to start to look crappy, one of his painted window planes will look as good 10 years from now as it does today. I made a pho door and stringers on the solid front half of the plane carrying the real stringers to the rear. The top of the tank compartment I had to plank, then the engine compartment too. I'm not very good at it, I haven't done it in years. Last time I did it I had just watched Dave Platt's tape on it and it turned out great, this time not so much, but it sanded down OK, though it needed lots of filler
ID:	2080107   Click image for larger version
ID:	2080108   Click image for larger version
ID:	2080109   Click image for larger version
ID:	2080110   Click image for larger version
ID:	2080111   Click image for larger version
ID:	2080112   Click image for larger version
Old 03-09-2015, 12:15 PM
  #2537
TomCrump
TomCrump's Avatar
The nose planking looks great. In fact, the whole model looks great !
Old 03-09-2015, 12:28 PM
  #2538
flyingagin
flyingagin's Avatar
Some really beautiful work Rich. The wife loved the wing. I threw the pics up on our TV for her.
My SR is still flight worthy after some 25 years and one rebuild just because the covering looked like crap and I wanted check out the structure for any damage. It is now named John Dear because of the covering scheme, just needs a John Dear decal or so. Well it would be flight worthy with a new RX and an engine rebuild, Saito 65. And I have worn the engine out so that it is way down on power. Got a new after market piston ring. Now I just need to get new bearing and have it. Rebuilt plenty of glow 2 stroked and even a total rebuild on a couple of engines. But some how I am reluctant to have at this little four stroke. Go figure.
I really like the halve ribs. They look great and will still stand out after the covering. Seems that the wing should perform better also.
Ken
Old 03-13-2015, 06:44 AM
  #2539
ETpilot
ETpilot's Avatar
Thought I'd post a few pictures of my LT-40 build. It is progressing pretty nicely. Fuselage needs a bit more work. Somehow the fuselage tail end got .50" off of centerline . So I had to jig it and coax it back. It is straight arrow again. Tail feathers are about done. Next will be the wing. If it ever stops raining and dries up, I may get to try to fly this plane.
ID:	2081121   Click image for larger version
ID:	2081122   Click image for larger version
ID:	2081123   Click image for larger version
Old 03-13-2015, 07:39 AM
  #2540
skylark-flier
... If it ever stops raining and dries up, I may get to try to fly this plane.
Might I suggest first, maybe a bit of fabric of some kind to cover over the holes? I've found that if you do that, they work better.
Sorry, couldn't resist. Seriously, she's looking good. I love seeing these planes all framed up.
Old 03-13-2015, 07:55 AM
  #2541
flyingagin
flyingagin's Avatar
hahaha good one Dave good one
Looking good ETpilot
Love looking at naked planes, love seeing their bones
Ken
Old 03-13-2015, 07:56 AM
  #2542
FlyerInOKC
FlyerInOKC's Avatar
Boy that takes me back! I added triangle stock to all 4 sides of the firewall on mine. Flies great with a Super Tigre .40.
  #2543
FlyerInOKC
FlyerInOKC's Avatar
Boy that takes me back! I added triangle stock to all 4 sides of the firewall on mine. Flies great with a Super Tigre .40. After I parked it in the canopy of a large tree my rock climbing Eagle scout son had a heck of a time but managed to free. He pulled off the vertical stab doing it. That was the only damage. I told him I would rather have to fix the tail then leave it in the tree. You may want to add some triangle stock there as well. I did when I reattached the tail.
Old 03-13-2015, 08:13 AM
  #2544
flyingagin
flyingagin's Avatar
I am with Mike here. I always add some triangle stock to a firewall.
On bigger planes I also pin through the fuse sides and into the firewall maybe a 1/4" with some small hardwood dowel pieces or bamboo skewer pieces. What ever fits.
I am assembling the fuse for a .90 powered bi plane, and will drill small hole through the fuse and into the firewall. Then bamboo skewers will be epoxied into the holes. The wings may come off but that engine ain't!
It is just some thing personal that I do. It is likely not necessary, but it gives me peace of mind.
Ken
Old 03-13-2015, 08:36 AM
  #2545
FlyerInOKC
FlyerInOKC's Avatar
If you stick with rubber bands (I did) store them in a plastic bag with baby/talcum powder and replace them every flying season and don't scrimp on the number!
Old 03-13-2015, 12:26 PM
  #2546
Flight Risk
Flight Risk's Avatar
ET, I'm not sure if you are building with a kit or from scratch, but I found out long ago that the source of wood from both sides should be the same. If you build one side and run out, then go the the LHS to get more, chances are it will have different characteristics, which can create bowing. Same for wings or other parts. It's always best to strip your own wood from the same plank than buying sticks. I like your use of flat iron for weight. I may get some of those made up.
Old 03-15-2015, 04:05 AM
  #2547
ETpilot
ETpilot's Avatar
I guess you can't see the invisiblecoat covering I have on my build. I better do the more traditional Koverall covering for better visibility.
The rain here in East Texas has been horrible this year. Just this week we got 4.75 inches. The forecast is for 3 days of rain next week. Great weather for building but I can't get my outside projects done and I sure can't try to get back into the flying.
Thanks for for all the tips. I do plan to add some more triangle stock, and also for the firewall. As for pinning the firewall, I had forgotten that. Thanks. I pinned my last build and will do the same with this one. I don't like using rubber bands so the wing will bolt on.
Flight Risk, I am following plans but draw my outline on freezer paper so basically it is a scratch build. I believe what you say is exactly what happened. I got some sticks for this build. I plan to cut my own sticks next time.
So far, the fuselage and tail surfaces are weighing in at 15 ounces. I am starting on the wing now. This is a fun build. It is going faster than I thought. It must be the rain.
Old 03-16-2015, 11:18 AM
  #2548
soarrich
My Feedback: (98)
soarrich's Avatar
Ken
Planes and ladies.....
Old 03-16-2015, 11:32 AM
  #2549
flyingagin
flyingagin's Avatar
Just planes
Ken
Old 03-16-2015, 01:05 PM
  #2550
skylark-flier
Poor Ken...
Personally, I subscribe to the Jeff Foxworthy creedo - I wanna beer, and I wanna see somethin' naked.
Yup, that's me ... the perpetual dirty-ol'-man.
