Reload this Page >
~~Sig Kadet Brotherhood~~.
Old 02-03-2013, 04:54 AM
GaryHarris
GaryHarris's Avatar
Default RE: ~~Sig Kadet Brotherhood~~.
I started a LT40 build thread here if anyone is interested. The kit should show up on Wednesday. It ll be my fourth LT40.
http://www.rcuniverse.com/forum/m_11392202/tm.htm
I haven't done any of the other Kadets yet, but it looks like now Ill have to start a collection.
Old 02-03-2013, 04:55 AM
hutchis
My Feedback: (8)
Here's my LT40 float plane built from a kit with some modifications (dual aileron servos, bolt on wing, tail dragger set up). It is covered with ultra cote and has an 0s 55 AX. Below is a link to some action on the River last Memorial Day. Can't wait to take it out of winter hibernation and get going again this spring.
Cheers..Hutch
http://www.youtube.com/watch?v=i0NLLCO7LiE
Old 02-03-2013, 05:00 AM
TimHendrix
Kadet MKII in 1983 when I was 13 years old. OS .35 for power. Couple of Seniors since then and an LT 40 my daughter assembled when she was about 12. Still using it as a club trainer. I'd like to build another MKII for old times sake.
Old 02-03-2013, 05:06 AM
GaryHarris
GaryHarris's Avatar
ORIGINAL: hutchis
Cheers..Hutch
Absolutely gorgeous LT40 Hutch. I'm wondering, how did you cover the fuse? Did you do the trans red in the cut outs first? And how did you do the white? Did you pre-cut the knock out areas before ironing down?
Old 02-03-2013, 05:57 AM
Slavko
Count me in also.  Built my first MK II back in about 1980.  Sold it when I got out of the hobby and got it back from the same fellow 25 years later.  Still have it and have built 4 more since then.  Great plane.
Joel
Old 02-03-2013, 06:02 AM
  #31
hutchis
My Feedback: (8)
Thank you.. For the Fuse Pattern I traced the pre cut knock out areas on each fuse side (and top) onto a paper pattern. Next I applied the red transperent covering just on the areas of the fuse with the knock outs. Then I took the paper patterns that were traced laid them over a section of white covering, cut out the knock outs, then laid them on accordingly. It took some time but it kept me busy last winter.....
Old 02-03-2013, 06:15 AM
  #32
lkruse
My Feedback: (42)
Throw me into the mix. Attached is a shot of my Kadet Senior ARF.
Larry Kruse
Old 02-03-2013, 06:16 AM
  #33
flyingagin
flyingagin's Avatar
Hey the water looks fine. I think I will also jump in. Splash
I presently have 2 Kadets.
A Kadet SR and a Jr. My third junior I think.
The SR was a kit build when I got back from Desert Storm. The Jr is a scratch build and then rebuild from a set of original plan from the first 2 Jrs. The rebuild came about after trying to force it off of grass resulting in a tip stall that left me with a completely trashes fuse. OS .25 powered.
The SR uses a rather worn out Saito .65.
Dihedral on both was reduce by 1/2.
Ken
ID:	1847443   Click image for larger version
ID:	1847444   Click image for larger version
ID:	1847445   Click image for larger version
Old 02-03-2013, 06:29 AM
  #34
GaryHarris
GaryHarris's Avatar
Thanks Hutch. I might do the same thing with mine except in green. I have been on sort of a green kick lately. Not many folks use green and I thinks it's a little different.
Got some new members yall... Welcome to the Kadet brotherhood. [8D]
GaryHarris. Number 1.
soarrich. Number 2.
N1EDM. Number 3.
Live Wire. Number 4.
5skyhawk172. Number 5.
zippome. Number 6.
shepard62 . Number 7.
GraemeEllis . Number 8.
archie05 . Number 9.
tomgreen. Number 10.
n2ryd. Number 11.
race61. Number 12.
Slavko. Number 13.
lkruse. Number 14.
flyingagin. Number 15.
Welcome guys.
Old 02-03-2013, 07:07 AM
  #35
cordell staker
cordell staker's Avatar
My kadet senior with the twins hank and jude, the thrust line and control surface angles are not modified. I think I added 18 lbs. of weight. I flew it before with an O.S. 60...I have set this up for a 90 just to make sure it gets off the ground. Gonna train my grand kids on Mad Max
ID:	1847476   Click image for larger version
ID:	1847477   Click image for larger version
ID:	1847478   Click image for larger version
ID:	1847479   Click image for larger version
ID:	1847480   Click image for larger version
Old 02-03-2013, 07:36 AM
  #36
GaryHarris
GaryHarris's Avatar
Another Texan!
Looks awesome brother! The Senior with ailerons is on my bucket list.
Old 02-03-2013, 08:10 AM
  #37
JPNYGAARD
My Feedback: (27)
ADD ME TO THE LIST!! I HAVE A KADET SR. ARF AND A SR. KIT ( MY FIRST KIT IN 50+ YEARS ) ON THE DINING ROOM TABLE.
ID:	1847512   Click image for larger version
Old 02-03-2013, 08:33 AM
  #38
foodstick
foodstick's Avatar
I realized I never posted a finished picture of my Senior with a sort of twisted history,
I do have a fuse shot from the build once covered ...
Here is the story on my Senior, the wing is from an airplane built by a father and son 20 years ago, it was silkspan and dope.. The plane was flown until it needed lots of work, then donated to the club. it flew as a trainer until the wing fell off in flight ! I ended up with the wing after the crash.. it survived mostly but had broken wing tips.
A different friend had given me 2 broken senior arf wings, one had good wing tips only... So I put them on the kit built wing !
Someone else gave me a fuse kit a couple years later, so I used that and a bit of 1/8th birch ply i had laying around to build a big bomb bay in the airplane.
Another friend had a yak 54 that he crashed, and the tail was on the wall in his basement, I said wow that would look good if I cut it down..on my senior.. He said take it, I did
I bent my own landing gear wire to resemble an old timer, and made the plane a tail dragger.
Another friend quit the hobby and gave me a bunch of fabric covering, so thats where the skin came from.
The wheels I believe were discards from an arf kit.
Custom bilt the cowl for an electric motor, that swings a 16-8 prop.
Taught myself to fly on a Seniorita so you had better sign me up
Old 02-03-2013, 09:01 AM
  #39
Live Wire
Live Wire's Avatar
Man this is getting interesting What a great line of planes and what can and has been done to them. Now I am going to have to get another just to be able to build with the brotherhood
Larry K
Old 02-03-2013, 10:45 AM
  #40
ovationdave
My Feedback: (16)
ovationdave's Avatar
Ok, mine is still in the box, its a 1976 kit, just picked it up at a resale shop about a month ago, its destined for floats when it gets to my board. Probably over the summer......should be a quick build.
I will take a number......Thanks!
Dave
ID:	1847562   Click image for larger version
Old 02-03-2013, 12:11 PM
  #41
ovationdave
My Feedback: (16)
BTW......there is Kadet Jr. for sale on RCU for $60.........
~Dave
Old 02-03-2013, 12:17 PM
  #42
Nergall
Count me in!
Senior with an OS .46LA: Been flying it for years. Plan to try FHSS with it shortly, if Tower ever ships those 14sg radios out.
ID:	1847608   Click image for larger version
Old 02-03-2013, 12:23 PM
  #43
GaryHarris
GaryHarris's Avatar
Wow! I had no idea this would grow so quickly. Welcome to the Kadet Brotherhood guys! I have a feeling Sig's kit sales will be on the rise soon. Just from me!
soarrich. Number 2.
N1EDM. Number 3.
zippome. Number 6.
n2ryd. Number 11.
race61. Number 12.
Slavko. Number 13.
lkruse. Number 14.
JPNYGAARD. Number 16.
foodstick. Number 17.
ovationdave. Number 18.
Old 02-03-2013, 12:29 PM
  #44
joebahl
joebahl's Avatar
I sold my kit built topfight AT-6 and he through in a ARF Kadet SR if i took 30 bucks off my bird so my son wanted to learn and i made the deal.A couple weeks later i found my son a electrict e-flight apprentice in another swap so i want to add flaps and barn door ail plus a bomb drop to the SR plus some floats for water fun. Count me in and i will post picture's of the operation later. lol joe
Old 02-03-2013, 12:31 PM
  #45
WI53072
I would like to be added to the Kadet brotherhood please!! I love my Kadet Senior. I converted it to a taildragger and powered it with a Saito .72. Nice flying plane like all Kadets!!!
Paul
Old 02-03-2013, 12:35 PM
  #46
huck1199
huck1199's Avatar
You missed adding me. Thanks Huck
Built in 1986 with an Irvine .40. Still flying now - great plane.
ID:	1847636   Click image for larger version
ID:	1847637   Click image for larger version
ID:	1847638   Click image for larger version
ID:	1847639   Click image for larger version
ID:	1847640   Click image for larger version
Old 02-03-2013, 12:52 PM
  #47
Top_Gunn
Please add me. I have an LT-40, a Kadet Sr (with ailerons added) and a highly modified Kadet Seniorita. In a year or so I hope to build a Kadet Sr. with the wing on the bottom.
Old 02-03-2013, 12:53 PM
  #48
rhamil
Built my first senior from plans in 1976
Old 02-03-2013, 01:02 PM
  #49
GaryHarris
GaryHarris's Avatar
If I miss anyone, I apologize. If you want to be added to the Brotherhood, please note so.
Welcome to our newest brothers of the Kadet Clan.
soarrich. Number 2.
N1EDM. Number 3.
zippome. Number 6.
n2ryd. Number 11.
race61. Number 12.
Slavko. Number 13.
lkruse. Number 14.
joebahl. Number 19.
WI53072. Number 20.
huck1199. Number 21.
Top_Gunn. Number 22.
Old 02-03-2013, 01:08 PM
  #50
GaryHarris
GaryHarris's Avatar
Some pics of my last LT40 that I unfortunately never finished. I was moving and had to thin the heard, so I gave it to a friend. I took out most of the dihedral, converted it to a bolt down wing and a taildragger. I got some of the covering done. Solartex antique.
