~~SIG Brotherhood ~~
#3001
It was actually a fun, stressless build. Typical Sig quality in the box. I used ,most of the supplied hardware. I just wish they would reverse their policy on supplied gear wire. The box comes with wire bent for a tricycle setup. You have to order the wire setup for tail dragger configuration from Sig. as I see it most builders choose tail dragger setup.
#3002
So i cut the dihedral in 1/2. Then make a i peace fuselage dubbler, then mount a block in the fuselage just to head of the wing to make the landing gear mount, then use the landing gear from the 4*60.
#3003
We Iowans think alike, even displaced ones, like me. LOL
#3004
Here are some nicer photos. I wanted to build “to plan” on this Hog so I have a base reference on how Sig designed the kit. I think a fuse mounted gear is a great idea for those flying in anything other than putting green quality grass or asphalt or fabric. My field is darned smooth, rolled putting green quality. 1/2dihederal is fine along with dual aileron servo’s. I will fly this one for a year or two, then sell it off after I build a replacement that will be finished in Koverall and dope and then I will think about incorporating some mods. For now this one was a good start.
#3006
Geez, I'm gone for a few days and it seems like everybody's got a plane ready to go all at once. Great builds, guys!!!!!
#3009
Well i got a another one and yea iam adding carbon fiber to the spar and a one piece spar caps. Going try and take out another couple pounds of lead. Also will definitely use the struts.
#3010
Now that the 4*60 W/retracts is done, I moved on to my Ziroli B-25. Right wing has the aileron and flap done, working on the left wing and will have that done my next time in the shop. I still have a few repairs to do, need to finish the T-clips rebuild, need to put in the tank and balance it and I think that is it, and maybe finish the cowl on the 1/5th Cub and patch the lower wing mounting holes, and maybe move the strut mounts to under the fuse and make new struts. It was my Biper Cub experiment that came out too tail heavy to do anything with. Would need 14 ounces of lead in the nose to balance. I also have the cowl for the P-47 to finish sanding and smoothing so I can make a mold from it. It got busted up when I bounced a wing off a building, and is too heavy to use. The plane needs nose weight, but using a heavy cowl is not the way to do it as the cowl would wind up getting torn up at the mounting tabs. Have quite a few projects sitting around, including a P-51 and Corsair that need to be completed.
#3011
I was hoping he was building from the plans rather than ordering a new one. I know, if it was me, I'd be cutting just as much weight out of the tail as humanly possible as well
#3013
if there were plans it would be a great idea. Now i can copy the tail and make it all out if Balsa.
#3014
The 168 doesn't have plans. Its all tabbed construction. It really is an easy to assemble kit, on that part they fully succeeded, though the manual is missing some key details as I missed a few parts in the tail and had to open it up to correct it. There was also an alignment issue with a couple former's in the tail where they are not fully symmetrical, and caused a twist. With a few modifications to the kit and manual, even a first time builder can build one.
#3015
Okay, something that I didn't know, the kit didn't have plans. That is a first for me, every Sig I've built had a plan sheet so you could replace damaged/missing parts as needed.
#3016
I saved all the scraps so I can make new parts if I need to, and will most likely make a new tail from foam and Carbon Fiber to hopefully shave 2 pounds from the tail which should remove 6 from the nose.
#3017
We have a covered fuselage. Wow forgot how big this thing is. And because of my daughter and her liking the color blue. Well let’s just say it is blue. [img]webkit-fake-url://a528d327-9102-4884-a6f2-ba860dc14a44/imagejpeg[/img]
#3020
cmy6, what a nice job you did! The covering is very impressive. The only thing that I would be concerned about is the landing gear wire, seems pretty thin. Maybe it's just the picture.
#3025
He certainly does, no doubt about that.
Hey guys, earlier this month I received a note from a brother - he'd changed his ID on RCU. Member #132, PSB is now Cycotravlr. Just keeping all y'all up-to-date (hopefully). So, here's what we look like today:
1 - Hazel & Glenn Sigafoose
2 - Maxey Hester & the team
3 - acdii
4 - RCKen
5 - DGUY
6 - DBD1
7 - fix-n-fly
8 - foodstick
9 - UPF-7
10 - jeffie8696
11 - skyrat71
12 - Leroy Gardner
13 - CanDo
14 - JPMacG
15 - Thunder Chicken
16 - 5skyhawk172
17 - Cutlass 60
18 - Mr-Punk
19 - Sabreryder
20 - eastkurt
21 - FlyerInOKC
22 - rtn9105
23 - oliveDrab
24 - triumphman49
25 - ARUP
26 - willig10
27 - malitape
28 - OLDFLYER2
29 - justin80
30 - Jim Branaum
31 - crawler tech
32 - yel914
33 - ThunderBoat42
34 - sbd-3
35 - Thatsakitbuilt
36 - blw
37 - Mike Gretz
38 - Mako17
39 - Live Wire
40 - deanz406
41 - bchapman
42 - SrTelemaster150
43 - SushiHunter
44 - n8rloves2fly
45 - M_Callahan
46 - carlosponti
47 - xxwolfyxx
48 - landeck
49 - cherokeenut
50 - Mark Thomas
51 - rphiii
52 - n0kjf
53 - cymaz
54 - OldRookie
55 - gosch
56 - ThunderChicken72
57 - lfd47
58 - bikerbc
59 - badger5964
60 - N1EDM
61 - Hfrank
62 - Lowvoltage
63 - US185Damiani
64 - hsukaria
65 - lkruse
66 - Sgt. Meyer
67 - G-JIMG
68 - Hydro Junkie
69 - Twin_Flyer
70 - oldsterling
71 - J T Caldwell
72 - cloudancer03
73 - Super08
74 - Hab
75 - Smashmaster
76 - Rv7garage
77 - Neddy191
78 - JZHANDYMAN
79 - Pete Lane
80 - SIGPlanes
81 - rcmichael
82 - larryshobbies
83 - skyraider71
84 - Hawk570
85 - hogflyer
86 - cubcrasher
87 - chandler_ace
88 - Firewalkerd1
89 - Robin A
90 - GLGofLB
91 - On the Deck
92 - aircraftbuilder67
93 - FJRrider
94 - sdcranford
95 - AMA 74894
96 - W7APD Alan
97 - bobsrc
98 - kiwi4
99 - Flight Risk
100 - G.Barber
101 - I_Fly
102 - scaleforlife
103 - balsatermite
104 - 3136
105 - rc56
106 - R/C Addiction
107 - Fly North
108 - JFS737
109 - skylark-flier
110 - rdgettler
111 - allamericanflyer
112 - MartyPetriSr
113 - tribalturtle2
114 - Soboflyer
115 - jollyroger
116 - Captcrunch44
117 - 19wingwalker48
118 - tzlaser44
119 - larscato
120 - TomCrump
121 - guido
122 - RMeadows
123 - Old_RC_Guy
124 - TheComputerGeek
125 - hook57
126 - newbiedc
127 - PipeMajor
128 - RDJeff
129 - ABORH
130 - danpos
131 - mscic-RCU
132 - Cycotravlr
133 - aggieman
134 - Renegade
135 - bodybuildr
136 - SigSenior
138 - mike 71
139 - merto31
140 - thobin
141 - numb3rulz
142 - Gary in Fla
143 - VincentJ
144 - RICKSTUBBZ
145 - EJWash1
146 - BigTeeEldorado
147 - Aquila1954
148 - jwharkinz
149 - TCraft Lover
150 - Pork Chop
151 - drube
152 - trainermaster80
153 - samklem
154 - tkametz
155 - Vinnie6
156 - budof561
157 - RKRick
158 - leojzamboni
159 - sgtmonte
160 - smallrc
161 - daywalker
162 - angel asenjo
163 - Jeff Spicoli
164 - themutsnutz
165 - mvarzoni
166 - Big Stikflyer
167 - gutmark
168 - knuckleball
169 - capt. crunch jr.
170 - flygilmore
171 - Yasbush
172 - cardinalflyer
173 - bbrowncods
174 - pmoen70
175 - GSXR1000
176 - Comper
177 - stinsonsr9
178 - scale buff
179 - F4 Phantom blue angles
180 - OKC_Jim
181 - bigtj10
182 - Mrotar
183 - fcf
184 - ursharkfuel
185 - fredvon4
186 - Brendon.Gunnell
187 - JulianF25
188 - SailplaneJunkie
189 - GUS THE I.A.
190 - do335a
191 - Patrick R.
192 - sterbejj
193 - daniberry
194 - ETpilot
195 - 442dave
196 - Mwt5086
197 - VooDooBlade
198 - Major Crunch
199 - eihoward
200 - aspeed
201 - bufa
202 - Corsair013
203 - Airacobra
204 - tmaxx1701
205 - Beibitoi
