Reload this Page >
~~SIG Brotherhood ~~
Old 12-02-2016, 06:18 AM
  #2101
spaceworm
Originally Posted by acdii
Smells like epoxy. Not really much odor to it. I prefer WBP because of speed, and ease of cleanup. I think it is more flexible which can be a good thing as the plane ages, less chance of cracks happening over time. Haven't tried it with Koverall though, only glass.
Since WBP is water borne, the underlying balsa should be sealed against the moisture in the WBP before using it to cover either with glass or Koverall or other fabric, to prevent warping the balsa.
Old 12-02-2016, 06:22 AM
  #2102
smkrcflyer
smkrcflyer's Avatar
Do I need put a sealer on the wood before glassing with WBP?
Old 12-02-2016, 06:33 AM
  #2103
acdii
I use a light coat of EZE-Kote first to seal the balsa. Its a very thick water based poly type specifically used for glassing.
http://www.horizonhobby.com/glue-and...500-ml-dlmbd37
Its not cheap, which is why I only use it for the seal coat, then switch to Minwax.
Old 12-02-2016, 06:42 AM
  #2104
acdii
Here's the Corsair that I glassed using this method and then painted with latex house paint and then clear coated with automotive paint.
ID:	2191961   Click image for larger version
Old 12-02-2016, 07:15 AM
  #2105
smkrcflyer
smkrcflyer's Avatar
Looks nice. I was thinking about using sanding sealer because I have it.
Old 12-02-2016, 11:21 AM
  #2106
acdii
I wonder about that. I am of the thought that the first coat of poly acts as a sealer and binding agent for the next coat of poly. I think if sanding sealer were used, the poly wouldn't stick to it as readily. Only to know is to try it. A great examples is to brush some poly over epoxy and see how it spreads away from the epoxy like water on a freshly waxed truck. Thats why I use the Eze-Kote first, its thicker, so less moisture to cause the wood to warp, but of the same properties as the Minwax, so it bonds. I noticed that Poly tends to interlink/crosslink much like lacquer does, each coat tends to bond with the former coat. Unless you disturb the finish of the prior coat, you wont see separation of coats in a cross section, you can't peel the top layer off the prior layer.
Epoxy is the same way provided each coat is applied prior to full cure of the prior coat, but apply it after the last coat has cured and you can get separation. Poly and Epoxy both tend to work this way, so they make a good choice for a smooth finish. Hardness is irrelevant for this application since it is so thin, so I don't consider strength to be an issue either.
Old 12-02-2016, 11:46 AM
  #2107
smkrcflyer
smkrcflyer's Avatar
Maybe I'll try Eze-Kote.
Old 12-03-2016, 05:52 PM
  #2108
trainermaster80
trainermaster80's Avatar
Captcrunch44 here is how to silk a plane article WITH A SPONGE.
I could'nt get it to load to this post. Send me your e mail address & you'll get the article
[email protected] frankie g the 88 year old modeler. It takes longer to read than to actually silk a plane wing.
Old 12-10-2016, 09:41 AM
  #2109
Captcrunch44
Thanks trainer master that is a cool article
i hope to put that to good use soon
Old 12-16-2016, 11:00 AM
  #2110
VincentJ
VincentJ's Avatar
Brethren, found this very interesting (and informative) site that may be of use to some of you. If not anything else it will bring tears to you eyes and make your Sig heart beat a bit faster... How many of these do you currently own or had?
I currently have: Yak-18P NIB kit, Morrisey Bravo (on my build table as we speak), 1/4 scale Spacewalker (built and flying) and my Ryan STA (hangar queen)!!!
http://wanderings-ds.jimdo.com/sig-rc-kits-1-20/
Old 12-16-2016, 12:28 PM
  #2111
knuckleball
knuckleball's Avatar
I think the website owner is on this forum? Anyway it is a way back memory machine for sure, I found my first Sig kit the CL-3 Chipmunk 1967 Designed by: Jim Van Loo, Modified by Mike Stott. Mike Stott's SIG Banshee still seems to be a top seller after all these years I built and flew one around 1980.
Thanks for the link!
Old 12-16-2016, 01:15 PM
  #2112
skylark-flier
skylark-flier's Avatar
I'm glad people are still finding the site interesting - yeah, it's mine. Also, still looking (without much hope) for the RC-10 and RC-11 Simco, and any others that might pop up out of the blue. As far as I know, the only kits/ARFs missing are the RC-10 and RC-11, but some time back I DID manage to come across a very old set of free-flight SIG plans that nobody knew even existed (Auntie-Freez) - so there still might be others out there. BTW, the new RC-107EPARF EDGEtra is on-site already.
Also, before things get past me (easy to do these days) I want to wish all a Merry Christmas and a safe & Happy New Year.
Old 12-16-2016, 01:23 PM
  #2113
FlyerInOKC
FlyerInOKC's Avatar
Old news Viinny, but don't you just love seeing those old assembly manuals again and again?
Old 12-17-2016, 04:42 AM
  #2114
VincentJ
VincentJ's Avatar
I don't know how I missed it? Dave you did a Great Job compiling all those kits/planes on one site. There is a lot of useful information in there to be sure...I want them all!
Old 12-24-2016, 01:00 AM
  #2115
jeffie8696
jeffie8696's Avatar
As of today I have owned every Four Star size.
Old 12-24-2016, 03:20 PM
  #2116
knuckleball
Looks good, I like the solid red.
Old 12-27-2016, 09:09 PM
  #2117
skylark-flier
WOW! That's a BIG 4*!!! Finally back from the coast and saw it - - pretty cool.
Old 12-28-2016, 04:58 AM
  #2118
Captcrunch44
Well just got started building up airplane stock for Sig next year. Here's the first one.
And jeff that is a vary good looking plane and awesome flyer. Well done. One word of advice on hot sunny days keep the dark canopy covered or it could look like ths
ID:	2194630   Click image for larger version
Old 12-28-2016, 06:00 AM
  #2119
FlyerInOKC
FlyerInOKC's Avatar
Looks like a keeper!
Old 12-28-2016, 07:48 AM
  #2120
oliveDrab
oliveDrab's Avatar
Here's a 4Star 120 ... the 4-bladed prop is just for taking pictures. I would never fly with it.
That's a 4Star 60 on the floor.
Name:	4-bladed 4Star120 006.JPG
Old 12-28-2016, 12:22 PM
  #2121
jeffie8696
jeffie8696's Avatar
So far I rteally like all the 4Stars I have owned but the 20 is my favorite. I have high hopes for the 120. My Irvine 120 should pull it around really well. It appears to have been built very well but never completed. It has MAP servos in the wing, I have never even seen that brand although I suspect they are Multiplex. I replaced them with good new Hitec servos, 645MG.
Old 12-28-2016, 12:51 PM
  #2122
acdii
The 645MG work perfect for this beast, running them in mine too.
Old 12-28-2016, 01:10 PM
  #2123
jeffie8696
jeffie8696's Avatar
Thats good to hear, I also have a set of them in my 4Star60 and they are doing a great job, Using them with a Life receiver pack
Old 12-29-2016, 06:19 AM
  #2124
FlyerInOKC
FlyerInOKC's Avatar
Guys, I would like to give SIG a big shout out for having the courage to bring out a new kit in a new size the Rascal 168" WS beauty! We need to recognize they actually got off the laurels and made a NEW kit! They didn't just talk about it they put skin in the game and made the investment (I'm sure it isn't cheap) to produce an all NEW kit from the ground up! There are a lot of companies out there, some larger some aren't, that don't have the faith in the hobby or us builders to step up and do what SIG did!
HATS OFF TO SIG!!!!
Old 12-29-2016, 06:33 AM
  #2125
acdii
hmm copy and paste from rcg?
pssst you forgot an f.
