Reload this Page >
Balsa USA Brotherhood
Old 11-10-2017, 12:50 PM
  #1701
TomCrump
TomCrump's Avatar
Minwax has Polyurethane, which is oil based and fuel resistant. It has Polycrylic which is water based, and isn't.
Old 11-10-2017, 01:42 PM
  #1702
smkrcflyer
smkrcflyer's Avatar
Originally Posted by GerKonig
Thank you both. Yes I was aware of the HD color matching services. But since I do not have a compressor o spray painting gear, i thought perhaps there was a aerosol rattle can available close to the solartex cub yellow ... It will be gas powered. Will check the Mniwax Poly, isthi s water based polyurethane? what finish do you use (gloss, etc.)
Gerry
I also have a framed DVII. Will finish that one after the cub. The Fokker will be colorful (LOTHAR's mount) yellow, red, white, lozenge. Electric power most likely
I found a color of Rust-O-Leum that's close to cub yellow, its golden sunset. Got it at Wallmart for $2 a can. Its cheep so you can spray some on a small piece of covering to see if it matches.
Old 11-10-2017, 03:50 PM
  #1703
hairy46
Default Thanks
Originally Posted by foodstick
Hairy, I had a friend build one of the Delta wing seaplanes from BUSA.. Maybe there is only the one? Anyhow I think he used balsa on the bottom of the fuse and glassed it.. But he ended up going to liteply and glassing it after a few flights. He is not a bad flier but he said it just didn't hold up to the abuse on the landings.
hope this saves you some trouble.
Light ply on at least the step glassed makes good sence thanks!
Old 11-10-2017, 03:55 PM
  #1704
hairy46
Default Might be able too
Originally Posted by jwrich
I never built one but a friend had one and he loved it. When he was not at his pond he flew at our field off the grass. Will you be doing a construction article, I don't thing think I have seen one done here.
Rich
Not sure but might be able to do a build thread. May take a bit beings I work so much. But it will include a bit of glassing.
Old 11-10-2017, 07:14 PM
  #1705
redtail
My Feedback: (15)
redtail's Avatar
Please add me to the Balsa USA Brotherhood. Does anyone make fiberglass parts for the Balsa USA models? Is Fiberglass Specialties still in business? Thanks. Chic
Old 11-10-2017, 08:41 PM
  #1706
jeffEE
jeffEE's Avatar
First modification is in the books. I think I will sheet the bottom of the aileron. I always thought it was a bit easy to distort. I have never noticed a problem during flying, but I am going to do it anyway.
Old 11-11-2017, 06:06 AM
  #1707
R/C Art
My Feedback: (38)
R/C Art's Avatar
Yes. Just Google it.
Old 11-11-2017, 06:30 AM
  #1708
spaceworm
Default Wing tip ailerons.
How effective are/were the wing tip ailerons? TIA.
Originally Posted by jeffEE
My next Balsa USA DVII (my 5th I think) build is on the boards. .... First thing to go is the silly round ailerons. They should be more square. I was going to add the cut outs on the leading edge of the wings, but I think the other times I have done that it weakens the wing a lot. ...
Old 11-11-2017, 07:29 AM
  #1709
jeffEE
jeffEE's Avatar
They were much more responsive than I thought they would be. Rolls are easy. I just think they are a bit easy to distort so I will add the solid sheet on the bottom.
My first DVII shows a few rolls and loops. I think it is one of the best flying warbirds for WWI airplanes.
Old 11-11-2017, 08:20 AM
  #1710
hairy46
Default Awesome maiden!
Thank you so much for sharing it!
Old 11-12-2017, 07:23 AM
  #1711
jwrich
My Feedback: (17)
jwrich's Avatar
Redtail, Do you fly a Balsa USA airplane or building one? To be part of this group, you must fly or built one of their kits. This is the rule that was established long before I took over managing the thread. Posting a picture of your plane is required also. I am proud to be part of this wonderful group of modelers.
Fair Winds & Happy Flyin'
Rich
Old 11-12-2017, 07:54 AM
  #1712
TomCrump
TomCrump's Avatar
Smile
Rich
+1
Old 11-12-2017, 08:14 AM
  #1713
redtail
My Feedback: (15)
redtail's Avatar
Rich,
Thank you for asking about my wanting to join the Brotherhood. Yes, I have a Balsa USA kit. I have a 1/4 scale Spad 13 kit I am going to modify from a Spad 13 to a Spad 7. I want to model the Spad 13 after the Spad 7 that the American, Eugene Bullard, a Black American, flew when he went to Europe to fight, first in the Foreign Legion, then in the French flying corp once he was injured. He flew with the French flying corp until the Americans came to join in the war. The Americans told the French that they had to relieve Bullard of his flying duties or they would not join the fight.
P.S. I am building the Charlie Kellogg TBF Avenger on the Warbird and Warplane Forum here on RCU.
Chic
Old 11-12-2017, 08:31 AM
  #1714
jwrich
My Feedback: (17)
jwrich's Avatar
Thanks Chic for responding. That's great! I built the Spad 13, very nice airplane. Will you be doing a construction thread, at least post a picture of your kit or work.
Rich
My Spad
ID:	2244631   Click image for larger version
Old 11-12-2017, 09:18 AM
  #1715
redtail
My Feedback: (15)
redtail's Avatar
Rich,
Nice looking airframe. Did you do a construction thread that "I" can follow during my build? What did you power it with? Did you split the top wing into 3 parts? Was asking about the fiberglass parts and I called Fiberglassspecialitics and did not receive a response. Did you use their cowl, valve covers, etc.? I will certainly do a build thread if you think I should since I am going to do some modifying. Did I get accepted to the Brotherhood? Again, thanks. Chic
Old 11-13-2017, 08:07 AM
  #1716
GerKonig
Thank you very much! Will tryt hat one first for sure.
Gerry
Old 11-13-2017, 08:33 AM
  #1717
jwrich
My Feedback: (17)
jwrich's Avatar
Welcome to the Brotherhood, Redtail, please post a picture of your Spad when you begin the build. The BUSA Spad is a challenging build, just read the instruction carefully and take your time. I did a construction article on RC Scale Builder.com, titled "Building the BUSA SPAD 13" in the Forum section, Balsa USA Kits, Page 5. The kit took me a long time to finish it because of health issues, it did turn out looking great. I sold it to a friend who needed a WWI airplane for a big Dawn Patrol event in Minnesota. Here is a picture
It would be helpful for me if all BUSA Brothers would post theirBUSA Brotherhood number in their signature. If I have missed anyone please let me know.
Balsa USA Brothers
#1 jwrich, (Rich), Enid, OK, USA
#2 Jeffo New Baltimore, MI, USA
#3 ARUP KY USA
#4 RCKen Lawton, OK, USA (RCU Forum Manager/Admin)
#5 mattnew, Haverhill, MA, USA
#6 surmovik60 VA USA
#7 GerKonig, Levittown, PA, USA
#8 Granpooba, Queensbury, NY, USA
#9 radfordc (Charlie), Lansing, KS, USA
#10 balsa brain, Jacksonville, FL, USA
#11 3136 Victoria Austrialia **
#12 wwoneguy, Beltsville, MD, USA
#13 vertical grimmace, Ft. Collins, CO, USA
#14 rcmiket, El Paso, TX, USA
#15 bpoates25, Riverview, FL, USA
#16 PiperDriver, Rolling Meadows, IL, USA
#17 68goat Alabaster, AL, USA
#18 jlsimon, Long Valley, NJ, USA
#19 pat s, Candor, NC, USA
#20 pending IN USA
#21 Steve Percifield, Noblesville, IN, USA (Sir Percy)
#22 opol, Two Harbors, MN, USA
#23 Zero, Houston, TX, USA
#24 tonyos, Madison Heights, VA, USA
#25 b206, Opdyke, IL, USA
#26 LonnieMcc, Carriere, MS, USA
#27 eindecer3, McMinnville, TN, USA
#28 flyer35, Ilion, NY, USA
#29 jeffEE, Farnington, NM, USA
#30 s3nfo, San Diego, CA, USA
#31 Kwikfli, Winfield, KS, USA
#32 JDHammer, Slippery Rock, PA, USA
#33 Ikruse, Lawton, OK, USA
#34 bobbailey, Chesapeake, VA, USA
#35 Vampire, Bath, PA, USA
#36 zemkes_wolfpack, Winamac, IN, USA
#37 triumphman49, Decatur, AL, USA
#38 SRQFlyer, Sarasota, FL, USA
#39 Daniel-EL, Maumee, OH, USA
#40 hairy46, Sinclair, WY' USA
#41 pettit, Durham, NC, USA
#42 Hrannar, Patrekfjordur, Iceland **
#43 lowbubba, Miamisburg, OH, USA
#45 FokkerD7, Cable, OH, USA
#44 FireBee, Chesapeake, VA, USA
#46 iampilot2, Middletown, OH, USA
#47 Wagon1,Penscola, FL, USA
#48 darren 4, Eau Claire, WI, USA
#49 Luxuswaffe, Hialeah, FL, USA
#50 dryverman, West Rutland, VT, USA
#51 otterrc FL USA
#52 cooper998, Newark, DE, USA
#53 lazyace, Buffalo, NY, USA
#54 wings2an3 Monroe, NY, USA
#55 The Pamster, Dallas, TX, USA
#56 lucasar15, Pottsville, PA, USA
#57 AMA74894, Spicer, MN, USA (Moderator Jim Buzzeo)
#58 squidman, Waco, TX, USA
#59 M_Callahan, South Lebanon, OH, USA
#60 Karp050555, Philadelphia, PA, USA
#61 optech, San Diego, CA, USA
#62 ashby NSW Australia **
#63 R/C Art, Shelbyville, IN, USA
#64 on_your_six MD USA
#65 Highflyer2, Alpharetta, GA, USA
#66 dddaviddean NJ USA
#67 Quagmire, Costa Mesa, CA, USA
#68 pending CA USA
#69 ratshooter, Burleson, TX, USA
#70 TXAG96, Augusta, MI, USA
#71 R/C Ray, Valley Cottage, NY, USA
#72 feep, Pelham, NH, USA
#73 sdcranford, Willard, MO, USA
#74 buzzard bait, Ithaca, NY, USA
#75 chadasmus, Freedom WI, USA, (BUSA Team Pilot, Builder and Designer)
#76 fokv25, Westfield, IN, USA
#77 Dynamic, Stratford, WI, USA
#78 WinterHawke, Waukesha, WI, USA
#79 t6racer NSW Australia **
#80 NM2K, Ringgold, GA, USA
#81 rcjunky67, Belleview, FL, USA
#82 AndyF Ft. Wayne, IN, USA
#83 freefall2907, Ottumwa, IA, USA
#84 a65l, Virginia Beach, VA, USA
#85 Grimracer, Urbana, IL, USA
#86 Corsair2013, Granytsville, UT, USA
#87 Chevelle NY USA
#88 eagledancer, Orlando, FL, USA
#89 Leroy Gardner ID USA
#90 ANZAC Australia **
#91 Spadsriver09, Southbend, IN, USA
#92 PSB, Malven, OH, USA
#93 bradpaul, Apopka, FL, USA
#94 MRadu, Los Gatos, CA, USA
#95 HorsePowerAviation, Cincinnati, OH, USA
#96 Shoestring, Granite, MN, USA
#97 David Gladwin, CookhamBerkshire, United Kingdom **
#98 Rich6170, Springfield, OH, USA
#99 Wildbills21, Menominee, MI, USA, (Team BUSA, pilot, builder,& chief mechanic)
#100 Rickj, Akron, OH, USA
#101 Geezeraviation (Doc), Houston, TX, USA
#102 Flyboy077, Uniontown, OH, USA
#103 Shelstrm. The other Doc), Lancaster, WI, USA
#104 Drude, North Port, FL, USA
#105 bschatz, West Hills, CA, USA
#106 RCDuffer, Valley Center, CA, USA
#107 capnpaul, Orillia, ON, Canada **
#108 p38nut, Indianapolis, IN, USA
#109 yoda64, Bloxon, VA, USA
#110 Jaybird, Hallowell, ME, USA
#111 mbnt, IL, USA
#112 Foodstick (Lance), Ankeny, IA, USA
#113 adec, Perthaustralra, Australia **
#114 Navy, Orange Park, FL, USA
#115 RD Jeff, Anchorage, AK, USA
#116 Mistral 12, Granbury, TX, USA
117 JKEpps, Greenbelt, MD, USA
#118 FlyerInOKC, Okla, City, OK, USA
#119 PT19, Buna, TX, USA
#120 Jim Scott, ?
#121 Srecker, Erie, PA, USA
#122 bigbird3, Williamstown, VT, USA
#123 Monsour, Fisherville, KY, USA
#124 Marksp (Mark), Redmond, WA, USA
#125 Quidleywins , Kyneton Victoria, Australia**
#126 M.Casper (Michael), Perry, IO, USA
#127 Twin_Flyer (Bill), Westhampton Beach, NY, USA
#128 Big Stikflyer (Jay), Machesney, IL, USA
#129 SkinnyBob (Bob), Park Falls, WI, USA
#130 Jetset, (Myles), Picton, ON, Canada**
#131 John Taylor, Macedon, NY, USA
#132 dwreel (Dick), Southern Pines, NC, USA
#133 jimbrock (Jim), Houston. TX, USA
#134 Bandit59, Irmo, SC, USA
#135 Check6, (Fred), N.Scituate, RI, USA
#136 OldScaleGuy, (Steve), Seymour, IN, USA
#137 N1EDM, (Bob), Brockton, MA, USA
#138 Str8aero, (Lee), Sheridan, WY, USA
#139 SAProbuster, (Bob), San Antonio, TX, USA
#140 TomCrump, (Tom), Traverse City, MI, USA
#141 spaceworm, (Richard), Guilford, CT, USA
#142 a8ter, (Larry), Dickinson, TX, USA
#143 NC state, (Tom), Albuquerque, NM, USA
#144 mac2286, (Jimmy), Commiskey, IN, USA
#145 crawler tech, Cocoa, FL, USA
#146 RobMason (Rob), Henderdsonville, NC, USA
#148 Redtail (Chic), Alexandria, VA, USA
Rich
Old 11-13-2017, 09:23 AM
  #1718
TomCrump
TomCrump's Avatar
Gerry
I painted my Cub, in that color. It's close, but it's not correct.
Old 11-13-2017, 09:32 AM
  #1719
mgnostic
mgnostic's Avatar
A question for builders of BUSA SPAD 13's amd SE5a's; What engines do you favor for these planes?
Old 11-13-2017, 09:47 AM
  #1720
RobMason
RobMason's Avatar
1/4 Fokker in the fog and on board video
ID:	2244933   Click image for larger version
ID:	2244934   Click image for larger version
ID:	2244935   Click image for larger version
ID:	2244936   Click image for larger version
ID:	2244954   Click image for larger version
Name:	20171108_080620 (2)small.jpg
Old 11-13-2017, 12:32 PM
  #1721
jeffEE
jeffEE's Avatar
Rob....Nice DVII.
Top wing mostly built. I went ahead and added the leading edge cutouts. What the heck, it's either scale or its not. And here is the set up for the ball and cup "N" strut attachments. The ball, the cup and how it should look after the part is covered. It just screws into each strut end. Not perfect scale, but the attempt is there.
ID:	2244961   Click image for larger version
Old 11-18-2017, 11:58 AM
  #1722
Shelstrm
My Feedback: (9)
Shelstrm's Avatar
Rich, here is a list of BUSA Brothers I copied from one of your earlier posts. At least it goes up through number 108. Hope this helps.
Doc S
BUSA brothers
#1 Jwrich OK USA
#2 Jeffo MI USA
#3 ARUP KY USA
#4 RCKen OK USA
#5 mattnew MA USA
#7 GerKonig PA USA
#8 Granpooba NY USA
#9 radfordc KS USA
#10 balsa brain FL USA
#12 wwoneguy MD USA
#13 vertical grimmace CO USA
#14 rcmiket TX USA
#15 bpoates25 FL USA
#16 PiperDriver IL USA
#17 68goat AL USA
#18 jlsimon NJ USA
#19 pat s NC USA
#20 pending IN USA
#21 Steve Percifield IN USA
#22 opol MN USA
#23 Zero TX USA
#24 tonyos VA USA
#25 b206 IL USA USA
#26 LonnieMcc MS USA
#27 eindecer3 TN USA
#28 flyer35 NY USA
#29 jeffEE MN USA
#30 s3nfo CA USA
#31 Kwikfli KS USA
#32 JDHammer PA USA
#33 Ikruse OK USA
#34 bobbailey VA USA
#35 Vampire PA USA
#36 zemkes_wolfpack IN USA
#37 triumphman49 AL USA
#38 SRQFlyer FL USA
#39 Daniel-EL OH USA
#40 hairy46 WY USA
#41 pettit NC USA
#42 Hrannar Iceland **
#43 lowbubba OH USA
#45 FokkerD7 OH USA
#44 FireBee VA USA
#46 iampilot2 OH USA
#47 Wagon1 FL USA
#48 darren 4 WI USA
#49 Luxuswaffe FL USA
#50 dryverman VT USA
#51 otterrc FL USA
#52 cooper998 DE USA
#53 lazyace NY USA
#54 wings2an3 NY USA
#55 the pamster TX USA
#56 lucasar15 PA USA
#57 AMA74894 MN USA
#58 squidman TX USA
#59 M_Callahan OH USA
#60 Karp050555 PA USA
#61 optech CA USA
#63 R/C Art IN USA
#65 Highflyer2 GA USA
#67 Quagmire CA USA
#68 pending CA USA
#69 ratshooter TX USA
#70 TXAG96 MI USA
#71 R/C Ray NY USA
#72 feep NH USA
#73 sdcranford MO USA
#74 buzzard bait NY USA
#75 chadasmus KY USA (BUSA Team Pilot, Builder and Designer)
#76 fokv25 IN USA
#77 Dynamic! WI USA
#78 WinterHawke WI USA
#80 NM2K GA USA
#81 rcjunky67 FL USA
#82 AndyF IN USA
#83 freefall2907 IA USA
#84 a65l VA USA
#85 Grimracer IL USA
#86 Corsair2013 UT USA
#87 Chevelle NY USA
#88 eagledancer FL USA
#91 Spadsriver09 IN USA
#92 PSB OH USA
#93 bradpaul FL USA
#94 MRadu CA USA
#95 HPA OH USA
#96 Shoestring MN USA
#97 David Gladwin United Kingdom **
#98
Rich6170 OH USA
#99 Wildbills21 MI USA (Team BUSA pilot, builder and the chief mechanic)
#100 Rickj OH USA
#101 Geezeraviation TX USA
#102 Flyboy077 OH USA
#103 Shelstrm WI USA
#104 Drude FL USA
#105 bschatz CA USA
#106 RCDuffer CA USA
#107 capnpaul Orillia, ON, Canada**
#108 p38nut IN, USA
Old 11-18-2017, 09:51 PM
  #1723
jwrich
My Feedback: (17)
jwrich's Avatar
Doc, Can't you see the last list I posted Nov. 13 and the last new member was #148. Once before folk were having problem the complete list, that was a RCU problem.
Ricxh
Old 11-19-2017, 06:05 AM
  #1724
jeffEE
jeffEE's Avatar
this is the last list I saw.
#3 ARUP KY USA
#20 pending IN USA
#29 jeffEE, Farnington, MN, USA
#51 otterrc FL USA
#68 pending CA USA
#87 Chevelle NY USA
#111 mbnt, IL, USA
#120 Jim Scott, ?
#148 Redtail (?), Alexandria, VA, USA
Old 11-26-2017, 07:53 PM
  #1725
D PAYNE
My Feedback: (22)
Default Dvii
Hello All,
I am working on a 1/3rd scale D-VII and I am looking for the perfect motor for it. I figured this would be a good place to ask. I would like to find the best option for the least vibration. I have been looking at 4 stroke gas twins but I have not found one yet that would fit in the fuse and have good power. Any suggestions and or experiences of any kind would be welcomed and appreciated. Just looking for the least vibration, best fit, and good power.
Thanks!!
