Where have all the builders gone
#1602
These people make a wiper system I used for both the MGB and Pantera:
https://www.specialtypowerwindows.com/
Combat, I have read that one of the reasons for such prevalent rust in 70's cars is that due to labor problems in Europe a lot of auto manufacturers ended up buying lower quality steel from China. I think the disaster of Mao's "Great Leap Forward" had passed but the Chinese steel was still no great shakes.
#1603
Finding all the little bits and pieces for that car [like a complete body rubber kit] might be difficult.
The electric windows is a real problem solver compared to dealing with after market window cranks that don't work as good as OEM.
#1604
I think a good sheet metal recipe would have some nickle to inhibit rust...like the Model A Fords have.
In the 1970s I've seen some American cars that went totally unprimered / unpainted where most people never look.
In Germany.... car companies couldn't get away with that
They have mandatory annual car inspections
The car is put up on a lift and every inch of it is inspected for any little signs of rust and mechanical issues.
Once a car becomes too far gone to be worth fixing then they'll sell it to an American GI.
#1605
gow.....I made a note about that and said "hmmmmm look at that..!".......as I watched the video about your Pantera.
gow589 (12-31-2022)
The following 2 users liked this post by combatpigg:
mgnostic (01-07-2023),
RICKSTUBBZ (01-07-2023)
#1608
OK here we go...sorry about the annoying buzzing noise from the "yard light" that I forgot to turn off.......https://youtu.be/vs9orXv1fwM
#1610
Oh yeah!
I always love that sweet sound....(the engine, while the light was cool too)
and the Datsun doesn't look too bad either.
#1611
For those who might be curious about the Blueprint Engines 347....it's a copy of the Ford Motorsports 415 HP Crate Engine...but it sells for much less.
Mine has non-adjustable rockers..which was a huge disappointment when I first discovered that. It wouldn't be a big issue..but the original valve job that came with the engine failed within 7000 miles and I had to take the heads to a local specialist to have then done correctly. Once this happens then I needed to get a rocker arm pedestal shim kit in order to re-establish the proper preload /rocker geometry on the hydraulic lifters.
The engine doesn't like to be revved past 5500 rpm. with the "proprietary" hydraulic roller cam.
The engine has the same basic bore stroke as a .040" bored Mopar 340...but I'm not sure about the rod length.
I wonder if this engine got the same love when Blueprint balanced it .....that my local Balancing Specialist would give it...?
If it was geuine FoMoCo...I wouldn't have these doubts...but you pay for that peace of mind.
It makes great power all the way to 5,500..but you really need to be "on the stick" to keep the first 2 shiftpoints from over-revving.
I need to get the MSD with rev-limiter.
I would not recommend this engine to a serious Weekend Warrior Bracket Racer...but for the way I use it ...it's OK.
I bought the long block engine about 5 years ago for about $4500 and It is shocking to see how much money it goes for now.
#1612
Engines are fun. I built the nascar engine from a Virgin gm performance block specking all components. 18° aluminum heads, 12.5:1 compression. Even installed piston squirter. You can hear the car from the next town over. Never been in a car like that before. Going over a hill at Road Atlanta, at any speed, it spins the tires if you don't lift. Alot of fun!
#1613
I had to look up what "PISTON SQUIRTERS" are.
#1614
combatpigg (01-08-2023)
#1616
You had better have safe search turned on before you google "piston squirter". Back to automotive thoughts, I dimly remember rebuilding an engine for a Suzuki Sidekick and it seems there was an orifice on the rod that points a squirt of oil at the bottom of the piston. I've also dealt with rocker pedestal shims in a 948 cc Austin A series engine. Even with adjustable rocker arms you need the shims to maintain the correct geometry if you skim the heads or engine deck. It entertains me to see how much of the stuff I learned from ford and Chevy V8s applies to the little British engines.
The following 2 users liked this post by mgnostic:
combatpigg (01-08-2023),
gow589 (01-08-2023)
#1617
Gas certainly is not cheap. It's more than doubled in the last 2 years. A lot of new performance engines actually have piston squirters not. I also put an oil accumulator in it. It didn't need it for driving as it's a dry sump but it allows me to start oil pressure before starting the engine. I limited rpm at 7,000 rpm for longevity (hopefully at least some) but I think it would happily go to 9k.
Look at the mandrel bends in those frame rails and what looks like a massive anti-roll bar and a very stout looking steering box ..
I love seeing the Old SBC hasn't been totally replaced..
Pre oilers....my guess is they are standard with some really expensive industrial engines...?
How many guys does it take to remove the body...?
#1618
#1620
Now gather around for my amazing engine story...about a 351W on a Friday Night at the 1/4 mile track [Bremerton Raceway]
At the end of another typical 13 second 105 mph run a puff of black smoke came out the hood of my 3400 pound Falcon Ranchero.
Shortly afterwards the engine started locking up and I barely made it back to the pit area before the engine totally seized.
The oil on the dipstick looked like metalflake paint.
I planned on calling AAA towing if this ever happened..but I still needed to get the car off the race track property before making the call. Problem is my "crew" was stuck in traffic after working overtime at his job.
A couple hours passed and as darkness settled I gave the starter a try..AND IT STARTED but it sounded like a rock crusher. I couldn't believe my luck and made a bee line to the exit..!
At first I thought I'd just drive to the freeway on ramp and park it..but my curiosity was too great So I kept going.
In overdrive the car was going 50 mph at about 1700 rpm IIRC.
Any way the miles just kept rolling by as I passed by Tacoma, Seattle, Everett and finally Arlington..but the biggest test was to see if THE LITTLE ENGINE THAT COULD would make it up the hill to my house.
It seemed to really struggle but it made it all the way into the barn..HA HA..!
120 miles home.... 2 rods that shared the same journal had no bearing material left on them and were totally black and blue from all the heat.
Next day the Machinist let me know that 351s don't like as much timing as I was running..[he raced 351s for many years on oval track]
gow589 (01-08-2023)
