Reload this Page >
Sig Kadet MkII build
Old 08-13-2016, 06:03 PM
  #226
KenChoo
Hey guys, I gotta say I really appreciate the encouragement from you all...your support is priceless, thank you.
Ken
Old 08-14-2016, 04:50 PM
  #227
FlyerInOKC
FlyerInOKC's Avatar
Originally Posted by KenChoo
Thanks Mike (FlyerInOKC) and Jim (buzzardbait),
Truth be told it's not as good as the photos make it out to be, but from 5 feet away it's decent enough! :-). Yeah, I'm glad the toughest part is over. Once I get the wing done I can focus on something other than painting at least :-)
cheers,
Ken
It takes at least 10 feet to make my airplanes look really good! ;-)
Old 09-26-2016, 08:49 PM
  #228
KenChoo
Wing is painted! Last bit for painting...the cowl. :-)
ID:	2183004   Click image for larger version
Old 09-26-2016, 09:02 PM
  #229
skylark-flier
skylark-flier's Avatar
Geez man, I'm going to let you paint my planes from now on. That bird looks GOOD!!!
Old 09-27-2016, 04:51 AM
  #230
buzzard bait
I agree, you've made a beauty of her!
Just to recap the method, you painted Nelson paint over Solartex using a bristle brush, right? I know it was a lot of work, but compared to what I've been doing, spraying dope, it seems so much better. I was constantly trying to save on solvent, but then having to use a lot to clean every nook and cranny in the spray gun, getting on my hands, breathing it, paying for it. Your method sounds so much better, and now we know it can look terrific too! Thanks for these posts; keep up the great work!
Jim
Old 09-27-2016, 04:53 AM
  #231
buzzard bait
One more thing: will you be able to tell us the weight gain from the paint?
Thanks again.
Old 09-27-2016, 06:43 AM
  #232
KenChoo
Thanks Dave, Jim!
Jim, yeah, it was brushed on System 3 paint from Nelson's, but I did use a foam brush for the wing just because I didn't have a good width bristle brush to use for that large surface, but I got better using the foam brush with practice. I do like the non-toxic aspect of this paint...
I'm afraid I didn't weigh the airframe prior to painting so I'm not sure how much was added, but I'll get a ready to fly weight when she's done...
cheers!
Ken
Old 09-27-2016, 08:58 AM
  #233
buzzard bait
Thanks Ken, I usually forget to do the "before" weigh too, just hoping maybe you did it. Will be interested in the final weight and test flight. Jim
Old 09-27-2016, 09:01 AM
  #234
FlyerInOKC
FlyerInOKC's Avatar
She is a beauty great job Ken!
Old 09-27-2016, 03:47 PM
  #235
KenChoo
Thanks Mike!
Old 09-29-2016, 09:13 AM
  #236
KenChoo
Guess what got painted? These sudden bouts of productivity are hilarious...
P.S. I wet sanded the ABS cowl with 320 sandpaper, which was perfect to remove the gloss and create a suitable surface for the paint.
ID:	2183421   Click image for larger version
Old 09-29-2016, 10:28 AM
  #237
FlyerInOKC
FlyerInOKC's Avatar
Now that;'s dead sexy!
Old 09-30-2016, 06:44 AM
  #238
DBD1
DBD1's Avatar
Turned out real nice. Looks great Ken.
Don
Old 10-01-2016, 10:19 AM
  #239
H5606
Hard to believe such nice results with a brush; looks really great; looking forward to completed airplane pics.
Old 10-06-2016, 10:21 AM
  #240
KenChoo
Hi guys,
I got quite a bit done this week. The plane is pretty much ready except for the placement of the RX, battery, and switch! I did weigh it all though, just excluding the RX, and it turned out to be 1oz shy of 5lbs (i.e. 4lbs, 15oz). So with a couple of ounces for the RX it'll just be about 5lbs. I'm frankly amazed! Using the Solartex and painting over it didn't add all that much weight it seems (either that or it was a fairly light airframe before covering). So that's all good.
Enjoy the pics...just gotta install the receiver, battery and switch, then balance, and finally run in the engine. I didn't expect the build to take quite this long (about a year since starting) but it was a wonderful experience all-in-all. Thanks everyone for following along and the tips and encouragement along the way!
Cheers,
Ken
ID:	2184653   Click image for larger version
ID:	2184654   Click image for larger version
ID:	2184655   Click image for larger version
ID:	2184656   Click image for larger version
ID:	2184657   Click image for larger version
ID:	2184658   Click image for larger version
Old 10-06-2016, 10:27 AM
  #241
FlyerInOKC
FlyerInOKC's Avatar
Great looking bird Ken! I can't wait o see it take flight!
Old 10-06-2016, 04:10 PM
  #242
skylark-flier
Yup! Well done, indeed!!! Looking forward to flight reports and pics.
Old 10-06-2016, 09:13 PM
  #243
Tom Nied
Tom Nied's Avatar
That's really nice work Ken. I've been building models for a long time and that Kadet of yours is well built and finished. Congratulations to you. Very nice job.
Old 10-11-2016, 07:39 PM
  #244
KenChoo
Thanks all for the kind comments...
I found that to balance in the middle of the CG range indicated, the RX battery has to go just under the fuel tank, and the RX itself and switch can be right in the middle of the radio compartment. I haven't installed the switch yet but I wanted to show how I mounted the RX.
Continuing in the spirit of trying new things (to me) in this build, I recalled a method I saw on Jim John's old pattern website from the late 1990's - I'd never mounted a receiver this way before but somehow remembered the concept and gave it a go...it works great! I fashioned two "H" brackets using scrap from the kit box, and with 4 rubber bands mounted as shown in the picture below. It's very lightweight, secure, offers excellent vibration damping, and is very easy to access the RX.
Cheers,
Ken
ID:	2185440   Click image for larger version
Old 10-12-2016, 04:46 AM
  #245
FlyerInOKC
FlyerInOKC's Avatar
That is a neat may too mount the receiver and the rubberbands are easily replaced too.
Old 10-12-2016, 01:43 PM
  #246
buzzard bait
Yes, that looks like a good method. My one question is, won't it work its way forward on each landing, and what happens in a crash?
A friend tried a gyro on a four stroke powered plane and the gyro failed due to vibration. Maybe this method would prevent that.
Jim
Old 10-12-2016, 02:04 PM
  #247
Tom Nied
Tom Nied's Avatar
Personally, I'd rather mount the rx solidly with a piece of foam rubber wrapped around it.
Old 10-12-2016, 02:05 PM
  #248
FlyerInOKC
FlyerInOKC's Avatar
Jim
If this system will hold the RX in extreme manuvers I don't see why it wouldn't hold in a crash provided there was no structural damage in the area of the "H" brackets. Then again if the structure was damaged that far back it wouldn't matter how you mounted it. It seems to me if the Gyro was held at the correct level it should work.
Old 10-12-2016, 02:15 PM
  #249
FlyerInOKC
FlyerInOKC's Avatar
They don't recommend you do that with 2.4 Ghz Receivers because it interferes with the antenna orientation requirements.
Old 10-12-2016, 02:30 PM
  #250
Tom Nied
Tom Nied's Avatar
I do it all the time and provide mounted straws that orientate the antenna leads
