Reload this Page >
New Balsa USA Smoothie XL Build
Old 03-02-2017, 09:48 AM
  #176
Check6
My Feedback: (427)
ID:	2203651   Click image for larger version
ID:	2203652   Click image for larger version
ID:	2203653   Click image for larger version
Old 03-10-2017, 02:47 PM
  #177
Check6
My Feedback: (427)
I was able to get some red trim on the wheel pants.I sprayed this in the cellar. We are bracing for another Nor Easter this Tues 3/13. Fortunately we are leaving for Fl. this Mon. LOL.
This will give you an idea of the final color scheme. I'm basically duplicating the box scheme.
Old 03-10-2017, 02:48 PM
  #178
Check6
My Feedback: (427)
Looks like the trim is slightly different on each pant. Good thing you only see one side at a time. LOL
ID:	2204808   Click image for larger version
ID:	2204809   Click image for larger version
Old 03-12-2017, 04:43 AM
  #179
Check6
My Feedback: (427)
Got the top and bottom trim done on the wings. Wind chill yesterday of 5 below. Was able to use a heat gun on it in my garage. I do have some touch ups to do. I used black vinyl electrical tape which is very sticky. Pulled off some of the paint. Hope I can touch it up so it doesn't look too bad. Top of the wing is straight trim. Bottom is scalloped.
Old 03-12-2017, 04:44 AM
  #180
Check6
My Feedback: (427)
ID:	2205004   Click image for larger version
Old 03-12-2017, 11:57 AM
  #181
Calvinman
Looks great Check Six! I think a little citrus based cleaner will remove the tape residue.
Calvi
Old 03-12-2017, 12:40 PM
  #182
Check6
My Feedback: (427)
Cleaner won't help. The little white areas is the actual white solartex fabric. If I had used the correct trim masking tape ,which is a blue vinyl tape that is very flexible and low tack, I wouldn't have had a problem. I think 3 M makes it and it's pretty expensive. Next time I will use it and alleviate all my problems. I will be painting the trim on the fuse next.
Old 03-18-2017, 03:37 PM
  #183
Check6
My Feedback: (427)
Got the trim painted on the fuse. I wasn't happy in some spots where the paint interacted and left some blemishes. I can live with it, I'm sure I'll have a lot more once I start flying it. LOL Have to install the trim pin striping tape.
Old 03-18-2017, 03:39 PM
  #184
Check6
My Feedback: (427)
ID:	2205994   Click image for larger version
ID:	2205995   Click image for larger version
ID:	2205996   Click image for larger version
Old 03-19-2017, 04:38 AM
  #185
Calvinman
looks great!
Old 03-19-2017, 05:19 AM
  #186
Check6
My Feedback: (427)
Thanks, Calvinman, I appreciate it.
Fred
Old 03-19-2017, 06:51 AM
  #187
jwrich
My Feedback: (17)
jwrich's Avatar
Job well done It should fly great, post some pictures at the field, video would be too.
Fair Winds & Happy flyin'
Rich
Old 03-19-2017, 09:17 AM
  #188
Check6
My Feedback: (427)
Thanks, Rich, I appreciate it. Weather has been very cold and windy. No flying anytime soon.
Fred
Old 03-19-2017, 02:21 PM
  #189
pappy35
Looks great. Once you have everything installed you'll have to weigh it and let us know.
Old 03-19-2017, 04:04 PM
  #190
Check6
My Feedback: (427)
Thanks Pappy 35,
Will do.
Fred
Old 03-20-2017, 06:44 PM
  #191
swift bill
Ready to go
Old 03-21-2017, 03:11 AM
  #192
Check6
My Feedback: (427)
Hi SwiftBill,
Awesome Job!!! Did you cover it with plastic film?? I'm not to proficient with film covering,all of my planes are fiberglassed. What's the finished weight? What's in it for power?
Fred
Old 03-21-2017, 02:48 PM
  #193
Check6
My Feedback: (427)
Got the canopy fitted and glued in. I faired it in with epoxy and baking soda mixture. I am not happy with the paint job. Rustoleum crinkled a little on the touch up coat. Right now I want to finish it and fly it. Down the road If I still have it I will sand it down and re paint with Krylon paint. I have much better luck with Krylon and dries in 12 min. Should have used that .Anyway, I'm installing the engine and radio gear now, so it's almost ready for flight. Weather is taking a real cold turn. Going down to 8 degrees tonight. This is New England for you. Today it was 55 degrees and sunny tonight 8 degrees.
Old 03-21-2017, 02:49 PM
  #194
Check6
My Feedback: (427)
ID:	2206444   Click image for larger version
ID:	2206445   Click image for larger version
Old 03-21-2017, 04:54 PM
  #195
swift bill
Painted solartex. Kloss Kote dark blue paint on 30 year old light blue Hobby Poxy $5 pint, I've had it a while.
Old 03-21-2017, 04:58 PM
  #196
swift bill
I have a Saito 180 gas conversion living in north Florida now maiden next week. I'm from Middletown RI.
Old 03-21-2017, 05:00 PM
  #197
swift bill
I can't find the control throws in the Manuel. Do you know what they are?
Old 03-21-2017, 05:22 PM
  #198
swift bill
https://www.facebook.com/william.top...0180814089177/
ID:	2206455   Click image for larger version
ID:	2206456   Click image for larger version
Old 03-22-2017, 05:46 AM
  #199
pappy35
Swift,
I don't have them handy but I know I posted then either in this thread or somewhere in mine. I asked Chad Asmus via FB Messenger.
Old 03-22-2017, 06:15 AM
  #200
Check6
My Feedback: (427)
Pappy 35 you had them posted on your 1 st page one from the bottom,
Swift here they are:
CG 4 3/8 in. from LE
Elevator: 1 in. up 3/4 in. down
Rudder: 1 1/2 in Left and Right
Ailerons: 3/4 in. up and down
Hope this helps
Fred
