Troublemaker 60 >
Troublemaker 60
Troublemaker 60
Old 02-10-2024 | 11:09 AM
plumberdeluxe's Avatar
My Feedback: (209)
Wing panels are framed and ready to join. I’ll rough shape leading edge first, then add ailerons, trailing edges in the center, and wingtips. This short kit thing is really kinda cool, get to use some wood that has been setting in a box for years…………🤓
Old 02-10-2024 | 01:46 PM
My Feedback: (209)
Wing is joined and straight and strong. I’ll do tips and trailing edges later.
Time to get the stab out of the way, this is sheeted in 1/16 all top and bottom……..
Old 02-10-2024 | 02:42 PM
My Feedback: (209)
Nice little lifting stab here, I will skin it next, make a piano wire joiner and add tips and elevators…………🤓
Overall this is going pretty well, hats off to the folks at Eureka, the precision cut parts are very nice. I will most likely be doing more of these short kits as they have a sweet selection of old vintage pattern planes.
Old 02-10-2024 | 04:20 PM
RICKSTUBBZ's Avatar
Not bad for a days prep and a couple days work.....
I am curious to see how or what you do for the "CANAPY" area.
What I was able to see on the plans is all blocks sanded to a canopy shape and do the rest with covering?
Old 02-10-2024 | 04:51 PM
My Feedback: (209)
Yeah it amounts to 2 balsa blocks, I'm not sure what I'll do yet. Seems like I'm digging for wood alot.
I have 3 large boxes and a stand up rack with wood to choose from. The rack is easy and organized, the boxes are messy
I have 3 large bags of blocks also, so it seems like digging for the next few pieces is what I've been doing mostly.
Wing after joining weighs 19 oz.....................
Old 02-11-2024 | 07:41 AM
  #31
My Feedback: (209)
Here’s the stab started, should be light and strong..💪
Those silly valves have really paid off over the years………..
Old 02-11-2024 | 08:51 AM
  #32
My Feedback: (209)
Going well, stab is falling together with tips installed but not yet shaped. I gotta step away and take my daughter out for a nice birthday lunch………Sawdust will not make things better right now………😝
Old 02-12-2024 | 06:29 AM
  #33
My Feedback: (209)
Stab is rough shaped, hinged, and can be se off to the side. Weight is 3.1 oz.
Old 02-12-2024 | 07:21 AM
  #34
RICKSTUBBZ's Avatar
Those tapered elevators are interesting.
I wonder if that was an aesthetics thing or if there was a perceived performance advantage.
Old 02-12-2024 | 07:35 AM
  #35
My Feedback: (209)
I'm not sure Rick,
What I do know is my wing and tail combined weight is 1 lb. and 6 oz.
I like that and hope for decent weights as I move along..........................
Still need to add tips and ailerons, but all is well at this point
Old 02-12-2024 | 10:37 AM
  #36
My Feedback: (209)
Here’s the rudder all hinged and ready. It came in at 1.9 oz.
Everything setting on the table has a total combined weight of 1.5 pounds.
On to the fuse………….
Old 02-12-2024 | 11:03 AM
  #37
My Feedback: (209)
Here is the Eureka short kit fuse parts laid out over the plans, these guys really use excellent wood and the cutting is probably the best I have seen.
I think I’m going to change the engine I was planning on using to a Super Tigre S-61 ABC. I have a better selection of headers and this may be a better way to go for this plane. I may mount the engine strait up or at a nice 45 degree angle and have the pipe lay right down the side around mid-fuse……..Excellent power, just not the higher rpm’s like the VF would give.
I'll decide shortly, once I get started on the fuse.........
Old 02-13-2024 | 10:25 AM
  #38
My Feedback: (209)
Here’s the fuse sides settings on the tail and wing, so far so good,
time for some formers…………….
12.7 oz. For sides, formers, and firewall but no formers glued yet.
This is interesting as my all up weight at this point is 37.7 oz. or 2 pounds 6 oz.
Still lots to add but the weight is at a great place……so far
Old 02-14-2024 | 06:33 AM
  #39
My Feedback: (209)
Most interesting fuselage I’ve ever built, at its widest point it is only 3” wide……….
All formers glued except firewall, weight is 12.5 oz.
Old 02-14-2024 | 12:09 PM
  #40
My Feedback: (209)
Starting to take shape, waiting on an engine mount to show up so I’m doing small stuff to keep moving.
This short kit concept is much easier than I expected……
Old 02-15-2024 | 02:40 PM
  #41
My Feedback: (209)
Well the engine mount arrived today, so the firewall is installed, engine mounted, all rods and gear attached.
It is almost time to sheet the top and bottom of the fuse and get ready to make a front end and spinner ring.
so far so good.............................................. ....
RICKSTUBBZ (02-15-2024)
Old 02-16-2024 | 09:33 AM
  #42
My Feedback: (209)
Fuselage top and bottom sheeting is added. All pushrods are made and ready to go. Fuse weight with mount, front gear, and 16 oz tank comes in at 1.5 pounds. So total weight of balsa components comes up to 3 pounds. I like where the weight is at. Finished plane recommended weight is 6.5 to 7.5 pounds……….
Old 02-16-2024 | 02:14 PM
  #43
My Feedback: (209)
Now begins the long process of shaping, carving, and sanding the fuselage into a rounded structure instead of boxy and square. Good thing is that weight comes off, hard to say how much…………hopefully a couple ounces 😄
Old 02-17-2024 | 04:21 AM
  #44
My Feedback: (209)
Front of fuse taking shape, sawdust and wood shavings everywhere 😄
Old 02-17-2024 | 04:28 AM
  #45
RICKSTUBBZ's Avatar
Lots of sanding...
from what i can see in the pictures, some nice sized triangle stock for the corner longerons and the 1/4 sheet really gives you the chance to round it over.
It will turn into a really nice airplane with all the round corners.
Of coarse, then, a little extra care needed when covering on the compound curves..
Looking good!
Old 02-17-2024 | 05:10 AM
  #46
My Feedback: (209)
Not sure how deep I’ll go, looks like I’m about half way to where the plans show…….. achoo!
Old 02-17-2024 | 05:19 AM
  #47
My Feedback: (209)
3 pounds 5 oz with tank, mount, rods, and gear attached………. Achoo! 🤧 I think I can hit 6.5 ready to fly…….
Old 02-17-2024 | 06:38 AM
  #48
My Feedback: (209)
Starting to get the “look”
Old 02-17-2024 | 07:09 AM
  #49
My Feedback: (209)
Time for a 🐽 snout……….
Day 9 so far and all is going pretty well.................
Old 02-17-2024 | 02:22 PM
  #50
My Feedback: (209)
Snoot roughed in………..very rough but it will clean up fine……….
All up weight so far with engine and pipe added is 5 pounds 2 oz.
Looks like 6.5 is going to be my finish weight target, anything less is icing on top.....
