Dumb Question? >
Dumb Question?
Dumb Question?
Old 06-26-2002 | 04:45 PM
Crash Master's Avatar
Default Dumb Question?
If I wanted to put say 5 degrees of down thrust to a firewall, how would I do this? Would the firewall be slanted to the bottom or to the top (if that makes sense)? Any and all help is appreciated.
Crash Master
Old 06-26-2002 | 05:12 PM
My trainer has 6 degrees downthrust. The engine angles downward.
Old 06-26-2002 | 06:01 PM
Default Re: Dumb Question?
Crash Master
Slanted to bottom .
Down thrust is litteraly moving the thrustline to provide more downward thrust. Generally to offest drag above centreline as with a high wing trainer that tends to climb when more thrust (throttle) is used.
You could change the firewall or
- add a couple washers to the top mounting bolts of your mount
- or add a couple washers to the rear mounting bolts of your engine (assuming it's mounted upright, front bolts if mounted inverted)
Old 06-26-2002 | 06:11 PM
That's exactly the information I was looking for.
Thanks for the input,
Old 06-26-2002 | 06:25 PM
Glad I could help.
All the Best!
