 The GP Cap 232 is almost there >
Old 12-10-2004 | 06:27 PM
  #51
motodude11's Avatar
Default RE: The GP Cap 232 is almost there
I finally figured out why my motor wouldnt hold in the tanks to low and the engine has a hard time with the draw of the fuel i got to change that and fix the rest of it im glad that at least some of you guys are having somesort of sucess with your setups
Josh
Old 12-24-2004 | 11:09 PM
  #52
ok
i got some pics finally. There is some of my pipe setup with a new coupler material. I have yet to see if it will hold up in the long term yet. Here in Canada we are in the winter hence the skiis and we got almost a foot of snow on the ground. i did raise the fuel tank becuase i thought it might cause a problem if left stock and it runs fine with the tank raised maybe and inch or so.
Tom
Merry CHRISTmas
ID:	206575   Click image for larger version
Old 01-07-2005 | 01:03 AM
  #53
hi there kiwisdofly
Im also in auckland. I fly out at mt Roskill modeling club.
Would all of you recommend the cap as a great 3d flyer?
Old 01-07-2005 | 07:44 AM
  #54
kiwisdofly's Avatar
Hi there,
Im Not really that qualified to start commenting on the 3d stuff.[&o] Can tell you, however, that the Cap 232 is an un forgiving aircraft that is (for some reason) a pleasure to fly. It really keeps me on my toes whilst in the air.........
Old 01-07-2005 | 07:46 AM
  #55
kiwisdofly's Avatar
Looks like alot of hours in thos little sleds,
Nice work.............
ORIGINAL: RVman
ok
Tom
Merry CHRISTmas
Old 01-08-2005 | 02:37 PM
  #56
hello
the cap could probably used as a 3D plane if you were careful to build very light so it won't snap. It is not one of the best 3D planes around but if you want something that actually looks like a real airplane i guess the Cap would work. I haven't really done any hard 3D manoevers but i can hover it and do some other stuff with no tendency to snap.
Tom
Old 01-14-2005 | 08:53 PM
  #57
motodude11's Avatar
if you want to do 3-D get an extreme flight mini 3-D i love it its insane it will do anything you want it to do i would not recomend this aeroplane for 3-D finally got it fixed by the way guys still not as nice as my zimpro ultimate (about the same size as a ohio)
Josh
Old 06-23-2005 | 06:50 PM
  #58
motodude11's Avatar
hey guys
thought id pipe in again since no ones talking in this thread anymore i just got my cap finished again and im installing a perry pump on it this weekend, im also redoing the graphics hope everyone is happy and healthly and flying instaed of repairing and building like me. Keep on flying.
Josh
Old 07-21-2005 | 07:53 AM
  #59
motodude11's Avatar
got even more photos look at my gallery to check out my redone GP cap 232 with new graphics and a new attitude
Josh
Old 07-21-2005 | 02:51 PM
  #60
Spad_man's Avatar
My Feedback: (8)
I wil jump in here, good post, and nice looking CAPs. Heres mine it's all most done. It has pull pull rudder and alirons, OS 46 FX.
ID:	299902   Click image for larger version
Old 07-21-2005 | 08:45 PM
  #61
ckangaroo70's Avatar
My Feedback: (51)
Just putting the finishing touches on mine as well. Mine is equipped with a 61 Magnum 4 stroke, and all Futaba Gear. It won't have real good verticle performance with the engine I have on it, but it should fly it pretty scale, and be able to do some fun aerobatics. It was a fun kit to build, and I am hoping it fly's as good or almost as good as my GP Extra 300 of the same size.
Old 07-21-2005 | 10:58 PM
  #62
FlyingPilgrim's Avatar
My Feedback: (26)
I am still trying to trim mine out for good flight. I found mine wanted to climb way too much, and had to dial in alot of down elevator. It did not land well unless I kept speed way up. I moved my CG back, and adjusted both ailerons up alot (to add down force to wings). That helped alot, but still was not right. I suspect that the engine needs about 2 degrees down thrust to make it fly right. When I have time, I will shim the engine 2 degrees and take out the aileron trim to see if that helps. I read a review some time ago that suggested the same thing- down thrust needed. I was impressed with the overall performance otherwise. If you have one that you have not flown yet, I suggest CG half way between center and rear of suggestion on the plans/instructions, and add some down thrust!! Nice kit to build, though. BTW, mine has OS .70, which gives great verticle with a APC 13x6. Balance was perfect with no lead. I would recommend this engine highly for this airframe. I was just surprised that the downthrust issue is not what it should be. Perhaps GP should add an update regarding this.
Pilgrim
Old 07-22-2005 | 08:00 AM
  #63
Spoiler's Avatar
Glad to see there are so many people still building kits. Must say i really love my Cap - its a seriously pretty aircraft in the air and is good fun to fly.
On the trim issues - mine is exactly the same - also climbing and requiring down trim. Landings can be very slow tho as mine does not snap. In heavy wind you have to use quite a bit of throttle otherwise it does an elevator landing usually short of therunway - but again, no snapping! I tried adding down thrust but it didnt seem to make any difference. I think the wing incidence could be wrong and will change it one day.
In light wind it will 3 d ie elevators and harriers, blenders, spins etc altho the latter may rquire a cg change to flatten them. Mine has no lead to balance and flies well with 50 sx and pitts muffler.
Am now thinking about a bigger Cap - say 25% in kit form of course[8D]
Old 07-24-2005 | 05:33 PM
  #64
motodude11's Avatar
Flyingpilgrim it actually sounds like it is tail heavy caps are notorious for it, and that would explain why you have to land so hot. Mine is now unoperational thanks to the flimsy landing gear set up, it ripped right off again. I love the plane and it is a big change from flying my zimpro ultimate, im just not use to it yet i've had 3 flights on it, and now the motor is finally running strong. The problem i had last flight is on landing im use to three pointing all my other planes and i just let it get to slow on me and it stalled into the field. This cap flys really good with where i have the cg on it now it doesnt tip stall or anything. It stalls to the nose and doesnt give you any real indications that its gunna stall, it just does. I also now really recomend perry pumps i love them!!
Josh
And heres a pic of mine after i fixed it the first time
Old 08-08-2005 | 10:54 PM
  #65
My Feedback: (26)
I checked my incidences today and confirmed my wing and stab at 0 degrees, engine thrust line at the designed +2 degrees. I recall reading in GP literature somewhere that this was in fact correct, but it just flies wrong, and doesn't behave tail heavy. I am going to shim the engine for zero degree up/down, and try it again. I haven't had time to mess with it lately, but hope to get out this weekend.
Old 08-10-2005 | 03:47 PM
  #66
prgonzalez's Avatar
Howdy,
I have my kit still in the box. I have three 2-stroke possible engines for this airplane, .46, .50, .61.
Which one you guys recommend?
Pedro
Old 08-10-2005 | 10:04 PM
  #67
Hi pedro, I think the .50 would work best for the Cap. The 61 is too heavy and the 46 is similar weight as the 50 but well, less power. It would fly fine on a 46 though.
Old 08-11-2005 | 07:59 AM
  #68
motodude11's Avatar
i agree 50 because thats what i have and its balistic
Josh
Old 08-11-2005 | 08:56 AM
  #69
prgonzalez's Avatar
Hi Josh,
Since you have a 2-stroke 50 in your cap, could you describe the vertical performance you have in your cap.
Pedro
Old 08-13-2005 | 12:50 PM
  #70
I'm not Josh but, my vertical is very good my engine and prop makes about 9.5# of static thrust plane weighs 5.5#, so make your own conclusions.
Tom
Old 08-13-2005 | 06:15 PM
  #71
motodude11's Avatar
i have a webra 50 gt which is know as a sick motor and mine has unlimited vertical (or until it runs outta range) lol
Josh
Old 08-13-2005 | 07:45 PM
  #72
prgonzalez's Avatar
Tom and Josh,
Thanks both of you for the information on the vertical performance using the 50 engine. Definitely, I will install a 50 in my CAP.
Any other modifications? How does it handle on grass? Does it tip over the nose?
Pedro
Old 08-13-2005 | 07:53 PM
  #73
motodude11's Avatar
no but the landing gear setup is pretty bad mine has broken off twice and it riped the structure off the fuse both times, also make sure your balence is on the forward settings for the recommended balence range! and try to push the tank as high as you can in the fuse and makes sure the carb is even with your tank lines (as they come outta the tank)or else your engine wont run right because the feed for the motor from the tank wont be sufficient.
Josh
Old 08-13-2005 | 08:10 PM
  #74
prgonzalez's Avatar
What about the muffler? Are you using a slimline type of muffler?
Old 08-13-2005 | 08:37 PM
  #75
hey josh, for the landing gear all i did to reinforce it was add a piece of 1/8 ply with a cutout for the landing gear plate that fits over the LG plate and jams up against the lower firewall and wing mount former. The gear hasn't gone anywhere because the ply piece wont allow the LG plate to twist.
pedro, you can see my muffler earlier in this thread and my other mods. i taxi with full up elev (40 degrees) so not much problem with nosing over.
Tom
