Building a Dynaflite Super Decathlon
#1476
RE: Building a Dynaflite Super Decathlon
i just found this thread, and boy am i glad.
i can now share my experience regarding this awesome bird with others whom can feel the pain with me.
I built the Dynaflite super decathlon over fall and winter, and have flown it three times in past 2 months.
however, it has not been positive.
i am using a Saito FG 36 cc gas engine, with electronic ignition.
The first flight was scary and i soiled my pants. prior to flight, i thought i had appropriately checked balance. when plane took off, it kept wanting to climb, i could not trim it level. when i would get plane to fly level by pushing elevator stick up (elevator in down position), then the plane would roll hard to left.
took the bird home, there was a rough landing whereby i bent the landing gear, that was it.
once home, i repaired landing gear, and began to work on this. the plane is tail heavy, and the method by which i checked balance was misleading and not accurate.
i removed the 3 servos in rear bay, and moved them as far forward as possible. i then placed the two batteries behind gas tank. and added about 19 ounces of weight to nose area.
took to field:
second flight, was slightly better than first, it now flew more level, however, it kept wanting to roll to left.
did not like this, so i landed plane, which was rougher, and the landing gear ripped off with some ply. this was only damage.
took bird home, did some repairs. and also checked the right to left balance. it appeared that the right wing was heavier. so i added weights to left wing, 1.5 ounces.
third flight was better than second, but still wants to roll to left. this has not been fixed with wing balance. landing plane, only damage was bent landing gear.
brought plane, and now,
fortuitously, the damage from second landing led me to rebuild the area under the tank, and now, i have placed the battery for the ignition and for the servos, directly under the gas tank.
by doing so, i have been able to remove approximately 12 ounces of weight from the added metal weights.
plane is level now.
have not flown it yet.
i also did one more modification, i increased the right thrust by placing two washers behind engine mount on left side on both the upper and lower left screw area.
i am interested to see how it will fly now, i also have removed the weights from the left wing.
any advice would be appreciated. has anyone else had this experience with the DF SD?
#1478
Banned
ORIGINAL: cshahrdar
one more question, do we have to fly the DF SD with the wing spars, meaning, are they functional?
A model has to be balanced statically (like in the shop no flying) longitudinally (pitch axis) within the CG range location and also laterally (roll axis) . You are obviously working on that.
It also has to be balanced dynamically while flying.
Dynamic balance is affected by ___
The aillerons rigging that should have their trailing edge in line with the rest of the wings.
Any warp in the wings.
The incidence angle of each wing.
Just things to verify .
Zor
#1479
ORIGINAL: cshahrdar
#1480
yes, you are correct, the strut is what i meant.
thank you,
that is what i meant.
however, in the building instructions, they stated how the struts could be used to adjust the wing washout?
which, if the wing is warped, how could this help any.
i have measured the wing and spar incidence using the hangar 9 meter.
both wings, and root, are even. the right wing at its tip has less washout than the left wing at its tip.
the left wing has 1 degree washout at tip relative to root.
the right wing is o at tip relative to root.
do you think this would account for the plane rolling to left?
the engine does not have enough right thrust and it is a torque thing?
thank you,
#1481
ORIGINAL: cshahrdar
thank you,
thank you,
This most definitely could be your issue. It can also lead to nasty stall tendencies in the plane as well. The right wing will stall first, which could lead to the plane snapping right during a stall. Also, you are going to have to use aileron trim to counteract the difference in washout which can lead to even more trouble. The wing will always be fighting itself. The "D" tube construction of this wing is going to make it almost impossible to correct the washout problem. This wing is incredibly rigid once built.
If you built the plane according to plans, it already has plenty of right thrust built into it. Unfortunately, it sounds like you have a lot of issues built into this plane. Not sure there is an easy fix for any of it.
#1482
PA
Been a while - thought I'd throw these pics out there to those using the DLE30 as the PS. Built this muffler over the weekend - 1/4"clearance with the cowl.
Enjoy.
Enjoy.
#1483
PA
Didn't intend the duplicate front view (a beer too many....). This pictures shows the 1/4"clearance with the side of the cowl.
The other problem is the DLEengine head - the fins on the the lower right corner (looking at the front view in the post above )need to be trimmed back - they contact the interior corner generated by the air intake and the side of the cowl - hate to do it, but it's gotta go.
Thanks, SnR
Thanks, SnR
#1484
MT
If ones does snap rolls and other aerobatic maneuvers I would recommend building the struts as functional. Also bolting the wing with the recommended 1/4x20 nylon bolts, there might be a risk also of snapping the wing free.
15 fights with the DLE 55, awesome!
#1485
ORIGINAL: SticknRudder
Enjoy.
Enjoy.
#1488
Banned
ORIGINAL: cshahrdar
can you show me a picture or direct to me what this would look like.
thank you
thank you
Meanwhile think of snaps like on ladies dresses for small airplanes not exceeding 24" span
or like on winter jackets for larger airplanes up to 100" span.
You fasten the snap so they snap in or out at 90 degrees with the wing struts.
Any tension or compression of the struts is not trying to unsnap them because these forces are at 90 degrees with the forces needed to snap them in or out..
Each side has 3 snaps; one at the fuselage bottom side and two at the strut/wing connection.
See how much time it takes to snap in the struts ? About 5 seconds on each side and no tools are needed.
A bit of imagination figures the best way to install the snaps depending on their size.
On wooden struts I usually sew them on with #10 sewing thread and epoxy the termination.
I will try to find my pictures that probably were taken 3 to 5 years ago.
Zor
#1489
OR
I increased my hinge mortice depth in the rudder as Zor mentioned on a previous post, and it resulted in a nice almost no gap between rudder and fin. I'll do the same with all my other control surfaces.
Getting back to the subject of which gas engine to put on my SD, I originally was under the impression that I had to go with a Chinese made engine if I wanted gas. Now I realize there are more gas engine makers out there available that are not made in China. With that knowledge now, I am concentrating my engine search on those resources. Two engines I am very much considering are a Mintor 33cc and an OS GT-33. I believe they are both fairly new to the market. The specs on them are fairly close. They are both beautiful looking engines. Prop mounting looks different. I'd appreciate any input out there on these two engines. Espescially from first hand use or seeing them perform. Would like an easy tune and operation for my first gas. Any other non-Chinese brands that may be good that I haven't considered, I'd like to hear about. Please exclude the Zenoah, because I really don.t want to go that heavy.
Lamar
Lamar
#1490
ORIGINAL: lamarkeiko
Lamar
Lamar
You cantry Syssa: http://www.syssaaircraft.net/sap.html They are built in the USA.
#1491
OR
That Syssa 30cc is very appealing. It would cost me about $60 more than I would have to pay Tower for the O.S. GT-33. How does the static thrust compare between those two engines?
Lamar
Lamar
#1492
Banned
Here is a picture of a big snap as used on larger models to make the wing struts be functional and able to be installed by just snapping on and off without tools.
Zor
#1494
Lamar
Lamar
Do not expect to necessarily get the same thrust from an identical prop on each engine. You'll probably find that optimum results with each engine require a different prop, that is, one optimized to the engine and its characteristics.
#1496
Banned
ORIGINAL: cshahrdar
thank you ZOr
now i know what you are referring to
i will make these struts with this.
thank you ZOr
They can be bought from most fabric retailers.
Zor
#1497
My Feedback: (21)
Looks like that airplane wasn't given sufficient time on the runway to build speed, pulled up to abrptly, and snapped to the right. No offense meant, but it looks like it COULD be just a little ahead of it's pilot. Is this the airplane with the built in twist to the wing? That might explain it's flight characteristics also. Just my opinion.
Bryan
Bryan
#1498
Banned
ORIGINAL: warbirdmustang
Bryan
Bryan
Perhaps reversed aileons ?
Zor
#1499
you caught that
pretty good
what happened was i took plane with a cross wind,
my mistake
everyhting else people say is true and i am learning from that
what you saw is also accurate,
when i saw the wind was making it roll right, i wanted to make plane completely upside down to avoid the most damage,
which i was able to do
so i did make ailerons to right turn after i immediately saw the cross wind rolled plane to right
pretty good
my mistake
#1500
ORIGINAL: cshahrdar
you caught that
pretty good
my mistake
you caught that
pretty good
my mistake
