Jack Stafford Cessna 120/140
#76
Here s a link to the corrugated plastic. https://parkflyerplastics.com/cart/i...roducts_id=629
#77
I just started building my cessna 140. The rear spar has two different tapers on it, and I am not sure which is top and which is bottom. The spar on the plans is at the top of the wing plan, so can I assume that the top is the top edge of the spar, or is this up side down on the plans? Does what I said make sense?? lol
#78
#79
#97
The plans called for sig's Morresy Bravo wing joiners. Decided to use some pipe I had kicking around. Made up laminated ply blocks and drilled holes through them. Eventually, the pipe will have some dowel inserted in the end and the wing bolts will run down from the top, through the pipe, to fasten the wing on with.
#98
Next, onto the lower fuse half. I added some stringers to strengthen the firewall to fuse up, as well as make sheeting easier. Landing gear plates installed too.
#100
