Reload this Page >
Something extra colors
Old 04-03-2005, 08:34 PM
Dewey2
My Feedback: (24)
Default Something extra colors
Just can't figure out a color or trim scheme for it. Have a full roll black, red, chrome, very light yellow. about 1/4 roll bright blue. Any pics of planes using some of the colors, or ideas on schemes.
Old 04-03-2005, 08:45 PM
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
Default RE: Something extra colors
I've had two SE. The first I covered like the box. The second one I did a 3D Flag as suggested elsewhere here on RCU.
ID:	253676   Click image for larger version
Old 04-03-2005, 09:45 PM
ricknkim
Here's my recently recovered SE. Flies great!! I decided to use up my red, white and blue ultracote...
ID:	253731   Click image for larger version
ID:	253732   Click image for larger version
Old 04-04-2005, 08:37 AM
BadAtti2de
BadAtti2de's Avatar
Here is mine, its almost done. Just need to finish canopy, and radio install and a little more trim on the covering. I have an OS 70 fs on the front and a Carbon fiber landing gear.
ID:	253919   Click image for larger version
ID:	253920   Click image for larger version
ID:	253921   Click image for larger version
Old 04-04-2005, 08:40 AM
BadAtti2de
BadAtti2de's Avatar
Here is a rough of what i am going for.
Old 04-04-2005, 10:04 AM
hookedonrc
hookedonrc's Avatar
Here's mine. It's pretty much right off the box using pearl green, pearl white, and pearl black. I did add the checkerboard pattern under the leading edge of each wing, and on the rudder. Other than that, it isn't very different. I really didn't go all out because it was my first covering job. I am still learning....
Old 04-04-2005, 04:06 PM
MinnFlyer
MinnFlyer's Avatar
Note: Chrome is under red and yellow and about 3/8" bigger
Also, red and yellow are edged with black tape
Old 04-04-2005, 04:49 PM
RCKen
My Feedback: (9)
RCKen's Avatar
Mike,
wow, that's a great color combo. mind if I borrow it??
Old 04-04-2005, 06:53 PM
Dewey2
My Feedback: (24)
ORIGINAL: MinnFlyer
Thats is going to be it looks sweet. And does anyone have a tracing of the nose, i built it to use a cowl on, but want to go with the stock look.
Old 04-04-2005, 07:00 PM
WacoNut
WacoNut's Avatar
ORIGINAL: RCKen
I think that is the best looking 3D Flag I have seen so far!!! Good Job!!!
Anthony
Old 04-04-2005, 08:06 PM
RCKen
My Feedback: (9)
RCKen's Avatar
WWIINUT,
Thanks.
Old 04-05-2005, 08:46 AM
MinnFlyer
MinnFlyer's Avatar
ORIGINAL: RCKen
Mike,
Go right ahead
Old 04-05-2005, 12:08 PM
hancop
For everyone that has multiple colours on the plane. Do you just iron on the covering over the other colours, or do you have to cut the pattern out then only overlap a little for the multiple colours ?
I guess what I'm asking is: Can you iron covering on top of covering ? Will it stay in place ? Can you do it with both monokote and ultracote ? (ie monokote on monokote and ultracote on ultracote)
Old 04-05-2005, 01:31 PM
Connery
Connery's Avatar
You don't want to iron a large piece of covering over another piece of covering. Easiest way to do it, and the way I did my 4* is to cout out the trim piece, spray windex on the back and place the piece in the location you want it. With the widex you came move it around until you get it just right. Then take a credit card, or something simular and squeegie out the excess liquid. Let dry over night and then take a trim iron or trim solvent to seal the edges.
ID:	254436   Click image for larger version
Old 04-05-2005, 01:36 PM
RCKen
My Feedback: (9)
RCKen's Avatar
Connery hit it right on the head. The windex method is the best way to put one piece of covering over the other (monokote or ultracoat, works for both). you can do a search here on RCU and find several threads explaining how to use windex to apply covering.
Old 04-05-2005, 03:18 PM
ricknkim
The windex method works well with Monokote over either Monokote or Ultracote. Ultracote will not stick well with the windex method, I think it's something different about the adhesive. However, I did mine with Ultracote over ultracote and just ironed it on with a iron set at medium low. If you keep the iron moving and go from one edge to the other and push the air out as you go there really aren't much bubbles. Ultracote will bubble badly if you use higher temps though. I did use a trim iron set on high just on the edges to seal them down after the covering was on.
Old 04-05-2005, 04:56 PM
RCKen
My Feedback: (9)
RCKen's Avatar
ricknkim,
I stand corrected. I was under the impression that you could apply ultracote using the windex method. thanks for setting my straight on that.
