Reload this Page >
Top Flite 1/7 P-51 Build
Old 09-27-2008, 10:59 PM
  #1726
XxOoCoBrAoOxX
Default RE: Top Flite 1/7 P-51 Build
It might be that Im not flying, you think? Because I tested my smoke pump on the ground real quick, so it might be that the engine wasnt hot enough??
thanks!
Old 09-29-2008, 09:30 AM
  #1727
Mikel-t
My Feedback: (12)
Just catching up again on this thread...is there a cockpit kit for this bird?. Thanks
Old 09-29-2008, 03:17 PM
  #1728
Mustang Fever
Mustang Fever's Avatar
Mike:
There is one for the Topflite 1/7 ARF P-51. Tower item #LXTZP9, $11.50 I ordered one on 22 June and it still shows out of stock. It appears to include the pilot, the upper part of his seat back, a recessed instrument and panel kit which looks very nice, and maybe a radio. I'm not sure. I did get the exhaust manifolds, tho, which are tower item LXTZR4 and are $11.
This stuff is so much nicer than what's in the BIY kit, I couldn't resist. Not for $25.
ID:	1043232   Click image for larger version
Old 09-29-2008, 03:41 PM
  #1729
Mustang Fever
The fin and dorsal fin are all done. Ready to start on the cowl.
ID:	1043242   Click image for larger version
Old 09-30-2008, 08:03 AM
  #1730
Redwulf__34
Redwulf__34's Avatar
Now she is looking like a "pony"!
Old 09-30-2008, 05:45 PM
  #1731
Mustang Fever
Cowl is getting there.
ID:	1043907   Click image for larger version
ID:	1043908   Click image for larger version
Old 10-01-2008, 10:39 AM
  #1732
Mikel-t
My Feedback: (12)
Looking Good! cant wait for your next photo's!!!!. I appreciate the heads-ups on the cockpit too!.
Old 10-01-2008, 03:50 PM
  #1733
Mustang Fever
Thanks, Mike.
I just finished a real battle, fitting the lower half of the cowel. I'll post some pics later on this evening if I get it finished, with all the cutouts and stuff.
I used the fiberglass version available through
http://www.fiberglassspecialtiesinc.com/
I bought their belly scoop, too, as I want to cover the cowl and the scoop and I don't think the standard plastic parts can take the heat.
Old 10-01-2008, 06:10 PM
  #1734
planebuilder66
My Feedback: (8)
planebuilder66's Avatar
It's been taking a while hasn't it?, I know where your coming from, I built the p-47 and it took me 6 months from box top off to tarmac, it seemed to drone on and on with cut this, fit that, sheet here and sand there. But in the end it was awsome to see that plane taxi out on the tar in steamboat springs, made every hour worth it. I never had the peanuts to fly it until years later, and yes, I rolled it over because the alerions were reversed, but I fixed her up and flew it all season till the gear failed after landing and ripped the blocks out of the wing, shes on the shelf waiting for glass covering, but to be done very soon. The P51 looks great, which gear are you running?
Old 10-01-2008, 08:24 PM
  #1735
Mustang Fever
I'm using the Robart 531RS. They're the ones that have the cylinder outboard of the unit, so the assembly is very low profile. They accept 7/16" robostruts directly. They're big and beefy, and I really like them, especially after using the Robart spring down units (They're SpringAirs marketed by Robart) They suck, not to put too fine a point on it. The 531s are very smooth and reliable. I've included some pics of how I did the mounts for them. We have a very rough field, so I kind of over engineered them. If they rip out, tho, it'll be after the wing is totally destroyed.
As you can see in the pix, a little more shaping required on the fuse aft of the lower cowel. I'll probably leave that until the forward wing fairing is complete. The black oval on the bottom will be cut out for cooling, as will the classic Mustang "grin" under the spinner. After the cowel there's this to do: forward wing fairing, belly scoop, wing fillets, cockpit, canopy, finish/cover. All the radio gear and controls are installed and functional. I might try to get the "Warbirds Over Paradise" guys to let me maiden it the afternoon before the airshow down there in Cape Coral next January.
You're right. It's a chore, and it's taken me over a year and a half, but it really does go together very nicely and looks very scale, even with my 1/2 inch cheat on the stab and fin.
I'm worried about the weight, tho. She's sitting on 12 pounds as of the last assembled pic. That's minus the fiberglass cowel and scoop, the forward fairing, the wing fillets, cockpit/canopy and covering. I think final RTF will be in the neighborhood of 13 pounds- 3 pounds more than TF says it should weigh. Without that big engine and mount in the nose, tho, I'd be putting a bunch of lead in the cowel. Right now she balances at 1/4" forward of the recommended CG with only the 1400 mAh battery located near the tail wheel. I expect the finishing epoxy and the covering to shift the CG further aft, so that the battery can come forward a little.
13 pounds works out to a stall speed of 27-30 mph, depending on altitude. The numbers on the 120AX say I should be able to get 90mph and 10-14# of thrust. Should be enough. I'll just have to be a little more patient on TO, and careful to keep the speed up on landing, tho the flaps should help a lot there.
ID:	1044599   Click image for larger version
ID:	1044600   Click image for larger version
ID:	1044601   Click image for larger version
ID:	1044602   Click image for larger version
Old 10-02-2008, 09:45 AM
  #1736
Live Wire
Live Wire's Avatar
Bob
The bird is looking great.
Thought I had better check in and let you know I am still here.
I built my cowl and air scoope out of balsa. The air scoope has 1 bolt that fastens it on so I can get to my flap servo, The cowl has 2 dowels in the rear and 2 bolts virtical by spinner that you don't see, to hold it on.
Old 10-02-2008, 09:50 AM
  #1737
Mustang Fever
Larry:
That sounds like a slick way to secure the cowl.
Old 10-02-2008, 10:28 AM
  #1738
Live Wire
Live Wire's Avatar
I thought I put pic's here have to look if not I will take some. You guie's are just about caught up with the first part of the thread. Great to see people keeping this thread alive.
A lot of work for such a small plane Still working on the finer parts like control movement and Landing gear[:@] getting just the way I want it
Old 10-02-2008, 12:04 PM
  #1739
gords
Mine came in over 13 lbs as well. Take-offs are not a problem with the Saito 1.5 (should be equivalent to the Ax 1.20), the landings are FAST though, head winds help greatly with slowing things down!
Old 10-02-2008, 01:05 PM
  #1740
Mustang Fever
Thanks, Gords
I vaguely remember buying the 120AX precisely because it matched the 150 Saito in performance, or is at least very close.
Old 10-02-2008, 04:09 PM
  #1741
Mustang Fever
Basically finished the cowl and started the wing fillets.
ID:	1044951   Click image for larger version
ID:	1044952   Click image for larger version
ID:	1044953   Click image for larger version
ID:	1044954   Click image for larger version
ID:	1044955   Click image for larger version
Old 10-05-2008, 11:49 AM
  #1742
Mustang Fever
Got on a roll yesterday and the frame up is finished. Bit of sanding and shaping to do, but beyond that, she's ready to cover.
ID:	1046306   Click image for larger version
ID:	1046307   Click image for larger version
ID:	1046308   Click image for larger version
ID:	1046309   Click image for larger version
Old 10-05-2008, 02:20 PM
  #1743
skyriter
Nice Job.
Did you glass the wing and if so.. what weight etc.
Bruuce
Old 10-05-2008, 04:24 PM
  #1744
Mustang Fever
Thanks, Bruce
I sealed the balsa on the wing with thinned finishing epoxy, maybe 40-50%. Just enough to harden the balsa so that I can't dent it easily. I'm planning on doing the same to the fuse before covering, which will be ultra cote. Weight right now with a 1400 mAh battery is 12 pounds. I'm expecting close to 13 fueled and ready to fly. I'm sure I could have saved two pounds by going with fixed landing gear, but I think WWII planes flying around with their wheels hanging down is an abomination.
Old 10-05-2008, 07:28 PM
  #1745
N1EDM
Bob, could you please refresh my memory.... what are you using for an engine, and is that the TF Gold or the TF Giant Gold...
Bob
Old 10-05-2008, 08:03 PM
  #1746
Mustang Fever
Bob:
It's the 1/7 scale Gold Edition, 65" WS. I'm using an OS 120AX, probably with an APC 15x10 prop.
Old 10-07-2008, 08:48 PM
  #1747
N1EDM
Thanks... I was considering a OS-91 2S.
Bob
Old 10-13-2008, 08:31 PM
  #1748
Live Wire
Live Wire's Avatar
Just a few pic's I thought may help.
ID:	1051306   Click image for larger version
ID:	1051307   Click image for larger version
Old 10-13-2008, 08:36 PM
  #1749
Live Wire
Live Wire's Avatar
and a couple more, The last one is my 51 still doing some work on the landing gear[:@][:@]
ID:	1051322   Click image for larger version
ID:	1051323   Click image for larger version
Old 10-13-2008, 10:11 PM
  #1750
Mustang Fever
Nice shots, Larry.
I just started covering mine. It's gonna be a long process.
