Reload this Page >
Top Flite 1/7 P-51 Build
Old 10-15-2008, 04:55 PM
  #1751
savoy
My Feedback: (7)
Default RE: Top Flite 1/7 P-51 Build
Here mine, just completed with help from some great info in this thread. Glassed and auto paint, OS .91, Robart retracts. 6 flights so far. Great realistic flyer with no bad habits.
Old 10-15-2008, 04:57 PM
  #1752
savoy
My Feedback: (7)
And another
Old 10-15-2008, 06:58 PM
  #1753
Mustang Fever
Mustang Fever's Avatar
Nice lookin bird, Savoy. Did you weigh yours? We're all curious on that matter. Seems like so many of them end up way beyond what TopFlite claims.
Covering on mine is coming along slow but sure. First time doing an entire model in UltraCote. It has a couple of qualities I really like: it sticks to wood much better than monokote, and gets "stretchable" at a much lower temperature. I can use one iron set for sticking, around 220F, and another for stretching, around 275. As I'm doing a multi section camo job, I'm starting at the tail and working upward and forward, and each piece is getting stuck down completely to the wood. I'm putting relief cut transition pieces in all the corners, around all the big curves, and inside all the holes. Seems to be working well. I applied one coat of thinned finishing epoxy to all the surfaces, and sanded up through 800 grit.
ID:	1052635   Click image for larger version
ID:	1052636   Click image for larger version
Old 10-16-2008, 08:55 AM
  #1754
savoy
My Feedback: (7)
No weight, I don't have a scale that will give an accurate reading. I'm curiuos myself with the glass and paint finish. I can tell you though that with only a .91 in the nose I had to install the batt aft of the servo tray to balance per/plan. Also with the slow stall speed and easy landings it sure does not fly heavy.
Old 10-16-2008, 11:08 AM
  #1755
Mustang Fever
That sounds very encouraging. I just use a cheap fish scale to weigh mine. Close enough.
Old 10-16-2008, 03:57 PM
  #1756
Strykaas
Bob, I'm really interested to see how you'll end up with that technique. This is something that I have thought about a lot, covering a whole warbird entirely with Ultrakote (i.e. Oracover)... I see two hurdles: those curvy parts does not make for the easiest covering job... 2nd, you'll end up with *many* more seams, which implies less durability... than a full fuel resistant paint job. Maybe a clear coat on top of that could seal the seams ? Watch out for weight...
Old 10-16-2008, 04:42 PM
  #1757
Mustang Fever
Strykaas:
I don't think I'd try this with MonoKote, but the Ultra Cote sticks to itself much better. If I do anything to the seams, it would be just to run a Q-tip dipped in trim solvent around each, but I don't like to do that as it tends to make the colors run.
Old 10-17-2008, 04:23 PM
  #1758
Mustang Fever
Up close, you can see the imperfections, but I'm pretty happy so far. This is easily the most difficult Cote scheme I've attempted to date.
Old 10-17-2008, 04:31 PM
  #1759
Redwulf__34
Redwulf__34's Avatar
I can't imagine doing that scheme with ultracote!!!!!!!! My hat's off to you bob. It's looking good to me so far.
Sean
Old 10-17-2008, 05:51 PM
  #1760
Mustang Fever
Thanks, Sean. Mostly it's a matter of going slow. What you see represents this week's production, and the tail end still needs two or three more pieces of white on the other side, plus the insignia on the other side. And I haven't started the elevators and rudder.
Old 10-19-2008, 03:34 PM
  #1761
Mustang Fever
This is looking far better than I had hoped for. I'm starting to believe that UltraCote is far superior to MonoKote.
ID:	1055098   Click image for larger version
Old 10-20-2008, 11:29 PM
  #1762
Mustang Fever
Slow but sure. Got the colors just forward of the squadron band, and the roundels.
The process is not too complicated- I drew the camo pattern on the airframe, then use tracing paper to make a template of each piece. I have a 2x3 foot piece of 1/8 glass I use as a cutting board. I cut a piece of covering a little larger than the template, remove the backing, then put it on the glass with some windex under it so I can squegee it out flat. Then, tape the template to it and use a razor blade to cut it out. The hardest part is remembering to put in a 1/8 - 3/16" overlap on the forward and upper edges as I work forward and up.
ID:	1056035   Click image for larger version
ID:	1056036   Click image for larger version
ID:	1056037   Click image for larger version
Old 10-21-2008, 07:03 AM
  #1763
Redwulf__34
She is turning out really nice Bob, Keep going!!!!
Old 10-21-2008, 04:07 PM
  #1764
Strykaas
I think you could send the final picture to Ultrakote ! They are not aware of what can be done with their stuff !
Old 10-21-2008, 04:41 PM
  #1765
Mustang Fever
Thanks, guys.
I got most of the techniques from reading Faye Stilley's books on covering, such as making templates and cutting the sections over glass. For covering open areas, like the rudder, Faye says to glue the pieces together with trim solvent, also over glass, but that you can't shrink it much cause it will pull apart. So, I ironed the rudder pieces together over glass, and had no problems with shrinking it all later on. This worked so well that I might someday build a Spad XIII. The one thing that was stopping me was that all the Spad XIII's with squared off wingtips like the one in my plans were done in camo, which means I'd need all the techniques I learned on the P-51.
Old 10-21-2008, 11:44 PM
  #1766
Mustang Fever
Since it's so much easier to get a straight line from nose to tail while part of the balsa fuse sides are still exposed, I went ahead and did the numbering for the left side.
I used Faye Stilley's method of making the characters from covering. For 3" high characters, one constructs a grid of 1/4" squares, and Stilley supplies the coordinates to use for each character, the coordinates representing the intersection of lines on the grid. One ends up with a series of dots to connect that result in very nice looking 1/2" wide block gothic letters and numbers, of the size required for the model. It didn't take more than an hour to do the grid on graph paper, punch the dots into the covering with a T pin, cut the characters out, and iron them onto the airplane. I wet the airplane with Windex for applying them, so I could slide them around and get them perfectly placed on the alignment marks, then used the trim iron set to about 210 degrees so I wouldn't get bubbles. So far, so good, but I intend to set this airplane outside in the sun for an afternoon before I ever fly it, to get all the bubbles to show up so I can smack em down.
ID:	1056743   Click image for larger version
Old 10-22-2008, 09:47 PM
  #1767
Mustang Fever
Here's today's output. It's been 8 days, and the fuselage is showing less bare wood than covered.
ID:	1057203   Click image for larger version
Old 10-24-2008, 09:08 PM
  #1768
Mustang Fever
Only the lower cowl remains, along with finishing the cockpit and painting the canopy. Time for a break.
ID:	1058269   Click image for larger version
ID:	1058270   Click image for larger version
ID:	1058271   Click image for larger version
Old 10-25-2008, 09:44 AM
  #1769
Live Wire
Live Wire's Avatar
Bob
That is looking great, I am still fighting my main gear. It would have been easyer to install the air at the start rather than changing from electric to air .
Old 10-25-2008, 01:20 PM
  #1770
Mustang Fever
The gear is definitely the tough part. Keep plugging away.
Old 10-25-2008, 09:18 PM
  #1771
Riddle4U
Bob, your work looks very nice. Is that the bigger TF Stang? It looks bigger than 1/7th, though maybe an illusion (seeing it on a bar stool). I guess it is time to push my 1/7th to completion. I do note the title of the thread being a 1/7th TF Stang. Great work regardless.
Old 10-26-2008, 12:07 AM
  #1772
Mustang Fever
Thanks, Riddle. Yeah, she's the 1/7. I can't afford the big ones, or the vehicle I would need to haul them around in. "60" size works best for me.
Old 10-26-2008, 08:24 PM
  #1773
Mustang Fever
The fuse is getting close- everything's done except the cockpit, the pilot, painting the canopy and painting the spinner. I'll start covering the wing probably Tuesday.
ID:	1059622   Click image for larger version
ID:	1059623   Click image for larger version
ID:	1059624   Click image for larger version
Old 10-27-2008, 01:49 PM
  #1774
Mustang Fever
Started on the exhaust manifolds today. Wasn't sure of the best way to do them, so as they are the TF 1/7 ARF parts, I looked at the instruction book online for that aircraft. They have a recess in the nose for this purpose. So, I located and cut out most of the balsa in that area. I left the small piece alone, as that's where a lot of the strength in the firewall attachment is, and cut a notch in the manifolds to fit over it. I sanded the edges of the 'folds, and used 5 min epoxy to stick em in there.
I'm now off to the Highpoint body shop to see about etching/painting of the spinner.
ID:	1060004   Click image for larger version
ID:	1060005   Click image for larger version
ID:	1060006   Click image for larger version
ID:	1060007   Click image for larger version
Old 10-27-2008, 09:02 PM
  #1775
skylarkmk1
skylarkmk1's Avatar
Mustang Fever,
The stacks look good. Here are a couple exhaust close ups from a F-51D, N 314BG, painted up as Petie 2nd.
Note the progresively heavier white exhaust residue on the front of each exhaust stack as you move from the front to the rear.
ID:	1060343   Click image for larger version
