Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
#101
IC, great website. That is my favorite shot of the ME109, like a leopard lurking.......waiting to pounce. [8D]
#102
ORIGINAL: Mode One
What's all your opinions of Solartex's Olive drab PC10, color wise that is.
#103
Bhole, those dont look good.......they look great! Always nice to see that picture. Do you have any other pics, one in flight maybe?
#105
A few more.
All these pics were taken with a borrowed camera. My wife and I bought a camera recently, just haven't had the birds to the field since.
#106
You built two Balsa USA SE5's? Hmmm, sounds like a good idea.......boy is my wife going to be pissed. Now all I need is another Fokker DVIII, Fokker DVII, Fokker Eindecker, Sopwith Pup......and two each of all the others.
I actually did think of building two more Fokker DVIII's from the plans. I wanted a pair of them in the lozenge and one in the Bumble Bee stripes like the one I wrecked last summer
#108
LOL! Unfortunately, only one of them (#14, bluenose) is mine. The other belongs to a buddy who really helped finance the project. I bought my kit (on sale) and the G-38, he paid for everything else in exchange for building his. I have $600 invested in mine, he has $1500 invested in the pair!
#110
I always thought there was a law about telling wives
Amazing the number of planes that I have brought home that I "won" at club contest and stuff
#112
Prop Nut
You have an ASP 80 in your SE5A now ?... How did the CG work out.. I am planning on a Magnum .91 which is about the same weight I would imagine... Do I need to invest in some lead ?...[8D]
#113
Just a little bit, and that might be because of the damage I did to the tail last summer. I balanced it as per the plans, flies great.
#114
Somewhere on this or other threads on other forums, you guys talked about aileron servos. How many did you all use and if not four, where did you put them. I'm thinking only two in the lower wing.
#115
From what I have read most guys are using two in the lower wing ... Then connecting the lower aileron to the upper with linkage if so desired...
#118
I didnt feel (IMHO) that four were warrented. I have found, after a year of really torqing that thing around, that two work just fine. I wanted to save the weight, save myself from having a servo wire up a cabane, and save myself the cost of two extra servo's.
#119
Do four ailerons work better then the four ?.. Better enough to run the likage from the bottom one to the top one ?.
#120
Yes, the more surface an airplane has to steer with the quicker responce it will have. I point to 3D planes as an example. Very responsive and very large movable surfaces. You dont really need all four working but you get really good control in manouvers if you do. Besides, it looks really cool
#121
"Do four ailerons work better then the four ?.. Better enough to run the likage from the bottom one to the top one ?."
What were you trying to say here Iron Cross? Prop, How big (Torque) servos did you use. I like the idea of reducing cost, weight and wiring with using two, also.
#125
I didn't think it fair, only thanking you, Prop Nut. Iron Cross also gave his opinion. However, maybe you are a multiple personality and you are both Prop Nut and Iron Cross? Does this mean you can fly two airplanes at once? Can you dog fight with yourself? Carry on conversations with yourself? Have you been exposed to too much Polyester Resin?
