JACK STAFFORD Models Aircoupe's
#52
![](/forum/images/badges/premium_member.png)
I have plane #2 caught up with plane#1, they are both ready for panel lines and rivets.
I am working on fitting the cowling on plane#1, here is a pic of what I have so far.
Later!!
Anthony
Later!!
Anthony
#53
I have the cowling fitted on Plane #1 and put everything back together to see how it looks. I think it is turing out very nice and the panel lines, rivets and paint shold really do the trick.
Here are a few pics!!
Anthony
Anthony
#54
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (22)
I like this Koverall finish idea. If I did that and filled the weave with this poycrylic stuff, could I use rattle can paint like Lusterkote or even Rustoleum ????? (I'm doing the old Sig Bonanza, half plastic, half wood)
#55
ORIGINAL: PilotFighter
Just put a couple of good coats of primer to assure that the weave is filled and you can paint the model.
Anthony
#56
I have the panel lines on Plane #1 finished,
As you can see from the pics below I layed out the lines with 1/64" chart tape and then sprayed over the tape with 3 coats of primer. After the primer dried I sanded the top of the tape with 400 grit paper to remove the primer from the top of the tape thus leaving a nice clean panel line![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
For my 1st attempt at makeing panels lines I think it turned out pretty good.![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
Anthony
Anthony
#58
And deprive you of all the fun??? I think not!!!![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
Anthony
Anthony
Rather than watch you build your Coupe, then borrow every technique to finish my bonanza, why don't you just come over and finish the bonanza for me?![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
#59
Does this covering weigh more than using the plastic coverings, and how fuel prof is it? What kind of special tools would you recommend when using this process? Pilotfighter might have to go to your house.![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
John
John
#60
The covering will weigh slightly more than iron on material but I think it is worth the weight gain. All you need is a good pair of scissors and some new #11 blades for your x-acto knife, paint brushes for applying the dope and polyc. The Koverall shrinks very nice and it will go around compound curves better than any iron on covering IMO.
On the average sport/scale model the weight gain will not hurt the plane, if you are building a high performance aerobatic plane stick with the iron on covering.
You need to either paint the plane with fuel proof paint or spray on a fuel proof clear coat as I am doing with these planes. I painted my 1/4 scale cub this way and it is holding up very well.
Later!
Anthony
Later!
Anthony
#61
I am in the process of laying down all the rivets on the fuselage[&o]
I am useing Elmers glue thinned down and applied with a syringe. Here are a couple of pics of how the rivets are turning out.
Anthony
Anthony
#63
I have all the rivets on the plane except the cowling which needs a little trimming for the exhaust. If all goes well I will be painting the fuselage tomorrow. Here are a couple pics showing the wing panel line and rivet detail.
Anthony
Anthony
#64
I am painting the fusleage,wing center section,cowling and canopy, nothing like waiting for paint to dry![EEK!](https://www.rcuniverse.com/forum/images/smilies/eek.gif)
I have the 2nd coat sprayed on and it is looking good. I am spraying very light coats and it will probably take 2 more coats to get even coverage. Here are a couple of pics of how it is looking.
Anthony
Anthony
#67
Here is a couple of pics of the cowling,
I will have to wait a day or two for the paint to cure enough to mask off to spray the yellow on the flying surfaces.
Anthony
Anthony
#70
Thanks!!![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
I am useing a HVLP spray gun and Behr semi-gloss latex paint I had custom mixed at Home Depot. It cost $11 a quart and I bought a quart of blue and a quart of yellow. I am thinning the paint with 40% windshield washer fluid. This allows you to spray very thin coats and it flows good and dries very fast. I will fuel proof the planes with clear gloss laquer. I painted my Cub with Latex lastyear and it is holding up great.
Anthony
Anthony
#71
I painted the yellow on plane #1 tonight, It is looking good and bright![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
I am going to lay out the panel lines on Plane #2 while the paint is cureing.
Anthony
Anthony
#74
Plane #2 has the panel lines and rivets applied and will be seeing the spray gun tomorrow![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
Plane #1 looks good but #2 should be even better, I have been keeping plane #2 1 step behind so I can learn from my mistakes and make improvements. The overall condition of the surface is smoother and the panel lines are more scale in appearance.
I will post some pics tomorrow after painting.
Anthony
Anthony
#75
CubNut,
Great job on the Aircoupe. I'm not building one I just like to read through the kit building forum to pick up tips and tricks. I noticed in one of your earlier post, you said you were using Robart hinges and in another post with a pic it looks like you have a few installed on the ailerons before you begin painting. If you did install those hinges, how did you remove them when you were ready for priming? I have a CG Ultimate I want to get back to and I have some Robart hinges and would like to use them.
