 throws for a midwest giles. >
Old 05-13-2008 | 08:12 PM
Default throws for a midwest giles.
just wonderin if anyone can dig up the manual for a midwest giles and find out the factory control throws on it.
ive heard there a little on the mild side but its a place to start.also been told if u got too much throw on the elevator it could be disasterous.
any input would help,thanx
its the 74 in 27% size
mv-warbird
Old 05-14-2008 | 12:26 PM
My Feedback: (-1)
Default RE: throws for a midwest giles.
Factory I don't know but I use A degree meter and set up my stunt planes for 12 and 18 degrees for high and low as my starting point then trim the plane the way I like it after each flight. It's A good starting point.
Old 05-22-2008 | 07:02 AM
joetach's Avatar
My Feedback: (7)
The factory throws are as follows;
Ailerons: Hi Rate 3/4in in Low Rate 9/16in
Elevator: Hi Rate 1 1/4in Low Rate 13/16in
Rudder: Hi rate 3/4in Low rate 1/2in
Be careful with Hi Rate elevator, the plane is inherently "snappy" at Hi speed.
Good luck,
Joe
